Differences between Series 4 and Series 5 TII motors? Please help!
Old Dec 1, 2004 | 09:24 PM
WannaSeeMyWankel's Avatar
STK/A-MKT TII PARTS 4SALE
Question Series 5 TII Jspec Motor in Series 4 N/A Car? Im screwed...
First off...I DID SEARCH, and got no help from it as usual.
What kinds of problems will I run into when I start this swap? Hopefully the harness is interchangable...but I doubt it, nothings easy with these cars.
Please help me out people!!
Old Dec 1, 2004 | 09:49 PM
RETed's Avatar
http://fc3spro.com/TECH/FAQ/ZVK/zvk.html
Harness does NOT swap over easily.
-Ted
Old Dec 1, 2004 | 09:53 PM
Is there a writeup for this swap?
Old Dec 1, 2004 | 09:55 PM
RETed's Avatar
You didn't find this in a seach???
I don't recommend it.
-Ted
Old Dec 1, 2004 | 09:58 PM
I already got the motor, I'm all ready to go...i gotta do it...so what do i gotta do?
Old Dec 1, 2004 | 10:07 PM
RETed's Avatar
Get these Turbo II parts...
Stock ECU
Main engine harness
Transmission
Driveshaft
Rear diff
Rear axles
Swap all parts with your NA.
Hopefully you can get the same series that matches the stock ECU and main engine harness, as plugging it into your S4 will make things a lot easier.
-Ted
Old Dec 1, 2004 | 10:26 PM
Well thats what i have...
Series 5:
Engine
Transmission
Rear Diff & Half Shafts
Harness
ECU
MAF Sensor
MAP Sensor
if i get all these parts for a S5 would it work out for me and function like a S5?
Old Dec 2, 2004 | 06:32 AM
according to the wirte ups about puttin a s5 engine in a s4 car, they tell you to keep the block and switch over everything else......if i just swap all the s5 electronics into my car will it work right?
Old Dec 2, 2004 | 06:49 PM
gotrotors?'s Avatar
You are correct. The EFI system of a s5 is very different from an s4. High impedence injectors rather than low, ELECTRIC OMP is the biggest difference...and that runs thru the computer...no omp...you get a check engine light. There are many other minor differences between s4 and s5. S5 does not have egr...s5 does not have the dreaded Pulsation damper. As far as wiring is concerned...i would try to get my hands on an s4 motor. Its not really worth the wiring for the 20 whole hp you get with s5. Just get an s4 motor and an s5 turbo and there you go. If you want to keep the s5 motor...you need to strip it down to the block and replace everything you took off with s4 stuff, minus the turbo manifold and turbo...that can stay. If you want to wire it, youre gonna need wiring diagrams for both series...and thats gonna get difficult. If you dont get things right, itll run shitty. Hope that helped. Im currently building an s5 motor for my s4...but im gonna use all the efi **** off my s4 for the s5.
Old Dec 2, 2004 | 07:08 PM
eriksseven's Avatar
Make Money.
^s5 does have a pulsation dampener...
Old Dec 2, 2004 | 08:23 PM
gotrotors?'s Avatar
strange....my s5 motor had no traces of a pd. Not even so much as a modifyed fuel rail. Maybe somebody put FD fuel rails on or something. No word of a lie...no PD
Old Dec 2, 2004 | 08:25 PM
What kind of wiring does it take to use the efi system from the s5? is it plug and play if i have the s5 harness and ecu?
Old Dec 2, 2004 | 09:08 PM
RETed's Avatar
Even FD's have PD's...that fail...
There is no way in hell the FD fuel rail is going to bolt right in.
The FD fuel injectors are radically different (side feed), so the fuel injectors and fuel rails are very different.
-Ted
Old Dec 2, 2004 | 09:20 PM
SleeperRx's Avatar
As far as the wiring goes, you could also simply get a standalone computer. Perhaps maybe a microtech or haltech and you wouldn't have to worry bout any changing of your s5 motor.
It could actually be your first GOOD performance modification and serve for future upgrades. Of course that is if your mechanically inclined to go this route and have the MONEY to do this. I think you could cut through a lot of crab by going this way. Only problem would still be your oil metering pump. If you want to run electronic OMP, then u might run into problems but i would recommend switching over to mechanical or premix.
Just a suggestion.
Old Dec 2, 2004 | 09:45 PM
gotrotors?'s Avatar
LOL i worked at rx7 specialties....and i didnt remember about fd rails. Im stupid tnite. LOL thanks for the correction. Perhaps jspec doesnt have one? Just a suggestion...but seriously there is no pd, i just checked again. Strange hey? It looks factory on both ends of the rail too. Hmmm.
Old Dec 3, 2004 | 07:47 AM
maybe your car has the banjo bolt to replace the pd, i read somewhere that you can do that...
Old Dec 3, 2004 | 12:24 PM
so wait. is this a S5 motor going into a S4? if so, i have everything electrical you need minus the harness. contact me on aim at driftedfc3s. btw, i'm also doing a swap. S4 T2 into S5 NA.
Old Dec 3, 2004 | 12:26 PM
Cool_ManX's Avatar
banjo bolt?
PD?
Old May 3, 2012 | 10:43 AM
sparkscarz's Avatar
hey u guys think a S5 N/A gasket kit will work with a S4 N/A? at least some of the gaskets?
Old May 3, 2012 | 10:52 AM
RotaryEvolution's Avatar
Sharp Claws
seriously, stop spamming the same ******* question over and over again in unrelated topics!
i at least see you have been doing some research looking at old threads but there is NO need to ask the same question less than 2 minutes apart and in severely old threads that do not even apply to your question.
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
