some helpful how to's
Old Aug 4, 2009 | 12:19 PM
serbRX7's Avatar
Arrow some helpful how to's
well her is some links that might help any one that going to mod there fd
this is just some links i found as i was doing reaserch for my project....
they might help you or give you some ideas what you might wanna do
with your setup
if any one got any other good HOW To's just add them to this thread
FD Block-Off Plates Installation
FD3s Fuel Pulsation Damper Elimination
i think every one should do this one i look at it like this pulsation damper is like driving around with ticking time bomb
u know what will happen when it goes off
if u got stronger fuel pump 4x850 or 2x1600 and 2x850 get rid off it...
Rotary Engine Compression Test
http://www.rx7.org/Robinette/
http://www.robrobinette.com/howtos.htm
this site has alot of stuff u might find intresting
Engine How To's
Remove Manifold
Vacuum Hoses
Turbo System Simplification
Boost controller
PRofec Install
AVC-R Install
ECU Modification
PMS Switch
Disable Double Throttle
Remove Throttle Body Coolant
Coolant Tank Elim
Water Temp Gauge
Fuel Filter Replace
Fuel Filter Move
Release Fuel Pressure
Fuel Pressure Gauge
Adjust TPS
Rebuild Turbo
Sparkplug Wires
Flush Radiator
Water Pump
Racing Radiator
Compression Test
Efini Y Pipe Install
IC Duct
Secure Battery
K&N Air Filters
Replace Oxygen Sensor
Remove Air Pump
Replace EGR
Disable EGR
Remove PCV Valve
Replace Turbo Coolant Lines
Cold Air Intake
Nitrous Install
Brake - Big Brake Install
Brake Line Replacement
Brake Proportioning Valve Install
Brake 929 Master Cylinder Install
Brake Line Flaring
Brake Bleeding
Brake Master Cylinder Bleeding
Shocks & Springs Install
Antiroll Bar Bushing Upgrade
Gauge Install
Short Shifter
Antenna Replacement
Turbo Timer Install
Racing Harness Install
Racing Seat Install
Hand Grip Repair
Raise Rear View Mirror
Fog Light Install
Daytime Running Lights
Safety Wire
Polish Aluminum
Repair Door Lock
Trailer and Hitch
Buy a Used RX-7
Other How To's
More Hints and How Tos
Old Aug 4, 2009 | 03:21 PM
wstrohm's Avatar
Recovering Miataholic
My in-bay Disassembly Sequence
FWIW, the attached MS Word document is the chronological series of steps I used to strip our '94's engine in the FD bay, down to the exhaust manifold. At the same time I was going for a LIM gasket replacement, I needed to change all 14 coolant hoses, and those steps are also mentioned in the sequence. Building back up was just the reverse of the tear-down.
Some of my references were to color-codes that are unique to my car.
Don't know if it's useful, so take or leave it as you will.
File Type: doc
Old Aug 4, 2009 | 03:39 PM
gracer7-rx7's Avatar
needs more track time
All that and more can be found in the FAQ thread stickied in this forum. You know the one that all the newbies are too lazy to read.
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/faq-3rd-gen-other-useful-links-68640/
Old Aug 4, 2009 | 05:10 PM
al.bre3zy's Avatar
Good read.
Old Aug 4, 2009 | 09:20 PM
cpnneeda's Avatar
RAWR!!!!!!!!
Add www.reganrotaryracing.com to that list. Great site, lots of pics, even part numbers.
Old Aug 5, 2009 | 10:43 PM
serbRX7's Avatar
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/looking-buy-rx7-3rd-gen-few-questions-339680/
https://www.rx7club.com/showthread.p...threadid=27094
see also: Buying an RX-7 (below),
**Useful websites, worthy of special mention**
www.fd3s.net/index.html
www.maxcooper.com/rx7
www.turborx7.com
http://reganrotaryracing.tripod.com/rx7main.htm
5th Gear Synchro Fix:
http://mahjik.homestead.com/files/ho...o/synchro.html
https://www.rx7club.com/showthread.php?p=1284686
20B info:
https://www.rx7club.com/20b-forum-95/where-does-all-costs-come-59544/
A
ABS module repair procedure: https://www.rx7club.com/3rd-generation-specific-1993-2002-16/93-diagnostic-module-rebuild-807185/
Advice for new owners, suggested modifications, etc... look for the long post by jimlab:
Aftermarket gauge install into the stock dash cluster:
https://www.rx7club.com/interior-exterior-audio-26/autometer-gauges-fd-inst-cluster-199139/
Air Separation Tank / AST / Coolant Expansion Tank:
Often fails due to heat and pressure. Many people replace them or remove them from the system.
http://www.rx7.org/Robinette/coolant_tank.htm
http://www.fd3s.net/coolant_tank_elimination.html
http://www.rx7store.net/product.asp?0=352&1=353&3=675
Airbox mod (thanks adam c)
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/cheap-stock-airbox-mod-121491/
Air to Water ( A2W ) Intercooler How to:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/my-a2w-intercooler-done-256178/
Automotive Electronics info, Toyota-based, but excellent basic information site for learning about how ECUs work, ABS, etc...:
www.autoshop101.com
Auto to Manual Transmission swap:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/automatic-manual-swap-how-hard-anyone-done-96658/
https://www.rx7club.com/3rd-gen-archives-73/mt-swap-161482/
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/so-how-many-people-have-done-auto-manual-swap-258966/
Auxiliary Injection:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/making-case-rotary-powered-fd-fix-806104/
https://www.rx7club.com/auxiliary-injection-173/
AWS Removal: Accelerated Warm-Up System is what causes your car to idle at ~3000 RPM's when it's super-cold. This heats up the cat converter(s) quickly, but can't be good for the engine.
http://www.rotormafia.com/dtc/
B
Battery relocation guide (passenger storage bin) w/ photos:
http://reganrotaryracing.tripod.com/batrelo.htm
https://www.rx7club.com/showthread.php?p=5577123
Battery Replacement : Hawker Odyssey PC680 , or Optima size 51R
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/half-size-battery-341087/
Boost Gauge Install:
http://www.fd3s.net/boost_gauge_install.html
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/boost-temp-gauge-install-newbie-guide-620341/
Boost Leak:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/boost-issue-not-going-over-7-psi-716185/
Boost Restrictor Pills: pill vs. nipple restrictor:
https://www.rx7club.com/forum/showthread.php?t=637406
Bose stereo: how to add aux input:
https://www.rx7club.com/interior-exterior-audio-26/bose-cd-auxillary-mod-716870/
Brake Bleeding: get rid of air bubbles for improved pedal feel and fade resistance.
http://www.zeckhausen.com/bleeding_brakes.htm
Brake Caliper Rebuild and Repaint:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/caliper-cleanup-rebuild-%2Apics%2A-388264/
Brake Job: how to change pads on all corners.
http://www.clubrx.org/default.asp?id...ntent=66&mnu=5
http://www.snapdrive.net/files/10340...eplacement.pdf
Buying an RX-7 / Buyers Guide / Used Car Shopping:
http://rx7.voodoobox.net/infofaq/bguide3g/bguide3g.html
http://www.marx7.org/infocenter/faqs/3rd_faq_main.html
http://www.fd3s.net/buying.html
http://www.rx7.org/Robinette/buyaused.htm
http://www.epinions.com/content_92709097092
C
Check Engine Light on non-US models:
https://www.rx7club.com/3rd-gen-archives-73/there-any-chance-read-ecu-codes-without-ecl-238994/
Clutch, how to release throwout bearing:
http://www.youtube.com/watch?v=uPCi4RpGQCU
Clutch Switch fix:
https://www.rx7club.com/3rd-gen-archives-73/cheap-bastard-fix-clutch-switch-495391/
Compression Test:
http://www.fd3s.net/compression_test.html
http://www.rotaryresurrection.com/3r...ion_check.html
Coolant Burping Tool/ Radiator Cap Funnel
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/radiator-cap-funnel-eliminate-air-bubbles-342309/
Coolant hose part numbers: replace all the rubber coolant hoses in your system.
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/all-coolant-hose-part-numbers-331644/
Cooling / Radiator Fan Control information:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/coolant-recall-fan-controller-schematic-location-385773/
Cooling fan modification. Lets you run your fans when you want to run them:
http://www.fd3s.net/fan_mod.html
http://rx7.voodoobox.net/howto/fanswitch/fanswitch.html
Cooling system thermoswitch replacement:
https://www.rx7club.com/3rd-gen-archives-73/fc-thermoswitch-fd-447606/
Cooling system diagram:
http://www.autosportracetech.com/RX-7/coolingsystem.htm
Cooling system info:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/big-fat-fd3s-cooling-thread-571088/
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/cooling-system-flush-info-441967/
D
Dashpot : dampens the throttle stop, for smoother on/off throttle transition, less backfiring, bucking
https://www.rx7club.com/3rd-gen-archives-73/dashpot-uim-180123/
Design / Styling Concept: Wu-Huang Chin, artist whose design was chosen for the FD3S's styling
http://cardesignerart.com/products.a...i&ttl=artistNa me&tmp=2&cID=C37&openID=C37
http://cardesignerart.com/products.a...=C7&openID=C37
Differential: Stock, Aftermarket, and Custom info:
https://www.rx7club.com/showthread.php?p=6538599
Differential Bushing Install:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/diff-bushing-install-645194/
Double Throttle removal:
http://www.rx7.org/Robinette/double_throttle.htm
Downpipe Install:
http://www.fd3s.net/downpipe_install.html
Downpipe / Exhaust Gasket issues:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/downpipe-exhaust-leak-problems-150079/
Downpipe studs & nuts: factory part numbers, also socket-head screw sizes:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/downpipe-nut-201768/
E
ECU Codes: how to pull and interpret diagnostic codes
http://www.fd3s.net/engine_codes.html
ECU diagram:
http://www.autosportracetech.com/RX-7/ecu.htm
EGR Blockoff: to simplify, reduce weight, and prevent possible catastrophic failure due to malfunctioning EGR valve (note: many japanese RX-7's don't use EGR valves, including the 99+ models):
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/egr-block-off-plate-209485/
EGR Switch Bypass: the EGR switch is the sensor that causes a check engine light ( code 16 ) when it doesn't detect the EGR valve opening and closing. This sensor tends to fail from heat, and give a false alarm even when the EGR valve is working properly.
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/question-about-12v-relay-fix-egr-345468/
https://www.rx7club.com/3rd-gen-archives-73/egr-cure-so-simple-21848/
https://www.rx7club.com/showthread.p...threadid=67757
EGR Test: ensure that the Exhaust Gas Recirculation valve is functioning properly:
http://www.fd3s.net/EGR_valve_test.html
Emissions / Smog Test Info:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/bonez-dp-cat-failed-ca-emissions-test-102707/
Emissions / Smog Info
http://www.zeroglabs.com/rx7/emissions.htm (denatured alcohol , electric air pump)
Engine Components, weighed individually (tons of photos):
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/engine-bay-weights-388361/
Engine Housing / Rotor information, weights, interchangeability:
https://www.rx7club.com/3rd-gen-archives-73/so-its-possible-use-2nd-gen-n-housings-our-fds-350315/
Engine rebuild (DIY style):
https://www.rx7club.com/3rd-gen-archives-73/work-begins-new-engine-lights-wheels-pics-506967/
Engine removal & installation:
https://www.rx7club.com/forum/showthread.php?t=152636
Exhaust system pics/sound/video clips:
https://www.rx7club.com/3rd-gen-general-discussion-322/post-pics-your-exhaust-system-buyers-guide-392922/
Old Aug 5, 2009 | 10:44 PM
serbRX7's Avatar
F
Factory Service Manuals (FSM):
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/94-fsms-available-download-449950/
Fan Switch Mod: run your radiator fans anytime you want, for better cooling at low speeds
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/fan-mod-pointless-i-think-not-239258/
Front Mount Intercooler Installation Guide (thanks TracyRX7)
http://flathat.woodstream.net/RX7/Docs/Greddy_FMIC.html
Fuel Filter:
Change the stock one every 15k miles, to be safe. Helps regain a little smoothness and MPG:
http://www.rx7.org/Robinette/fuel_filter_replace.htm
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/fuel-filter-replacement-upgrade-pics-272305/ more pics here
Fuel Leaks or Odor:
https://www.rx7club.com/forum/showthr...hreadid=113638
Fuel Pulsation Damper Replacement:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/fpd-fuel-pulsation-dampner-replacement-%2A-write-up-%2A-549019/
Fuel Pump Installation:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/fuel-pump-write-up-pictures-833749/
Fuel Pump Rewiring:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/new-clubrx-rewire-your-fuel-pump-easy-cheap-reliability-mod-615964/
Fuel Starvation fixes (improvements to stock tank baffling):
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/gas-tank-swap-308038/
https://www.rx7club.com/race-car-tech-103/fuel-starvation-3rd-gen-solutions-621927/
Full Exhausts (what you need to know):
https://www.rx7club.com/showthread.php?p=5699718
G
Gauge Installation info, which wires to tap for illumination:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/some-defi-standard-gauge-install-%2Afacts%2A-239260/
Gauges / Stock Water Temp Gauge Linearization:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/temp-guage-inaccuracy-252334/
Gauge Install: Oil Temp, Water Temp, Boost, DIN panel mount:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/din-panel-gauges-577232/
H
Headlight motor mod / sleepy eyes
https://www.rx7club.com/interior-exterior-audio-26/how-sleepy-headlights-3rd-gen-351136/
Helicoil How-To (repair damaged threads)
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/stripped-manifold-stud-autozone-kit-556805/
I
Intercooler theory:
http://www.bellintercoolers.com/Pages/tech.asp
Intercooler/Front mount installation guide (thanks TracyRX7):
Intercooler/Stock mount installation guide (thanks Gen2n3):
https://www.rx7club.com/showthread.ph...43#post5675443
J
Japanese '99 Rat's Nest solenoid vacuum " black box " info and photos:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/99-rats-nest-replacement-block-315993/
JDM aftermarket suppliers:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/fd3s-japan-links-729140/
M
Malloy Mazda , Ray Crowe is the parts manager, gives great prices to RX-7 owners, quick shipping:
(888) 533-3400 , (703) 490-8170 , fax: (703) 490-3864 , hmkparts@aol.com
Manual Boost controller / Greddy Profec B II install & review:
https://www.rx7club.com/3rd-gen-archives-73/profec-b-spec-ii-install-review-192249/
Manual Boost controller Installation:
https://www.rx7club.com/3rd-gen-archives-73/my-boost-control-setup-perfect-10-8-10-pattern-178136/
Midpipes and boost control:
N
Non-Sequential Turbo modification:
http://www.fd3s.net/non-sequential.html
more pics here:
http://www.nopistons.com/forums/inde...howtopic=16665
O
Odometer repair:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/just-got-done-figuring-out-how-fix-fd-odometer-599220/
Oil Cooler cleaning / reconditioning:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/oil-cooler-fixing-cleaning-pics-info-382612/
Oil Filter Recommendations: K&N , Purolator PureOne, Mobil1
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/k-n-oil-filters-342624/
Oil injectors: different designs 93 vs 94-95:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/change-oil-injector-design-327499/
Oil Pan Leak fix:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/mythbusters-time-oil-pan-motor-mounts-488739/
Oil system diagram:
http://www.autosportracetech.com/RX-7/oilsystem.htm
Oil viscosity information (very readable):
http://www.ferrarichat.com/forum/faq...=haas_articles
O2 Sensors (OEM):
www.oxygensensors.com
P
Paint Codes:
https://www.rx7club.com/forum/showthread.php?p=6757184
Parts: buy them here
www.mazdatrix.com
Parts: Japan vendors:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/possible-sticky-484400/
Poor Man's Non-Sequential Mod:
http://web.archive.org/web/200301091...i.com/id49.htm
Power Plant Frame Reinforcement:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/check-out-my-reinforced-ppf-527280/
Power Steering Pump removal: (thanks jimlab)
https://www.rx7club.com/suspension-wheels-tires-brakes-20/how-remove-replace-suspension-bushings-211372/
http://www.zeroglabs.com/rx7/psremoval.htm
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/powersteering-removal-kit-428946/
Power Steering Rack Rebuild:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/power-steering-rack-rebuild-refresh-pics-w-part-numbers-636037/
R
Rear Differential bushings how-to:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/how-diff-bushings-455522/
Rear Suspension Pillow Ball replacement, fix clunking in rear:
http://www.maxcooper.com/rx7/how-to/...lls/index.html
Recommended modifications:
https://www.rx7club.com/showthread.p...69&page=2&pp=15
Reliability Mods:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/want-buy-3rd-gen-need-reliabilty-mod-help-41513/
http://www.fd3s.net/stages.html
https://www.rx7club.com/3rd-gen-archives-73/need-questions-answered-experienced-3rd-gen-owners-27053/ << read the post by jimlab
http://www.turborx7.com/recomend.htm
Reliability mods / $1000 to spend
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/i-have-%241-000-spend-339981/
S
Sleek light kits: RE Amemiya vs. C-West vs. East Bear: (thanks nickpapagiorgio)
https://www.rx7club.com/3rd-gen-archives-73/sleek-light-kits-re-amemiya-vs-c-west-vs-east-bear-big-pics-46477/
Smog Info / Passing Emissions:
https://www.rx7club.com/showthread.php?t=102707
Spark plug photos, with mileage and analysis:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/post-your-spark-plug-photos-here-417119/
Spark Plug Replacement:
http://home.covad.net/~f2racer/plugs.../plugwires.htm
http://www.rx7.org/Robinette/sparkplug_wires.htm
Suspension bushings removal using hydraulis press: (thanks jimlab)
https://www.rx7club.com/showthread.php?t=211372
Suspension setup / mods: (according to the noted FD suspension guru Howard Coleman)
https://www.rx7club.com/suspension-wheels-tires-brakes-20/howard-colemans-fd-chassis-setup-723617/
T
Throttle Position Sensor ( TPS ) adjustment, fix idle / hesitation problems:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/fixed-my-idle-problems-backfiring-bucking-more-170731/
https://www.rx7club.com/showthread.ph...&highlight=tps
Turbocharger Overview:
http://www.autosportracetech.com/RX-...erOverview.htm
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/why-engine-so-damn-complicated-part-1-sequential-turbos-demystified-841821/
Turbocharger ID info: (FD twins vs. Cosmo twins)
https://www.rx7club.com/showthread.php?p=7669649
Turbo Rebuild w/ pics:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/questions-before-undertaking-turbo-rebuild-272685/
Turbo FAQ's, including sourxe of oil in intercooler / intake pipes:
Turbo System troubleshooting (Stock Sequential): (thanks spurvo)
http://www.autosportracetech.com/RX-7/rx7stuff.htm
http://www.autosportracetech.com/RX-...leshooting.htm
http://fd3s.net/boost_problems.html
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/how-test-your-solenoids-actuators-other-turbo-stuff-802060/
...at high altitude: (thanks LAracer)
http://www.geocities.com/laracers_vr..._problems.html
http://www.geocities.com/laracers_vr_r1/boost_plots
...with higher than stock boost:
https://www.rx7club.com/forum/showthread.php?p=5359517
V
Vacuum hose diagrams:
https://www.rx7club.com/showthread.php?p=8113663
Vacuum hose removal tips:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/infamous-vacuum-hose-job-422528/
Vacuum hose replacement how to: (thanks Rated R1)
http://rx7.voodoobox.net/howto/vachose/vacjob.html
Vacuum hose: solenoid ( rats nest ) removal, lots of photos:
http://www.face2faces.co.uk/RX7/howto/ratsnest1.htm
Vacuum hose reliabilty test (scientific experiment): Viton vs. Neoprene vs. Silicone (thanks TracyRX7)
http://www.geocities.com/MotorCity/G...5/hosetest.pdf
V8 Swap info:
https://www.rx7club.com/other-engine-conversions-non-v-8-118/
https://www.rx7club.com/showthread.php?t=135921
W
Wastegate Actuator adjustment / modification:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/interesting-wca-test-potential-boost-creep-solution-369386/
Wastegate Porting:
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/how-port-wastegate-426526/
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/wastegate-porting-observations-726267/
Water temperature gauge sender:
https://www.rx7club.com/3rd-gen-archives-73/water-temperature-sensor-how-tap-install-247152/
Wheels: (stock 'light' vs 'reinforced' version)
https://www.rx7club.com/3rd-generation-specific-1993-2002-16/difference-between-light-re-enforced-fd-wheels-538438/
Wheel Fitment:
https://www.rx7club.com/suspension-wheels-tires-brakes-20/will-these-wheels-fit-question-eliminator-3000-a-560921/
Old Aug 5, 2009 | 10:48 PM
serbRX7's Avatar
all that stuff is from FAQ thread
i think it should be renamed to --- help for newbies click here
Old Jan 23, 2010 | 06:13 PM
serbRX7's Avatar
2,133 hit and counting ..... hopefully you found what you wher looking for
if you found it some where else
posts a link on this page for others .... thanks
Old Feb 26, 2010 | 10:54 PM
RXILVER7's Avatar
Grabbin My Wankel
99 Spec Tail Light Conversion
http://www.jsott.com/rx-7/lights/index.html
Old Feb 26, 2010 | 10:55 PM
RXILVER7's Avatar
Grabbin My Wankel
EVO-R RE Sleek headlight Kit Installation
http://www.evo-r.net/RE-light/installation.htm
Old Feb 26, 2010 | 11:28 PM
Finster's Avatar
was 150kfd
It hadnt occured to me to eliminate the FPD. Thanks serb
Old Feb 27, 2010 | 08:52 AM
Sato Tatsuya's Avatar
I'm surprise this thread has not been stickied...!!
Old Feb 27, 2010 | 09:17 AM
Mahjik's Avatar
Mr. Links
Arrow
It's called:
FAQ for 3rd Gen & other useful links
https://www.rx7club.com/showthread.php?t=68640
_Tones_
May 25, 2021 05:37 AM
radiantRX-7
18
Sep 15, 2015 07:04 AM
rafgonz
Sep 7, 2015 06:36 AM
acha3
Sep 6, 2015 08:14 AM
