What size is that huge bolt on the flywheel?
Old Nov 20, 2003 | 06:20 PM
Cody's Avatar
SKELETOR!
Hey people,
I'm taking apart my FC engine, and just got the trans separated from the block.
What size bolt is that on the flywheel? I have to go buy a huge socket for it and was wondering if someone knew offhand what size I need to get?
Old Nov 20, 2003 | 06:22 PM
AcidShock's Avatar
Eet fase
I believe it is 2 1/8 inches big for SAE. I am not sure what that equates to in metric though.
hybridracer's Avatar
I Post In The Nude
54mm
amused's Avatar
hmmm its like... 2 and 3/16 or something. i bought one, was like 30 bucks from sears
Old Nov 20, 2003 | 06:27 PM
Cody's Avatar
SKELETOR!
Is it a Metric or Standard nut? I'm probably gonna have to call around to find one, I don't think the local auto parts stores carry anything over like 36mm.
Exact size, anyone?
Old Nov 20, 2003 | 06:29 PM
AcidShock's Avatar
Eet fase
I just looked in my tool chest and it is 2 1/8". You can use either that or 54 MM.
Old Nov 20, 2003 | 06:41 PM
I Post In The Nude
Autozone has em that you can rent, or sears, I know sears sells a 54mm.
Old Nov 20, 2003 | 06:56 PM
HeavyFoot86's Avatar
you have to have a flyweheel puller too, and it's a pain in the butt. take it to a bazda dealership, and get someone to take it off, thats what I did
Old Nov 20, 2003 | 06:57 PM
MAZDA**
Old Nov 20, 2003 | 07:01 PM
amused's Avatar
bah, flywheel puller? how about old fashioned muscle
Old Nov 20, 2003 | 07:03 PM
AcidShock's Avatar
Eet fase
How about a dead blow hammer too.
Old Nov 20, 2003 | 07:20 PM
I Post In The Nude
Exactly. Dont pay someone else to do what you can do for free You just gotta know what your doin
Old Nov 20, 2003 | 08:10 PM
Cody's Avatar
SKELETOR!
Hmm.....flywheel puller, ehh? Will my Steering Wheel puller work....or is it a different tool? Also, whats the deal with the 19mm on the front side? Is it still a "lefty loosey" nut? I attacked that thing with my impact gun, and nothing. Will a huge breaker bar work? Any tricks to getting it off easy?
Old Nov 20, 2003 | 08:13 PM
$150FC's Avatar
Currently Winning
heh, when i read the thread title i said "******* gigantic" outloud
but yes do what they said. if you get a long enough lever (say five feet) it's not hard to do.
Old Nov 20, 2003 | 09:44 PM
I wish I was driving!
769 posts and you can't use the search function? This subject has been beaten to death, both the nut size (54mm or 2 1/8 inch socket {available at sears}, fits fine) and the flywheel removal:
leave the nut on a couple threads so the flywheel does not shoot off.
Pry on one side of the flywheel and hit the opposite side with a dead-blow hammer (hit it hard).
Move the prybar to another position, and again wahck the opposite side (whack hard)
5-6 good whacks and it will pop off.
Seriously, though, search function, man.
Old Nov 20, 2003 | 09:46 PM
It is covered in red loctitie from the factory, just like the flywheel nut. Big torque will loosen them (they both thread normal direction), but it is usually easier to heat them with A. a propane torch or B. MAP gas first to break down the loctite, and then loosen them.
Have you taken a look at the handy, widely available FSM?
Old Nov 20, 2003 | 10:05 PM
Cody's Avatar
SKELETOR!
Nope.
I've taken a look at the hundreds of tools and various Rx7 things littering my garage and parkway areas now, and found nothing that would work to even "ghetto remove" the bolts.
If it helps, I'm not trying to save the engine, or flywheel, just interested in disassembling the engine.
I do appreciate your help, but the "use the search function" demand never seems to work, so I'm not sure why people bother to throw a fit about it.
Anyways, thanks for the info, I'll have to see if I can locate some more tools tomorrow. Worst case scenario, my impact hammer will disassmble the engine for me.
rotor_veux
Sep 3, 2015 07:10 PM
