Frequently Asked Questions on the 2nd Generation RX-7 1986-1992 FAQ for FC
Old Dec 29, 2005 | 10:43 AM
Icemark's Avatar
Arrow Frequently Asked Questions on the 2nd Generation RX-7 1986-1992 FAQ for FC
Please look through this thread before posting any technical questions.
This thread was created to answer many of the commonly asked questions that pop up on a regular basis in the 2nd Generation RX-7 Technical/Specific section. It contains a questions and answers collected by all the moderators and many regular members of the 2nd Generation RX-7 specific section.
In this thread there are multiple posts on different subjects, covering subjects such as Engines (including engine swaps, modifications, Turbos, and the quest for more power), Lubricants and Cooling, Electrical, Emissions, Manuals and Links, Specifications, Body (including style updates and modifications), Suspension and driveline, and general questions including subjects like what to look for when buying and how long the cars last.
Table of Contents (clickable links direct to posts):
Body (including wheels and tires)
Electrical (includes warning beeps, radio wiring and electrical not working)
Emissions
Engines (also includes info on swaps, turbos, and the quest for more power)
General/Misc
Lubricants and Cooling (includes Fans, oils and coolant)
Manuals & Links
Specifications
Suspension & Driveline (including transmissions, rear ends suspension parts
Racing Beat Tech notes:
http://racingbeat.com/FRtech.engine.htm
Old Dec 29, 2005 | 10:50 AM
Icemark's Avatar
Body & Wheels
Can I use a 89-91 (S5) tail light on my 86-88 (S4)?
Yes with minor modifications to the body of the 86-88.
Here is a link on converting: http://www.aaroncake.net/RX-7/taillights.htm
Will 89-91 (S5) mouldings or bumpers fit on my 86-88 (S4) RX-7?
other than some minor mounting hole differences on the front bumpers, the mouldings and bumpers will fit fine.
What size are my wheels?
The stock sizes all have an offset of 40mm or 40 ET and are:
14x5.5 (steel) w/114.3x4 bolt pattern (Base)
14x5.5 w/ 114.3x4 bolt pattern (Base, Luxury, 87.5-88 SE)
15x6 w/ 114.3x5 bolt pattern (GXL, Sport, GTU, 91 coupe)
15x6.5 w/ 114.3x5 bolt pattern (convertible)
16x7 w/ 114.3x5 bolt pattern (Turbo, GTUs, Infini IV)
In addition please see below in this thread for stock wheel type and weight.
On the same vein, the stock tire sizes are:
14x5.5 = 185/70HR14
15x6 & 15x6.5 = 205/60VR15
16x7 = 205/55VR16
Will 3rd Gen RX-7 (FD) wheels fit on my 2nd Gen RX-7?
If you have 5 lug hubs and use spacers. Typically you need spacers around 25mm (1"), depending on tires
I want to change my wheels to something bigger. What offset should I use???
http://www.1010tires.com/WheelOffsetCalculator.asp
Wheels:
86-87 base model steel wheels not shown.
86-87.5 Base/SE/Luxury model phone 14x5.5: (13.5 lbs)
88 Base/SE/Luxury model phone 14x5.5: (13.2 lbs)
86-87.5 GXL/Sport 15x6:
87.5-88 GXL/Sport/GTU 15x6:
87 Turbo 16x7 :
88 Turbo 16x7 (simular to 87 except polished and 7 spokes)
10thAE same as 88 except painted Crystal White(21.1 lbs w/center cap and valve)
88-92 Convertible 15x6.5" (11.0 lbs)
89-90 GXL, GTU 15x6
89-90 GTUs, 89-91 Turbo 16x7" (17.1 lbs)
91 coupe 15x6
Paint Codes:
86-88:
Artic Silver Metallic - J5
Tornado Silver Metallic - K8
Brilliant Black - PZ
Sunrise Red - RH
Crystal White - UC
Dover White - WU
Noble White - WY
Satin Gold Metallic - 1A
Claret Metallic - 2H
Royal Maroon Metallic - 3A
Sapphire Blue Metallic - 5A
True Red - NP
89-92:
Blaze Red - SQ
Crystal White - UC
Winning Silver Metallic - 1F
Shadow Silver Metallic - 3G
Harbor Blue Metallic - 5D
Brave Blue MC - 5N
Old Dec 29, 2005 | 10:59 AM
Icemark's Avatar
Electrical (includes radio wiring and audio as well as warnings/beeps)
My speedometer shows incorrect speed
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/speedo-reads-%7E3-5x-speed-941733/
My wipers only work on low speed
The wiper switch has a relay inside that has failed. It will need to be replaced. There are several people that replace them, or you can do it yourself.
My tail lights don't work, but my head lights do
The light switch connections may have burnt out. Check the back of the light switch. If they are burnt, you will need to replace the light switch and light switch harness.
My dash lights don't work
Did you check the dimmer control??? If you did and they still don't work the light switch connections may have burnt out. Check the back of the light switch. If they are burnt, you will need to replace the light switch and light switch harness.
What type of bulb is used...
A full listing of the different types of bulbs is found in the Specifications section of this FAQ.
All my warning lights are on
It is normal for all the lights to come on, if the key is on, and the engine is not running, but they should turn of when the engine is running.
With the engine running the Alternator failure warning circuit in the CPU will switch the lights on when the voltage in the car drops under 12 volts. Either your alternator, belts, underhood fuse box connections may have failed. The voltage in the car and the voltmeter on the dash (only in non-turbo models) needs to be above 12.6 volts. If it is below 12.6 volts your alt is not producing enough power to run the car.
You also need it to stay at or above 13.6 volts to charge the battery.
The voltage in my car is Low or High
Normal operating voltage for cars is 14.4 volts. This is where the voltage should be when the engine is running. If it is not at this voltage, there is something wrong with the alternator or charging system or wiring.
13.5 volts is the bare minimum to charge the battery. Anything less than 13.5 volts while the engine is running is bad and indicates that the alternator is failing or mis-wired.
12.6 volts is battery voltage. If the car is at 12.6 volts or lower while the engine is running, then the charging system is not sufficent to even keep the car running and the car is running on the battery. This indicates that the alt has failed, or is disconnected.
Above 15 volts is very bad. 15 volts is the maximum that the electrical system works at. Above 15 volts and there is the potential of burning out electrical parts in the car such as the lights and computers. 15+ volts indicates the regulator in the alternator has failed or is disconnected.
What are the wire colors for adding aftermarket radio
LTBlue/Red= 12v+
LtBlue/White= +Accessory
LtBlue/Yellow= -power ant trigger
Red/Black=+ Lumination
White=Factory Amp Turn on
Ground to the body, use the 10mm bolt behind the center console front drivers access panel. Do not use the Red/Black as ground it will damage the interior light circuit and dimmer in the car
Front Speakers (maximum of a 15 watt peak from the radio):
LtGreen/Red= Left
LtGreen/Black= Left
LtGreen= Right
LtGreen/Yellow=Right
Rear Speakers (if applicable, if you have the amplified rear speakers again the Maximum of 15 watts peak is all the stock speaker amp input can handle):
Brown= Left rear
Brown/White= Left Rear
LtBlue= Right Rear
LtBlue/Orange=Right Rear
Note: as mentioned above the power antenna's trigger is ground (or - ). With all aftermarket radio's antenna output as 12 volts positive (+). To make a stock power antenna work you need a relay wired like this:
Some S4 models will have amplified doors woofers. There will be a round 6 pin low level DIN plug found on these models at the back of the radio.
Stock Speakers / Amps
Speaker Size:
Dash: 130mm (4”)
Door: 160mm or 150mm (6”) (note: true 6.5” speakers are 170mm)
Rear tower: 4” or 6"
Headrest: 3.5”
Rear floorboard: 5.25”
Amp Locations:
Door speaker amps are behind the driver’s dash speaker.
Front dash amps are next to the radio, or on the passenger’s side next to the pass speaker.
Rear amps are next to the radio (6" speakers), or on each speaker (4" rear speakers).
Headrest speaker amp is in the driver’s side just below the B pillar
My reverse lights don't work
Common if you had Clutch or Transmission work done recently to have the wires disconnected at the transmission. Occasionally the reverse light switch will also fail.
I keep hearing a beep beep beep
Probably the power steering computer telling you there is a problem with the system. The number of beeps before pausing will indicate the problem.
1-beep, pause, repeat - in case abnormality of speed sensor signal:
In case broken wires or short circuits occur to sensors or harnesses, the buzzer sounds 60-seconds after the engine speed signal of 2200 rpm continues for 18-seconds.
2-beeps, pause, repeat - in case abnormality of engine speed signal:
The buzzer sounds twice and repeats when the vehicle speed signal is missing input and/or no engine speed signal is found (short circuit, broken wire, etc.)
3-beeps, pause, repeat - in case abnormality of stepping motor signal:
The buzzer sounds when there are broken wires or short circuits in coils or harnesses.
4-beeps, pause, repeat - in case abnormality of the power steering microcomputer:
The buzzer sounds 4 and repeats when there are circuit troubles other than with the micro computer.
5-beeps, pause, repeat - in case abnormality of steering sensor signal: Steering sensor is mis-aligned or failed or steering wheel has been improperly installed.
I keep hearing this loud buzzer every time I hit the red line
Yep, for your protection.
My clock/idiot lights don't work correctly or the clock doesn't hold memory when the key is off
Probably the fuse is blown or you have cold solder joints on the clock/idiot light panel.
My horn doesn't work
Probably bad solder joints in the CPU
Fuse Box:
S4 coupe
S4 convertible:
S4 Underhood:
S5 (all models):
Locations:
I want to install an electric fan. How well will it cool? How much power does it give me? Which fan, and how do I install it?
In short, you gain a small amount of throttle response when free-revving in neutral, and any power gained (less then 1HP) is almost immeasurable. Cooling will be no better then using the stock clutch fan since the fan is only used at idle or very low speed driving, and it is the thermostat that regulates the temperature of the engine and not the fan. There's really no compelling reason to install an electric fan unless you need the space (FMIC, 20B install, etc.) or your stock clutch fan died. Remember that the stock clutch fan freewheels when it is not needed, so it doesn't suck any power from the engine.
Lots of info on e-fans:
http://www.aaroncake.net/rx-7/efanmyth.htm
https://www.rx7club.com/forum/showthread.php?t=435289
https://www.rx7club.com/forum/showthread.php?t=430082
https://www.rx7club.com/forum/showthread.php?t=385994
https://www.rx7club.com/forum/showthread.php?t=397450
https://www.rx7club.com/forum/showthread.php?t=393234
Installation instructions:
http://www.aaroncake.net/rx-7/efaninstall.htm
http://www.rotaryresurrection.com/ro...ectricfan.html
What is this little black box with a single wire and a small metal tab that is mounted near or on the clutch slave cylinder?
It is the Condenser (capacitor) for the Oil Pressure Sender. It is needed to protect the oil pressure gauge from burning out in the event of sender failure, and for smoothing any erratic pluses from the sender.
Old Dec 29, 2005 | 11:12 AM
Icemark's Avatar
Emissions & Exhaust
My car is having trouble passing emissions, but I have new spark plugs, filters, cats, etc. What do I do?
and:
J-rats Recipe for cheating emissions if its ABSOLUTELY necessary:
1. Turn variable resistor to full lean, or as lean as you can get and still run.
2. Trick ACV into pumping air to the cat all the time by removing the FORWARD UPPER vac hose, and capping it.
3. Run 87 octane
4. Run your tank down till your almost empty.
5. 2-3 bottles of alcohol in the tank. Drive VERY GINGERLY to the emissions station.
6. Once you pass go, DIRECTLY to a gas station and fill up with regular unleaded.
What emissions equipment can I remove?
This is a pretty good thread on that:
https://www.rx7club.com/forum/showth...hreadid=112251
My idle sucks or is erratic
Most likely the TPS is out of adjustment, but here is a further article to help:
https://www.rx7club.com/showthread.p...hreadid=235007
Can I use a Cherry Bomb/ Glass Pack Muffler?
The rotary engines exhaust temperature is very high, and often will melt the contents of cheaper mufflers that use fiberglass or glass packing. This (depending on quality) can happen in a month or two or in some cases in a few hours.
Old Dec 29, 2005 | 11:28 AM
Icemark's Avatar
Engines (including engine swaps and the quest for more power).
How do I check error/trouble codes?
S4: http://fc3spro.com/TECH/HOWTO/ERRORC...KI/zerror.html
S5: http://www.johnr.com/cpucodes.html
How do I compression test my engine?
http://www.banzai-racing.com/compression_test.htm
My RX-7 rev's up to 3000 RPM every time I start it when cold
Yep, part of the accelerated warm up process. Start the car with the clutch pressed in, and the car in gear if you don't want it to do that.
My car doesn't start
Remember when starting a fuel injected car you should never pump or press the accelerator pedal, but if it won't start it is probably flooded, Hold the accelerator pedal all the way down while cranking, do not pump the pedal. If it still doesn't start after a few tries, Then remove the EGI fuse and crank a couple more times, then re-install the fuse and try starting again. If then the car still fails to start it then you need to remove and clean the spark plugs, put in a teaspoon of good quality 20W50 motor oil or a teaspoon of ATF into the lower sparkplug holes, re-install the spark plugs and try again. Make sure you change your oil after you have started and run the car ASAP.
I just got my car and I want to make it faster, what are the first modifications I should do?
Do a full 60K tune up, replacing all the fluids (including brake, clutch, tranny, engine oil, coolant, and rear end lube), spark plugs and cables, all filters (including fuel, oil and air), belts, any hoses that are leaking or bulging, and the O2 sensor. In addition if the car is more than 10 years old or has more than 120K miles on it, the Pulsation Dampener (or pimary fuel rail and integrated Pulsation Dampener on 89-91 FCs) should be also replaced.
I have this hesitation whenever I accelerate right around 3500-4000 RPM
The dreaded 3800 RPM hesitation is cause 90% of the time by poor ground connections between the engine, the battery, and the car. Clean or replace all the under hood ground connections. On 86 model year cars , replacing/regrounding the pressure sensor's ground wire has helped (do not re-ground a 87 or later model year). If there is still a problem after that, look at cleaning the fuel injectors and (on a N/A) that your 5th/6th ports are operating correctly.
http://howto.globalvicinity.com/gv_w...i=58&co=1&vi=1
I think my engine has been overheated. How can I check to see if the coolant seals are good?
Fill coolant system ALL THE WAY UP (engine cold). Make sure that the fluid level is as high as you can get it. Leave the filler cap off. Remove the EGI fuse. Crank the motor (it should not start). If you get a LARGE amount of coolant coming out of the coolant fill, its safe to assume your coolant seals are blown. Also, a good indication is a fuel/exhaust smell in the coolant.
Do I need to upgrade my fuel injectors in my NA?
Most likely, no. The stock NA fuel system can support up to about 250HP, which you will not be anywhere near unless you are running a big bridge port or a peripheral port. The stock NA actually runs quite rich, so you will see some gains by leaning out the mixture quite a bit. Adding larger injectors is just going to cost you power and waste gas.
What size injectors does my RX-7 use? What colour are they?
Year Engine Plug Size Colour Part #
84-85 13B NA, low square center, 680cc, orange, 195500-0900
86-87 13B NA, low square center, 460cc, red, 195500-1350
86-87 13B Turbo, low square center, 550cc, tan, 195500-1370
88 13B NA, high square offset, 460cc, purple, 195500-1350
88 13B Turbo, high square offset, 550cc, purple, 195500-1370
89-91 13B NA, high oval center, 460cc, red, 195500-2010
89-91 13B Turbo, high oval center, 550cc, purple, 195500-2020
My engine cuts out when turning, but there is plenty of gas... whats wrong?
Fuel tank sock is dirty and needs to be cleaned or replaced, and or the baffles in the fuel tank are rusted away.
How long does a rotary engine run? Do I need to rebuild my engine?
Most 13Bs can last over 150-200K miles, while most 13BT engines usually last 125-175K miles, but remember that regular proper maintenance for the engines entire life is required for higher lifespan.
Can I swap a Turbo engine/Jspec engine/13BT/etc into my Non Turbo?
Yes, check these links:
https://www.rx7club.com/forum/showth...threadid=26647
http://www.rotaryresurrection.com/ro...conversion.htm
http://www.rotaryresurrection.com/2n...o_s4_swap.html
http://www.rotaryresurrection.com/2n...o_s5_swap.html
How do I add a turbo to my NA 13B?
What Turbo kits can I add onto my non turbo RX-7?
There are no longer kits formally made at the time of this post, however there are companies from time to time that do make available non turbo to Turbo Kits. Because most of these companies stop building the kits, or go out of business in short time, it is impossible to keep active links for them.
Most people that turbo a non turbo make their own kits:
Using the stock TII turbo, exhaust manifold with spacer, NA intakes and NA ECU:
http://www.aaroncake.net/rx-7/naturbo.htm
https://www.rx7club.com/forum/showth...threadid=88540
https://www.rx7club.com/forum/showth...threadid=88758
https://www.rx7club.com/forum/showth...hreadid=124232
http://users2.ev1.net/~ccoutts/turbo..._a_project.htm
Using the stock TII turbo, exhaust manifold, intakes, ECU:
http://forum.teamfc3s.org/showthread.php?t=37694
Turbo-NA Forum:
http://www.aaroncake.net/forum/forum...urbocharged+NA
Will a 3rd Gen RX-7 (FD) twin turbo engine (13B-REW) fit in my 2nd gen RX-7?
The simple answer is No! The motor mounts are in different locations as well as other issues; however if you have enough time and money it can be done. Much of the project will be custom fabricating all the systems that attach to the engine such as the exhaust, intercooler setup, cooling system and wiring. A standalone EMS is almost required and it is very difficult to control the sequential turbos. Most people go to a single turbo because of this. In general this swap is not worth the time and trouble unless you plan on making more then 450 HP.
Here is a basic write up: http://fc3spro.com/TECH/SWAP/FD3S/rew.html
There have been many past threads covering swapping the 13B-REW into an FC:
https://www.rx7club.com/forum/showthread.php?t=724758
https://www.rx7club.com/forum/showthread.php?t=721243
https://www.rx7club.com/forum/showthread.php?t=717051
https://www.rx7club.com/forum/showthread.php?t=718967
https://www.rx7club.com/forum/showthread.php?t=636334
https://www.rx7club.com/forum/showthread.php?t=713592
https://www.rx7club.com/forum/showthread.php?t=712829
https://www.rx7club.com/forum/showthread.php?t=710959
https://www.rx7club.com/forum/showthread.php?t=710360
https://www.rx7club.com/forum/showthread.php?t=699306
https://www.rx7club.com/forum/showthread.php?t=690691
https://www.rx7club.com/forum/showthread.php?t=686057
https://www.rx7club.com/forum/showthread.php?t=628090
https://www.rx7club.com/forum/showthread.php?t=681876
https://www.rx7club.com/forum/showthread.php?t=663582
https://www.rx7club.com/forum/showthread.php?t=674513
https://www.rx7club.com/forum/showthread.php?t=672656
https://www.rx7club.com/forum/showthread.php?t=668437
Can I put the RX-8 engine (Renesis) in the 2nd gen?
Well, technically yes. But it is not a simple bolt-in swap. The Renesis uses different mounts, and an entirely different ECU and wiring harness. Anything can be done, but this is much more complicated then swapping any 2nd gen engine into the car. Lots of fabrication, wiring and other things must be done to support this engine. It is generally easier (and probably cheaper) to swap in the 20B three rotor, or the 13B turbo from the Turbo II.
I want to replace my rotary engine with a piston motor, what can I do?
Some people have done that, but it is generally not covered or even recommended to be brought up here in the 2nd Gen Sections, but rather in the Other Engine Section of this board. There are also other websites out there that cater to helping conversion issues.
How much Horsepower did my car come with from the factory?
At the Flywheel ratings:
86-88 NA = 146 HP @ 6500 RPM w/ 138 Ft/lb @ 3500 RPM
86-88 Turbo = 182 @ 6500 RPM w/ 183 Ft/lb @ 3500 RPM
89-91 NA = 160 HP @ 7000 RPM w/ 140 Ft/lb @ 4000 RPM
89-91 Turbo = 200-202 @ 6500 RPM w/ 196 Ft/lb @ 3500 RPM
Infini IV = 215 @ 6500 RPM w/ 206 Ft/lb @ 3500 RPM
Can I install an 89+ intake on my '86-'88?
Yes, but it is not a direct bolt-on and some fabrication and wiring changes are necessary. Take a look at this website:
http://homepage.mac.com/carldavis/intake.html
What is the size and thread for this bolt or nut?
See this topic in the Archive: Master List Of Thread Sizes for 2nd Gen Nuts and Bolts
How do I tell the difference between an S4 and S5 engine?
See the following topics:
https://www.rx7club.com/forum/showthread.php?t=530583
https://www.rx7club.com/forum/showthread.php?t=263870
Lots of Info: https://www.rx7club.com/forum/showthread.php?t=373451
Pictures: https://www.rx7club.com/forum/showthread.php?t=341891
https://www.rx7club.com/forum/showthread.php?t=330057
Good thread: https://www.rx7club.com/forum/showthread.php?t=594874
Where do I install the sensor for my aftermarket temperature gauge?
There has been lots of discussion about where to mount water temp sensors/senders. The best location is on the water pump housing near the stock ECT (Engine Coolant Temperature) sensor. Drill and tap according to the threads on your sensor (usually 1/8" NPT). It is important this this sensor be installed before the thermostat. See the following topics for more information:
https://www.rx7club.com/forum/showthread.php?t=512268
https://www.rx7club.com/forum/showth...ender+location
https://www.rx7club.com/forum/showthread.php?t=361867
https://www.rx7club.com/forum/showthread.php?t=14683
https://www.rx7club.com/forum/showthread.php?t=430129
https://www.rx7club.com/forum/showthread.php?t=403701
https://www.rx7club.com/forum/showthread.php?t=137824
How do I remove the flywheel nut and flywheel?
The flywheel nut is torqued to approximately 350 Ft-LBs and is 54MM or 2 1/8" in size. You will need a large breaker bar or impact gun and then some means to keep the flywheel still as the nut is spun off. The flywheel can then be pulled off with a puller or pried off from behind. See the following topics:
https://www.rx7club.com/forum/showthread.php?t=559740
https://www.rx7club.com/forum/showthread.php?t=552288
https://www.rx7club.com/forum/showthread.php?t=485098
https://www.rx7club.com/forum/showthread.php?t=483905
https://www.rx7club.com/forum/showthread.php?t=399637
https://www.rx7club.com/forum/showthread.php?t=408309
https://www.rx7club.com/forum/showthread.php?t=273219
https://www.rx7club.com/forum/showthread.php?t=244162
https://www.rx7club.com/forum/showthread.php?t=176418
https://www.rx7club.com/forum/showthread.php?t=169323
https://www.rx7club.com/forum/showthread.php?t=83807
Do those cheap eBay "speed chips" or "mod chips" work?
No, they do not. In fact they're not even a "chip" (integrated circuit) but simply a 2 cent resistor in a fancy case. The theory is that by putting this resistor in series with the IAT (Intake Air Temperature) sensor you can fool the car into adding more fuel by making the intake seem colder then it really is. In reality we all know that more fuel is not equal to more power and by messing with the IAT sensor the car will run too rich and lose power. Also the price is a total ripoff considering that anyone could go out and buy the same resistor for less then 5 cents.
Do Toronados or other airflow modifying devices work on a 2nd gen RX-7
No, typically there is about a 10% Horse power loss and about a 2% fuel economy loss. Also see this report from Consumer Reports on Fuel saving devices: http://www.popularmechanics.com/auto...s/1802932.html
Can I install the S5 (1989+) intake in my S4 (1986-1988)? If so, how?
Yes you can, though there is some debate on the power gains achieved.
See this website:http://homepage.mac.com/carldavis/intake.html
Can I Run Nitrous Oxide On A Rotary?
Yes, but if you don't know what you are doing you can cause some serious engine damage very easily. See this writeup:
https://www.rx7club.com/forum/showthread.php?t=633853
Can I Rebuild My Rotary Engine? How Do I Rebuild My Rotary?
In general, anyone with a bit of mechanical skill and the ability to follow directions can successfully rebuild a rotary.
There are two archived topics which cover rebuilds and porting:
https://www.rx7club.com/forum/showthread.php?t=639375
https://www.rx7club.com/forum/showthread.php?t=374810
Old Dec 29, 2005 | 11:38 AM
Icemark's Avatar
General Questions (not covered in other headings)
What should I look for when buying a 2nd Gen RX-7?
Non Turbo: http://www.aaroncake.net/RX-7/buy1.htm
Turbo: http://www.aaroncake.net/RX-7/buy2.htm
General: http://fc3spro.com/TECH/h2b.html
I don't want to buy a shop manual for my car, is there a place where I can still find out the information from one
Shop manuals for both series can be found on-line at:
http://www.cochran-racing.com/FSM/index.html
or (86-88)
http://www.teamfc3s.org/main/factory...ual/1986_1988/
and (89-91)
http://www.teamfc3s.org/main/factory...ual/1989_1991/
89-91 Wiring only:
http://s8.photobucket.com/albums/a47/S5_wiring/
Where can I find links on specific 2nd Gen RX-7 information and models?
Searching this site is good. The search function can be found at the top right hand corner of the site. In addition these sites are recommended and can help with models and technical information:
http://www.fc3s.org/
http://fc3spro.com/
http://www.mazdamark.com/about_the_fc.htm
http://www.geocities.com/huguesdc1/
http://www.mazdatrix.com/faq.htm
What kind of gas mileage does the FC get on average? What can I do to increase mileage?
The FC is a sports car, not a Geo Metro. Therefore, mileage on average seems to hover around 15-18 MPG city, and 23-26 MPG highway. If you are getting less, you either have a heavy foot or your car needs a tuneup.
As for increasing mileage, the first thing that needs to be done is making sure the car is in good tune. Do a full tuneup including plugs, wires, fluids, filters, timing, TPS adjustment and everything specified for the 60K tuneup (see Haynes/Factory service manual). Learn to drive with less of a heavy foot. Accelerate slowly, coast in neutral to stops, and keep the revs below 3800. A vacuum gauge helps (drive for most vacuum), as well as an A/F gauge (try to keep it in closed loop). You can get some great mileage if you are patient.
Some topics on mileage:
https://www.rx7club.com/forum/showthread.php?t=438252
https://www.rx7club.com/forum/showthread.php?t=429568
https://www.rx7club.com/forum/showthread.php?t=433231
https://www.rx7club.com/forum/showthread.php?t=424535
How to get better mileage: https://www.rx7club.com/forum/showthread.php?t=412143
How is the FC in the winter? Is it safe to drive? How does it handle the snow?
Just fine actually. If you know how to drive, driving the FC is like driving any other RWD vehicle. A good set of snow tires is important, but there is nothing fundamentally "wrong" with the FC that makes it a poor winter car. Remember that with like any other light, RWD car, you need to be easy on the throttle and clutch. Take a winter driving course if you are unsure. Also, make sure the car is in good tune. Cold weather can make small mechanical problems into large mechanical problems very quickly. If you live in an area that uses salt on the roads, then it is very important to have the car undercoated (Krown, etc.) every year. Salt eats RX-7s. Aside from that, winter driving can be fun if done safely. Many of us in Canada drive our RX-7s year around.
What steps do I have to take to store my car for a long period such as the winter?
There have been many topics in the past covering storage. Here are a few good ones:
https://www.rx7club.com/forum/showthread.php?t=447478
https://www.rx7club.com/forum/showthread.php?t=362195
https://www.rx7club.com/forum/showthread.php?t=365565
https://www.rx7club.com/forum/showthread.php?t=103560
https://www.rx7club.com/forum/showthread.php?t=462826
https://www.rx7club.com/forum/showthread.php?t=468903
http://www.aaroncake.net/rx-7/storage.htm
How do I take my car out of storage or start a car that has been sitting for a while?
http://www.aaroncake.net/rx-7/unstore.htm
What does the VIN number mean/break down??
The North American Vehicle Identification Number breaks down like this:
RX-7 86-88 (8/85 - 12/88)
JM1 FC 33 1 * G 0 ######
JM1= Mazda Passenger Car
FC = RX7 Series
33= Coupe
35= Convertible
1= 1308cc 13B rotary non-turbo
2= 1308cc 13B rotary turbo
*= Check Digit
G= 1986
H= 1987
J= 1988
0= Hiroshima Plant
######= Serial Number
RX-7 89-91 (12/88 - 7/91)
JM1 FC 331 * K 0 ######
FC= RX7 Coupe
33= Coupe
35= Convertible
1= 1308cc rotary non-turbo
2= 1308cc rotary turbo
331= Coupe w/auto shoulder belt
332= Coupe Turbo w/auto shoulder belt
333= Coupe w/o auto shoulder belt
334= Coupe turbo w/o auto shoulder belt
351= Convertible w/o airbag
352= Convertible w/ airbag
*= Check Digit
K= 1989
L= 1990
M= 1991
0= Hiroshima Plant
######= Serial number
Build dates by serial number:
Model year-----Production Date----Serial Number
1986--------------8/85 - 6/86------100001-200000
1987--------------6/86 - 7/87------500001-600000
1988-------------7/87 - 12/88-----600001-700000
1989------------12/88 - 12/89-----700001-800000
1990------------12/89 - 11-90-----800001-900000
1991--------------8/90 - 7/91------900001-950000
Where can I see what others have done to their cars? I need project ideas!
https://www.rx7club.com/forum/showthread.php?t=608165
How big can I make my signature in the 2nd Gen RX-7 technical section?
1. Custom signatures are enabled, but any graphics used in such signatures are limited to a 20K file size and 460 x 200 pixels.
2. Signatures are limited to six lines of regular text, including blank lines, or the equivalent size in picture, or picture/text combination.
3. There is currently no system to automatically check for signature size limits, so Admins and Moderators will be checking manually. Should your sig be found in violation, you will be asked to fix it; if you don't comply, it may be removed without warning. It is your responsibility to edit your sig and bring it within compliance.
Old Dec 29, 2005 | 11:48 AM
Icemark's Avatar
My car seems to use a lot of oil. How often do I need to check it?
Everytime you get gas, you should check your oil level. The Rotary motor by design is supposed to inject oil into the engine based on throttle position. If you keep your foot on the gas a lot, you will use more oil. It is normal to use about 1 quart of oil every 1000 to 3000 miles.
Can I use synthetic oils in my Rotary engined car?
Yes and no. Mazda officially does not recommend the use of synthetic oils in rotary engines, however, long term and racing use has shown that the better synthetics (Redline, Amsoil, Neo, Royal Purple, Mobil1) are perfectly fine to use in a rotary engine, and will generally result in a 1 to 2% horsepower gain. However use of poor quality synthetics (like Valvoline, Castrol Syntec, Havoline, Etc) will result in build up due to high ash content left from these oils when they are burned. It is believed that is why Mazda did not recommend synthetics, because the couldn't pick favorites.
Other notes:
The Mazda Factory racing departments recommend and use ‘synthetic’ oils including the winning 1991 Leman’s 20-G 4 rotor Mazda 787B.
MazdaComp USA printed manual (now Mazdaspeed) recommends the use of synthetic oils for racing conditions.
Redline, Amsoil and Royal Purple Synthetic Motor Oils have been used in rotary engines (both race and street) for ten plus years with excellent results.
Most Synthetic Motor Oil is compatible with the bearing material, sealing elastomer's, and combustion seals used in a rotary engine.
What oil should I use in the FC?
According to Mazda:
In starting and operating temperatures below 20F, use 5W30
In starting and operating temperatures between 0F and 80F, use 10W30.
In starting and operating temperatures above 30F, use 20W50
As far as brand any good quality oil that meets the API SL or SM standards should be fine.
How do I kill that buzzer in the dash that goes off when the cooling system or oil is low?
You need to bleed the coolant or fill the oil. The buzzer is there to help you from blowing up your motor.
I am having trouble keeping the car cool
Do you have:
OEM thermostat? (of KNOWN condition) do not use aftermarket thermostats like Stant in 86-88 engines
The plastic Undertray under the radiator and front of the engine?
A radiator with a clear core and not too many bent fins?
Two belts running your water pump?
OEM rad cap? (of KNOWN condition) (note: the stock pressure ( .9 bar) radiator cap suggested for proper cooling and system health).
A coolant mixture of at least 40% coolant, to 60% distilled water (do not use tap water) or 50/50 mixture (recommended in climates that drop under 0F).
Old Dec 29, 2005 | 11:53 AM
Icemark's Avatar
Manuals & Links
Why was my question not answered? What's the best way to ask a question?
Here's a good link that explains how to ask an intelligent question using an online forum such as this one. It uses programming as an example, but everything covered is valid here as well.
http://www.catb.org/~esr/faqs/smart-questions.html
http://208.62.166.66:82/guest/shop_manuals/
OR
(86-88 only)
and (89-91 only)
S5 Wiring Diagrams:
https://www.rx7club.com/forum/showthread.php?t=530860
Where can I find the dealer fiche/parts catalog?
http://www.mazdamotorsports.com/pages/cats/rx7pubs.html
http://fc3spro.com/
http://mazdarx7.iougs.com/
Old Dec 29, 2005 | 11:57 AM
Icemark's Avatar
Specifications
What type of bulb is used in my USA spec MAZDA RX-7 in the..
High & low beam headlamp
H6054
H6054ST Silverstar High Performance Lighting: the whitest and brightest Halogen
Parking light
1157
Front turn signal
1157
Rear turn signal
1156
Tail light
1157
Stop light
1157
High mount stop light/Third Brake light
1156
Fog/Driving light
H3C-55W
License plate
168
89
Back up light
1156
Front sidemarker
194
Rear sidemarker
194
Ash tray
158
Map light
168
Dome light
DE3175
168 (spot lights on models equipped with factory sunroof)
Trunk/Cargo area
DE3022
Instrument-general
158
74
Hi-beam indicator
158
Automatic transmission indicator
158
Directional signal indicator in dash
158
For those without the FSM, slow internet, in a rush, or in the middle of a build and need some torque specs right away, here are the sheets Atkins gives out that were posted by another user.
The following weights are from Ted at FC3Spro.com:
All items weighed on a Toledo shipping scale (200lbs. maximum, 0.05lbs. resolution) and NCI shipping scale (100lbs. maximum, 0.02lbs. resolution).
We will initially be throwing up random measurements as we weigh items.
It will all be restructured as time permits, but for now there is no particular order to which the items are listed...
Toledo scale accuracy +/- 0.10lbs. - absolute accuracy +/- 0.20lbs.
1989 GTUs/Turbo rims (two measured): used, both include valve stems and balancing weights = 17.10# / 17.05#
1988 10th AE wheels rims (7 openings) (4 measured): Factory painted, used, without valve stems and balancing weights = 21.10# (average)
1987 Turbo II stock pre-cat - used, O2 sensor attached = 13.50#
1987 non-turbo stock exhaust manifold - used = 16.75#
1987 Turbo II stock spare tire and rim - 24.85#
1987 Turbo II stock turbo: used, dirty, NO lines except for rubber lines on wastegate = 21.70#
Aluminum flywheel: used, stamped "MI" (Mueller Industry/Midway Industry?), NO counterweight, NO fasteners = 10.25#
1987 Turbo II stock flywheels (two measured): used, NO fasteners = 27.55# / 27.40#
1987 Turbo II stock front brake rotor: used, 10.9" (Mazda spec, NOT measured), rotor width measured at 5 different positions (5 lug positions) average 21.174mm (actual measured are 21.16mm, 21.18mm, 21.19mm, 21.18mm, 21.16mm; +/- 0.1mm) [Note: Mazda spec new is 22.00mm], used = 12.25#
K2RD Stage 1 brake kit rotor: 12.19" x 1.25", new, two piece steel rotor with aluminum hat, fasteners (safety wired) included = 11.40#
Racing Beat 3" downpipe: used, NO fasteners = 6.50#
Racing Beat 3" pre-silencer - 15.65#
Nippon Denso AC compressor: used, dirty, no fittings but black plastic caps on valves attached = 14.90#
1987 Turbo II stock steel hood: used, windshield spray nozzles and hoses attached, all underhood insulation and front rubber flaps attached, 5A blue paint = 51.85#
1987 Turbo II stock aluminum hood: used, NO windshield spray nozzles or hoses, all underhood insulation and front rubber flaps attached, hood stripped (NO primer base) and repainted yellow = 29.20#
1987 Turbo II stock air pump - 8.80#
1987 Turbo II stock interior heater/AC blower - 6.85#
1987 Turbo II stock AC condenser core - 6.55#
1987 Turbo II stock driveshaft - 13.95#
1987 Turbo II stock driver's seat - 33.40#
1987 Turbo II stock passenger seat - 32.20#
Factory Metal Sunroof (w/out clips, headliner, etc- just the painted metal panel)(3 weighed) - 10.36# 10.40# 10.35#
Fiberglass replacement Sunroof (w/out clips, headliner, etc- just the painted fiberglass panel)(1 weighed) - 5.46#
Old Dec 29, 2005 | 12:05 PM
Icemark's Avatar
Suspension & Driveline (including transmission questions)
Can I install the Turbo II transmission into an NA?
Certainly. But you need to also install:
-TII flywheel, clutch, pressure plate
-TII slave cylinder
-TII starter
-TII driveshaft, differential, axels
-Adapt the wiring.
MazdaTrix makes a TII transmission to NA rear end driveshaft, so if you don't want to swap your rear end, you can use that shaft instead.
Can I install the RX-8 6 speed transmission into my 2nd Gen RX-7?
5th gear on the FE tranny is the same as the 4th on FC trannys anyway, so there is no real advantage of using the RX-8 tranny if you are thinking that the 6th gear will be a extra gear for an overdrive, and actually 6th on the FE tranny (.83 vs .71) is shorter than the FC, resulting in lower gas mileage at highway speeds.
Using a RX-8 tranny would be like adding a extra gear between 2nd and 3rd to a standard 2nd gen RX-7 M or R type transmission. If you look at the gear chart this does not match clearly, but in simplified operation it is the nearest description to what happens.
Add in, that the RX-8 6 speed transmission is also about 4 inches too short, forcing you either to relocate the shifter 4 inches forward in the car, or move the engine 4 inches backward (towards the firewall) to make it fit in the stock shifter location as well as fabricate a custom drive shaft and transmission mounts.
Did my 2nd Gen RX-7 come with a Limited Slip Differential?
Only the following USA model 2nd gen RX-7s had a LSD from the factory:
86-88 GXL
87-91 Turbo
88 GTU
89-90 GTUs (however not the 89-90 GTU)
Non US models with LSD info to come
streetlegal?
Mar 17, 2022 02:46 PM
