how to install a mechanical water temp gauge and what are the max temps can go to
Old Mar 11, 2005 | 06:07 PM
felixwankel88's Avatar
well when i re rebuild my engine i wanna be able to monitor the water temps VERY VERY VERY cloasely so i dont **** up again.. my question is how/where do i instll a water temp sendor and run it to a degree gauge in the car.. also what are the safe temps the rotary can be ran at.. like what is the max temp before u kill it... i just wanna have a better feel for the temp and how inacureate the gauge in the gauge panell is... links to kits are nice to hehhe... even better digial read out gauges arev nice to!!!!! well let me know what u know
thanks
Dustin
(p.s skittle will be resurrected)
Old Mar 11, 2005 | 06:18 PM
Wanked_FC's Avatar
Ihre Papieren, Bitte?
180-210F is normal
220-250 something's up
over 250 you're pretty much fooked
stock guage is useless
drilling and tapping the water pump housing is best, you get temps even the t-stat is closed.
Old Mar 11, 2005 | 06:35 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
I would argue that the wp pump housing is not the best. I put my sensor in the stock location on the block since that is the hottest point in the entire coolant system. I dont even have my stock temp gauge connected since it sucks anyways. With the sensor in the block I can see when the tstat opens and the with a accurate gauge can immediately see any fluctuations in temperature. If you want to keep the stock gauge I would recommend putting your aftermarket sensor in at the block and then drill/tap into your wp housing and put the stock sensor there.
Wherever you decide to put it just make sure you know what temperature it should be relative to its location. I dont recommend putting it anywhere after the tstat since there is a possibility it could give you inaccurate readings.
Old Mar 11, 2005 | 06:46 PM
thanks for the great responces... as far as having the stock one it dont really matter since it sucks.. could u get me a pic of where the stock watter temp gauge is... also ilike2eatricers do you agree with wanked fc's temps????
thanks in advance
dustin
Old Mar 11, 2005 | 06:48 PM
anyon e kknow of any a place to get the sendors and possible a digital temp read out gauge(heheh gotta go advanced lol)
Old Mar 11, 2005 | 07:19 PM
Impreza2RX7's Avatar
Jegs
Old Mar 11, 2005 | 07:56 PM
Aaron Cake's Avatar
Engine, Not Motor
The stock gauge does not suck, unless it is S5. The S4 gauge is actually quite good, but a little slow in the response time.
Summit Racing sells all kinds of digital gauges. But be aware that digitals are harder to read at a glance.
Best place for the sender in in the water pump/thermostat housing. Many possible locations. Just make sure to pick a spot BEFORE the thermostat, so you will still have a temp reading if your thermostat fails closed.
Old Mar 11, 2005 | 10:26 PM
NZConvertible's Avatar
I'm a boost creep...
Originally Posted by ilike2eatricers
I would argue that the wp pump housing is not the best. I put my sensor in the stock location on the block...
You're probably right (after all, that's where Mazda though was best), but there are few aftermarket gauges with sensors that fit in the stock location, and using an adaptor to make it fit is a bad idea as it spaces the sensor out of the coolant flow.
Unless you're lucky enough to find a gauge that fits the stock location, the back of the water pump under the thermostat is the best place.
Old Mar 11, 2005 | 10:38 PM
HAILERS's Avatar
HAILERS
Anyone ever try the drain plug hole on the intermediate housing?
Old Mar 11, 2005 | 10:52 PM
any one have a pic showing the locatition of the stock pressure sendorrr.
Old Mar 11, 2005 | 10:55 PM
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
how does that one look.. what kinda sendor will i need to get.. where can i get it
Old Mar 11, 2005 | 11:50 PM
alwayssideways's Avatar
Nurse I need 1300cc's NOW
thats where i was going to put mine
Old Mar 11, 2005 | 11:53 PM
Gene's Avatar
10 lb. boost, 5lb. bag
I have this in my car:
http://www.pegasusautoracing.com/Pro...asp?RecId=2492
Reads water temp and oil temp on one display. It comes with two senders and a wiring harness. Buy a spare sensor ($50) because they fail sometimes. You'll know when it fails because the reading will go all wacky. I disagree with AAron, when I had an analog gauge I would always misread it when glancing unless it was right on one of the marked numbers. With a digital you can read it instantly.
Old Mar 12, 2005 | 05:01 AM
My blitz electric water temp gauge was 1/8" NPT and fit right in the stock location. I also have an s5 so I can say the stock temp gauge sucks. The stock temp sesor location is to the left of the oil pressure sender.
EDIT: About the temps, my car runs normally at 82* C (180*F) which is normal operating temp. Sometimes when pushing it I get up to about 87*C (190*F) but never higher, except after I shut off my car (raises to 90* C or 194* F). This is with the greddy fmic and a koyo rad with all stock ducting and stock clutch fan.
Old Mar 12, 2005 | 09:26 AM
Dom_C's Avatar
I have mine before the thermostat. . i know not the best place for it but it works. It's actually right on with the stock gauge i feel. Anyways i have mine on the thermostate housing neck. (filler neck also) If you look at the filler neck you will see that there is a spot that looks it was cast to have a temp sender unit there. Well that's where mine is located. We drilled and taped that location and it works great thus far. All i have for a gauge is a shitty *** sunpro or wahtever VIP sells and it is shitty but it works, i'll be getting a better one in the future. Anyhow that's how i have mine run.
Dom
Old Mar 12, 2005 | 10:17 AM
Aaron Cake's Avatar
Engine, Not Motor
Ask the seller what sender the gauge expects. Looks like he is marketing it to Honda owners, which means it may be calibrated to work with the Honda sender (available at any wrecking yard or Honda dealer). However, for about $5 more, you can get a much nicer looking gauge from Summit Racing, complete with sender and wiring. Summit's house brand is cheap, or you can get "Cyberdine".
Sender locations are in the factory service manual.
Old Mar 12, 2005 | 11:01 AM
arron can you link me to the summit digital gauge please......
Old Mar 12, 2005 | 03:22 PM
Aaron Cake's Avatar
Engine, Not Motor
Are you serious? Go to http://www.summitracing.com . On the left, search the catalog for "cyberdine", "temperature gauge", etc.
I mean, you could put in some minimal effort. Or at least spell my name correctly if you are asking for a favour...
Old Mar 12, 2005 | 04:26 PM
You mean temp sender...
It's not about whether it works (it'll work fine), but about what happens if the thermostat fails. If it sticks closed, there won't be any flow past the sender. So as the engine cooks itself, the gauge will actually be reading cold. The temp gauge is supposed to show any temp-related problems, and in this location it won't.
Old Mar 12, 2005 | 04:30 PM
sorry aaron... i cant spell...i did find them
NZ thats the pic i waz lloking for exzatly thank you everyone for the help
Old Mar 12, 2005 | 04:47 PM
what do all of you think about this????
http://cgi.ebay.com/ebaymotors/ws/eB...category=33682
Old Mar 12, 2005 | 05:10 PM
Kenteth's Avatar
Like Ghandi with a gun
Get a new unit off summit, they will cost about the same, maybe less after ebay shipping rape
Old Mar 12, 2005 | 05:14 PM
but i couldent find the sender for the digital gauge on summit
Old Mar 12, 2005 | 05:22 PM
Kenteth's Avatar
...Most of them come with the sender... at least new ones do. Ok I take that back, in my experience in the past, new ones come with senders. Looks like summit lists them seperatly though:
Summit# sum-g2984 gauge ($30), sum-g2988 sender ($10.95)
or cyberdyne gauges through summit, summit p/n # cyba220e060n syberdyne gauge with hi/lo function ($49.95). summit pn# cyb-senss6e sender ($15.95)
Old Mar 12, 2005 | 05:29 PM
Aaron Cake's Avatar
Engine, Not Motor
That eBay gauge looks pretty decent. Certainly not my style, but if that's what you are looking for, it should do the job.
The Cyberdyne gauges at Summit require you to purchase the sender. According to my paper Summit catalogue, the Cyberdyne sender is CYB-SENSS6E and is $15.99
Summit also has their house brand of digital gauge. Part number SUM-G2984 for water temp, and SUM-G2988 for the sender.
