using the temp sensor location at top of thermostat housing
Old Oct 25, 2004 | 02:02 PM
SidewaysFC's Avatar
I have a greddy temp gauge looking to hook it up somewhere. Is it feasible to use the stock temperature sensor location on the top of the thermostat housing?
Duh...the temperature will not be correct until the thermostat opens, but the temps are always hotter after it opens and close to its hottest point right when the coolant comes out of the water pump. And I don't rag on the car unless its fully warmed up...meaning the tstat is open, thus the sensor reading the right temps? am I wrong? ...advice please.
ty
Old Oct 25, 2004 | 03:03 PM
2ndGen.rocket's Avatar
Ho's and Cadillac Doors
This is an electric temp gauge I take it? Then yes, using the stock temp gauge location is fine. Notice how you can watch your stock temp gauge climb when the thermostat opens?
Old Oct 25, 2004 | 03:07 PM
speeddemon32's Avatar
No more 7 or 8
accually, i thought the stock temp sensor was on the block just below the oil filter next to the oil pressh sensor???
I thought the thermostat, or radiator sensor was for coolant level?
Old Oct 25, 2004 | 03:44 PM
F1blueRx7's Avatar
Couldn't stay away
ty
That location is used for the ECU. You should use the location for the stock gauge which is near the oil pedestal. You can also install the sender in line with the radiator hoses which is what I plan on doing.
Old Oct 25, 2004 | 03:46 PM
My fault, I left a piece out of my post for some reason. What I was saying is that my mechanical gauge was mounted at the top of the thermostat housing. I could watch the thermostat open up with instantaneous response from the gauge.
Old Oct 25, 2004 | 03:48 PM
No more 7 or 8
ohhh.... he he he, thats cool! do you have an auto meter gauge? the reason i ask is because i have one, and i cant figure out ware to put that BIG sensor??? if so how did you get it in there?
Old Oct 25, 2004 | 05:30 PM
Tap and die set. Get an upgraded aluminum or steel fitting, and then thread the sensor right into the top of the water pump housing neck.
immanuel__7
89
Sep 5, 2015 10:23 AM
CaptainKRM
14
Aug 26, 2015 09:52 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
LMBTG
Aug 15, 2015 01:43 PM
