The Monsterbox 4 Rotor
Old Aug 31, 2016 | 11:50 AM
  #526
Monsterbox's Avatar
Mazzei Formula
Originally Posted by KNONFS
Congrats on getting the engine, that in itself is an achievement!
Did the water housing came with the engine? Does it have a provision for the water sensor?
Yes they fabb'd this according to specs for this application. There are two 1/4npt ports welded to the bottom that are not seen in picture, this will allow for the EWP feedback temp, and adaptation to the coolant temp sensor for ECU.
Thank you, yes its been a very long wait, and huge expense, many years of saving, many years of building, many years of dreaming, many other cars that have come before it that have been inspirations driving the dream to this point. This engine represents much more than just itself.
Old Aug 31, 2016 | 12:18 PM
  #527
ACR_RX-7's Avatar
Lacks Ample Funds
Originally Posted by Monsterbox
It should be considerably less pressure drop. There are 1/8npt bungs pre and post inter cooler on the manifold which will house air temp sensors to the ECU. The ECU will also use the internal MAP sensor on the post intercooler side of the engine and an external GM map sensor on the pre-intercooler side. So we will have definitive results for efficiency and pressure drop
I do not know the internal construction to that detail, but may borrow a scope and look inside.
4 channel EGT will be utilized, sensor on each exhaust runner, and the ECU allows trimming of each injector, independent for one-another so we will be able to tune according to air-flow if any of the rotors should show airflow bias due to intake anomalies.
Thanks for the reply. I'm very impressed and with that amount of sensor input, this engine should dial in very nicely.
I would suspect that the plenum with the internal cooler will have a nice laminar flow since the fins should straighten out the flow evenly.
Old Aug 31, 2016 | 02:40 PM
  #528
7-XR's Avatar
Hey, just wanted to say that you have done an amazing job to your car. I don't think very many (if any) builds can come close.
I cant wait to hear it fire up!
Old Aug 31, 2016 | 07:03 PM
  #529
Monsterbox's Avatar
Mazzei Formula
thank you!
Old Aug 31, 2016 | 08:13 PM
  #530
ZoomZoom's Avatar
SEMI-PRO
You must have lived on YouTube listening to 4 rotor engine tracks to keep the edge off while you waited.
Old Aug 31, 2016 | 09:05 PM
  #531
Monsterbox's Avatar
Mazzei Formula
You just described 90% of my life the past 9 months
Old Sep 1, 2016 | 04:11 AM
  #532
mr rxeven's Avatar
congratulations on the 4 rotor, its a dream of every rotor head, now you need to add three Doritos to your avatar.
Old Sep 1, 2016 | 09:38 AM
  #533
Hybrid G's Avatar
Battleships aren't meant to be comfortable or safe. I like battleships.
^^^^ thats a good one..... I like battleships too
Old Sep 1, 2016 | 05:46 PM
  #534
Monsterbox's Avatar
Mazzei Formula
Old Sep 1, 2016 | 07:26 PM
  #535
ACR_RX-7's Avatar
Lacks Ample Funds
The "4 Rotor" plate on the manifold is a very nice touch.
Old Sep 2, 2016 | 06:10 PM
  #536
bufferovrflo's Avatar
So badass, cant wait to see this start! Really hope that radiator can stand up to the challenge of cooling that beast
Old Sep 2, 2016 | 07:10 PM
  #537
Valkyrie's Avatar
So many injectors... Are you responsible sourcing your own fuel rail, throttle cable, wiring, and radiator hoses?
Is that a dry sump?
Old Sep 2, 2016 | 09:17 PM
  #538
ZoomZoom's Avatar
SEMI-PRO
I think we all love battleships. Maybe we should park this car in front of one for some photos when you're done.
Old Sep 3, 2016 | 02:23 PM
  #539
Monsterbox's Avatar
Mazzei Formula
Is that a dry sump?
They supplied fuel rails but yes for injectors radiator hoses wiring etc
Its a wet sump, with a dry sump pump, running together with the OEM internal pump, two pickups near center bottom of pan will lines from each side, to each pump. Both pumps combine the oil flow to the first oil cooler into one line and then it all returns to the pedestal
Old Sep 3, 2016 | 02:25 PM
  #540
Monsterbox's Avatar
Mazzei Formula
haha!
Old Sep 3, 2016 | 02:26 PM
  #541
Monsterbox's Avatar
Mazzei Formula
thank you!
Curious to find out the same. Thinking that it should cool pretty well with no intercooler/condenser piping etc blocking it
Old Sep 4, 2016 | 02:08 PM
  #542
Monsterbox's Avatar
Mazzei Formula
its blurry but will take another shot tonight
Old Sep 4, 2016 | 03:35 PM
  #543
Leeroy_25's Avatar
Is that from the man juice on your camera lens?! I know I am excited! Just recompose and try again when you have it all out of your system!
Old Sep 4, 2016 | 03:52 PM
  #544
Broke_A_Baller's Avatar
OMG a Chupacabra!
Get a new camera!!!!!!!!!!!! Or phone with better camera!!!!!!!!!!!
:p
Looking good though!
Old Sep 4, 2016 | 03:54 PM
  #545
Monsterbox's Avatar
Mazzei Formula
the tradeoff of dropping in 4 rotors in a week is a blurry pic here and there
let me just say, this is a FAT heavy girl. She doesn't like getting pushed around or dropped. Using stock FD engine hooks, stuff was bending the front hook w/ engine and trans up in there air lol. Fun stuff ! She's in though!
will get some soon thanks!
Old Sep 4, 2016 | 04:10 PM
  #546
lastphaseofthis's Avatar
My job is to blow **** up
I am super curious what sort of MPG you're going to get on the highway... lol 5-6?
i am curious how well you tame it for parking lot driving.... then again this car belong nowhere on the street, its 100% race at this point lol.
Old Sep 4, 2016 | 04:21 PM
  #547
OMG a Chupacabra!
What clutch and flywheel setup did you go with?
Old Sep 4, 2016 | 04:32 PM
  #548
Monsterbox's Avatar
Mazzei Formula
Old Sep 4, 2016 | 05:44 PM
  #549
RCCAZ 1's Avatar
Do the rotor housings have any type of custom coolant flow tubing or management, similar to what Logan Carswell did on his 4 rotor to keep water temps within 5C in his engine from front to back?
Old Sep 4, 2016 | 10:54 PM
  #550
I wish I was driving!
What kind of cheese is that?
