Old Dec 11, 2016 | 08:23 PM
  #6401
peejay's Avatar
Old [Sch|F]ool
What I did today: Brought home my 9" housing and a core GSL-SE engine to get them out of my friend's way, since he is moving next week.
Need to straighten the housing, it's badly warped. I have some ideas of how to do it, not sure how good those ideas are.
Old Dec 13, 2016 | 09:26 AM
  #6402
Sh00bs's Avatar
Doritos & Dual Sports
hello all
Im currently deployed and haven't touched my fb in 3 months :/
Last week however I did Score a clean targa band for about $425 I think it's a good price seeing as how most are skyrocketing past $500
i'll be back in January and my list goes as such of things to do on my 85 and the gf's 79 LE
85:
put T3 coilovers on
get 48ida jetted correctly
swap 4.88 rear in and do disc conversion (lines, proportional valve)
remove rear bumper
mount front oil cooler
mount and fit the tuckin 99 flares I have
79: remove stock 12a with slow leaking coolant jacket
sell keg, 12a exhaust, 36dcd's
install her new pineapple racing s4 na pport engine w/48ida
figure out if she has the early gsl rear or not, if later model rear, swap my 4.10 gears from my old rear to her's and sell her 3.9 lsd gears. if not, just sell the 4.10 rear
install my ground control front suspension on the front of her 79
holley red fuel pump and fpr for the new engine
build/buy exhaust for the pport
fix a few electrical gremlins
phew, I think I have a full plate that should keep me busy til spring
Old Dec 18, 2016 | 01:29 PM
  #6403
racerx01's Avatar
Well since its winter and my FB is not a daily driver. I am taking care of the suspension and tires which need some attention. I recently purchased car off BAT web-site before Thanksgiving; picked it up in first week of December. The chassis has 169K and factory replacement motor has 35K.
So went on a shopping spree over last two days...
Konig Rewind w/ Dunlop 195/50/15
Struts and shocks KYB G
Springs Racing Beat
After getting some tin worm taken care of and having underbody POR15/under coated, plan to have suspension and tires installed.
Hoping before spring to have RB headers, and pre-silencer installed. And rats nest removed. Anyone have Youtube video or step by step instruction on this item?
Car runs very strong, so not sure if I want to cause issues with rats nest removal.
Plan to have all this done before April.
If anyone knows of a good Rotary shop within 1.5 hours of Louisville please contact me.
Can wait to BRAP in the spring LOL. Happy holidays.
Old Dec 26, 2016 | 08:18 PM
  #6404
DreamInRotary's Avatar
Always Wanting to Learn
I finished up my Epsilon Center Lock refresh and fit the wheels with some fresh rubber.
Front setup:
16"x8"
205/50R16 BFGoodrich G-Force Sport Comp 2 A/S
Rear setup:
16"x9"
225/50R16 BFGoodrich G-Force Sport Comp 2 A/S
Old Dec 27, 2016 | 07:16 AM
  #6405
peejay's Avatar
Old [Sch|F]ool
What fan is that on that radiator on the side?
Old Dec 28, 2016 | 11:28 PM
  #6406
Frankenrex's Avatar
Looks like a Ford product. I seem to recall and Escort fan or something similar fits FBs nicely. I know the Nissan Quest/Mercury Villager fan fits well on the FCs.
Old Dec 30, 2016 | 02:43 PM
  #6407
t_g_farrell's Avatar
Waffles - hmmm good
Probably a Ford Taurus fan. They fit the 1st gen radiators.
Old Dec 31, 2016 | 08:38 AM
  #6408
rwatson5651's Avatar
79 w 13B4port
My first experience with a big two-barrel carb was a customer's '80 that turned out to have a Lake Cities and a 45 DCOE. I was shocked, the drivability was identical to my bone-stock '80.
The key thing will be if I can incorporate the A/C idle-up solenoid to the carburetor.
Originally Posted by j9fd3s
i doubt if anyone has tried it, but how hard could it be?
I did it for my 36 DCDs, I used the stock one off the nikki . Its just a matter of fabbing a bracket so the hook can hit the throttle linkage. I was able to bolt it to the Rotary Engineering throttle cable bracket and it works perfectly. I may be able to dig up a pic. Just feels a little odd to adjust your idle speed with a 14 mm wrench!
The icing on the cake was installing an adjustable vacuum switch in the AC compressor circuit so the compressor kicks off when I open the throttle all the way, I can drive with the AC on without it feeling like the AC kills my power. You never even know the AC is on!!
Here is a link to the switch I used:
http://transmissiontechnologies.com/...um-switch.aspx
You can find these for about $25.00
Old Dec 31, 2016 | 08:49 AM
  #6409
peejay's Avatar
Old [Sch|F]ool
Fan looks way too deep and large in diameter to be a Taurus fan, besides those have white shrouds. It does look like the GT500 fan but I thought it'd be too large to fit a 1st-gen radiator.
1st-gen (tall type) and 2nd-gen radiators are almost identical in size, BTW. Core ares is within 1/4" of each other.
Old Dec 31, 2016 | 10:47 AM
  #6410
Frankenrex's Avatar
No they don't.
https://www.1aauto.com/radiator-cool...hHAaArpA8P8HAQ
Could be a Fox Mustang V6 fan as well. All the '90s-up Ford fans are similar, just varying sizes of fan blades and shroud. The Taurus fan is popular for hot rods, restomods, etc. because it's cheap, flows a bucket-load of air, and is apparently a convenient size for lots of classic radiator sizes. A little Googling with the FB radiator size in mind will probably find you the right one. I have a couple of '90s Escort fans, and they are a good fit for the rad + oil cooler in my SA - they even have the radiator neck cutouts in the right places! A little too thick, though, at least with my added pulley sheave for AC. I need to change the AC bracket to move the belt back one sheave so I can remove that, and then the fan will fit fine.
My 2005 Crown Vic even has a similar fan to the one above. I can say it moves air with authority.
edit: also, they're two-speed, and some of them have the relays mounted to them, making them super-easy to install. Supposedly, some '90s Volvo fans are basically the same, as well: http://www.pirate4x4.com/forum/gener...plication.html
Old Jan 2, 2017 | 09:46 PM
  #6411
DWNUNDR's Avatar
finishing up repainting the engine from a ugly teal color and putting it back together...
painted my fc 4pots ready to figure out a bb kit for the fb
and painting the dash from brown to black finally
Old Jan 4, 2017 | 09:01 PM
  #6412
racerx01's Avatar
Smile Got my 15x7 Konig Rewinds with 195/50/15 installed
Konig Rewinds
Konig Rewinds 2
Old Jan 5, 2017 | 06:47 PM
  #6413
Qingdao's Avatar
HeyHeyHey..Its the Goose
OE tires & wheels in the passenger seat. Classic
I might end up with a set of those wheels some day. They do look sharp.
Old Jan 5, 2017 | 07:40 PM
  #6414
Frankenrex's Avatar
Oooo, pretty!
Old Jan 6, 2017 | 07:21 AM
  #6415
NISxMO's Avatar
Installed this yesterday. My drivers side seat was broken as was the slider on the rail. Picked up a set of Porsche 914 seats locally at a great price. Lightweight fiberglass. Fixed back bucket. Period Correct look. I think I like! I just hope my personally fabricated seat rail doesn't turn into a safety hazard lol. Oh! and another benefit is that it now sits lower allowing me to get my legs beneath the steering wheel.
I also found a DIY on a porsche forum to increase the size of the side bolster before recovering them for a factory look. May give that a shot soon!
Old Jan 6, 2017 | 02:24 PM
  #6416
DWNUNDR's Avatar
Slow day at work... So....
Old Jan 6, 2017 | 08:25 PM
  #6417
well today i noticed that i haven't unpacked mine from sevenstock, two years ago!
Old Jan 7, 2017 | 12:04 AM
  #6418
Frankenrex's Avatar
Nifty. Looks like there's an added bonus of being several inches thinner in the back, as well, letting longer-legged folks fit a little better. That's one of my issues - I fit, but only just. I'm going to look at Pontiac Fiero seats. A buddy has a herd of the things, and says that the seats are low to the floor and thing, to allow 6+-footers to fit in Fieros.
Old Jan 7, 2017 | 07:37 AM
  #6419
NISxMO's Avatar
I'm super long legged as well (at 6'0 to 6'1). I have mounted these pretty far back and can now fully stetch my leg when the clutch is depressed. It has definitely given me more room all around.
Old Jan 7, 2017 | 11:03 PM
  #6420
RXChevin's Avatar
Had an 81 cluster sitting on my desk for the longest time. Couldn't find any sort of aftermarket gauge faces and couldn't take the stock yellow anymore. Solution? Make them:P
Front plexi still need's a Windex and polish
Old Jan 8, 2017 | 11:00 PM
  #6421
Frankenrex's Avatar
Does the backlighting work OK? That always seems to be the tricky bit.
There was a Mercury Cougar guy who did some custom overlays for FBs quite a few years ago. I supplied the gauge clusters for him to model off of (S1, S2, and S3, since I had all three). I have one of the few SA22Cs with white gauges, though the way the lighting on the numbers had to work is funky, and they're yellowing a bit after so many years. I think nowadays, I would just cut white vinyl overlaid on colored plexi.
Old Jan 10, 2017 | 10:50 PM
  #6422
klptk's Avatar
Finished up doing a rear bumper tuck. Didn't want to ruin the shocks so I made a new inner core out of aluminum which also had the added bonus of sitting even closer to the rear. Had to completely chop up the cover but it had some cracks and I think the new look is worth it. No more rear protection but where I live 90% of bumpers are already as high as the rear glass...
Attached Thumbnails What did you do to your FB today?-imag0917%5B2%5D.jpg   What did you do to your FB today?-imag0929%5B1%5D.jpg   What did you do to your FB today?-imag0931%5B1%5D.jpg
Old Jan 15, 2017 | 12:39 PM
  #6423
Qingdao's Avatar
Injector hole solution!!!
I took some head bolts from a Honda VF750R, and I cut them down. Then welded them to a piece of plate steel. Added O-rings and we are good to go!
Attached Thumbnails What did you do to your FB today?-20170115_130225.jpg   What did you do to your FB today?-20170115_130233.jpg   What did you do to your FB today?-20170115_130252.jpg   What did you do to your FB today?-20170115_132737.jpg   What did you do to your FB today?-20170115_132923.jpg
Old Jan 21, 2017 | 11:22 AM
  #6424
usually bumper tucks look weird on these cars, but i think yours turned out really well
Old Jan 21, 2017 | 02:43 PM
  #6425
thirteenbees's Avatar
Dropped the alternator from the top to the side.
