King N00b needs some walkthroughs...
Old May 17, 2006 | 10:01 AM
Basma, Bitch!
Exclamation King N00b needs some walkthroughs...
Hey folks...
My car is kicking my ***. I've done search after search, seen a wealth of technical and useful information, even diagrams that are hand-drawn works of art. I go to my to car to look, and no such thing. When they write these things out they don't draw the viper pit that surrounds everything, and the 20+ years of God-knows what that's accumulated on everything. Not to mention what's been done by previous owners...
I've posted various topics here and there inquiring as the locations of some things under the hood...
#1: Where is my OMP? I've gotten answers such as, "Passenger side, front cover" or "follow the OMP lines" Well, the only thing I see when I look at my front cover is metal, no distinguishable part, and for the second answer, my OMP lines are melted off (I'm replacing them, which is why I need to know where the OMP is)
#2: Exactly what is the location of my engine's temp sending unit/sensor? I've been told, "Driver's side, rear iron, under the big head(that's the oil pressure sensor)"....yeah...like I know where that is...big...thing...yeah.
#3 The spigots that the OMP lines go on, I know are on the passenger side of the housings. But when I look, I see nothing of the sort. Just a big block with a metal shroud.
The problem is, is that I can't see through half of the bullshit that's underneath my hood, and since I can't rebuild one of these things with my genitalia while I'm blindfolded, I'm kind of on the low-end level of wherabouts when it comes to what's on the engine.
Rats nest removal? Please don't recommend it...I'm still trying to figure out where the hell my thermostat is....by the way....where is that??
Any help is greatly appreciated!
~Jerry
Old May 17, 2006 | 10:57 AM
vipernicus42's Avatar
Rotoholic Moderookie
Took me a while but I used the search function and serached for "temp sender" and got:
https://www.rx7club.com/showthread.p...ht=temp+sender
Which isn't the easiest thing to think of. I'll see if I can add a post to it with the words "sensor" and "gauge" in it to make it easier to find
I'll dig up pics of the rest for you later.
Jon
Old May 17, 2006 | 11:06 AM
Hades12's Avatar
Burning Oil-Grinding 3rd
Take a few pics of your engine bay and we will draw circles on where the parts should be.
What year car?
Old May 17, 2006 | 11:08 AM
Basma, Bitch!
You found the search button, but you can't read the Queen's english?
I asked nicely...I really did.
Old May 17, 2006 | 11:09 AM
Basma, Bitch!
I'm sorry, man. I don't have a camera, unfortunatley. I know that would help tremendously. I have an 82.
Old May 17, 2006 | 11:11 AM
Mazdo's Avatar
The Steamer
The MOP has a rod that connects it to the carb/throttle linkage. If you still can't find it, maybe the previous owner blocked the pump off and went to pre-mix?
The thermostat sits on top of the water pump. Just pull off your radiator hose and there it is
Old May 17, 2006 | 11:13 AM
Basma, Bitch!
No, I don't think the previous owner did that. I was good aquaintances with him, and he said it still had the OMP. And thanks for the location of the thermostat!
Old May 17, 2006 | 11:15 AM
Basma, Bitch!
Oh, Mazdo...This rod you're talking about, if I'm thinking of where I've been told the OMP goes, would this rod have to be at a 45 degree angle? Considering the carb is at the back of the engine, and the OMP is at the front...??? Forgive my stupidity
Old May 17, 2006 | 11:27 AM
Mazdo's Avatar
The Steamer
https://www.rx7club.com/showpost.php...7&postcount=26
There are some pics courtesy of vipernicus. The rod has a bend in it, but I don't think it has too severe of an angle to the carb.
Old May 17, 2006 | 11:35 AM
Basma, Bitch!
Thanks for the link, man...that clarified alot for me. Anyone want to venture question #3??? lol....btw, I'm searching the forums like crazy, hopefully I'll find it....
Old May 17, 2006 | 11:38 AM
Basma, Bitch!
Oh, and yeah...I'm ***. I'm sorry, Vipernicus...I've been up since yesterday, just got off work, and read your post wrong....sincere apologies, and thank you for the link
Old May 17, 2006 | 01:29 PM
edwin-82/rx7's Avatar
7-itis
i think your biggest problem in locating the omp is that the air pump is in the way. if you look at the front of the engine where the belts are:
one loops around the bottom pulley (out of the two belts, this is the rearmost belt), goes up to the water pump pully, and at the top loops around the alternator, then back down to the main pulley.
the second, loops around the bottom pulley, then over towards the passenger side to the air pump, then to the water pump pulley and back down.
the third (if you have ac) goes over towards the drivers side to drive the compressor.
so you want to look down past the air pump (on the second belt) to find the omp. if you stood on the passenger side and looked straight at the air pump, its almost directly behind it down near the front bottom of the engine. its going to have two nipples (heh, nipples...) pointed towards the passenger side of the engine bay, and a connection for the rod controlled by the throttle shaft on the carb. that rod also has a small 90 deg. bend in it near the top.
hope this helps, someone correct me if anything is wrong.
Old May 17, 2006 | 03:23 PM
Kentetsu's Avatar
I was all set to verbally smack you upside the head for biting the hand that was feeding you. Your apology brought you back up a bit in my opinion.
Yes, if you follow that rod down the front of the engine, it will lead you straight to the OMP. The replacement lines can be kind of expensive though. I think some people have used a substitute material to make their own, but it has to be the right stuff or it will react with the oil.
Old May 17, 2006 | 04:29 PM
aussiesmg's Avatar
Thunder from downunder
PM me if you want replacement OMP lines, I went premix, only use Synthetic 2 stroke now, burns cleaner as it was designed for use in the fuel system.
Old May 17, 2006 | 04:51 PM
Hopefully these help.
Undo the 2 bolts from pic 1, remove that elbow-pipe thing and you'll find the thermostat. Note: you should drain coolant first, or it will be a little messy.
In Pic 2 I point to my OMP. Now you didn't say which model of car you had but you said something about "bungs on the housings" which leads me to believe you have an -SE. The OMP is still on the front of the engine in exactly the same place, but if you have a GSL-SE, ignore pic #3 where I show where the OMP lines end at the carburetor.
Jon
Attached Thumbnails King N00b needs some walkthroughs...-thermostat.jpg   King N00b needs some walkthroughs...-omp.jpg   King N00b needs some walkthroughs...-omp-lines-end.jpg
Old May 17, 2006 | 08:16 PM
Basma, Bitch!
Thanks, everyone...you guys have all been great help! By the way, Vipernicus... I have an '82. It's not a GSL or an -SE. Oh, and Kentetsu...Thanks for not verbally smacking me up, aye? You guys are awesome.
Old May 17, 2006 | 08:17 PM
Basma, Bitch!
Oh, and I ordered my teflon lines from MSC...there's a tutorial about it on here...hope it works lol.....
djmickyg
Apr 14, 2007 11:38 AM
mikelthecarguy
Engine Management Forum
Sep 24, 2005 12:20 AM
LionheartC2K
41
Mar 22, 2003 04:31 PM
rob1out
Mar 2, 2002 02:24 PM
phr34k3z
Sep 16, 2001 07:51 PM
