A-spec 500R
Old Jun 12, 2006 | 07:28 AM
  #101
matty's Avatar
all we have so far is one dyno sheet.
Actually whats up with that dyno sheet? how come power drops off pretty hard in the upper rpm range. Was the engine ported?
Old Jun 12, 2006 | 09:07 AM
  #102
burnoutking999's Avatar
Mentos and Magnums
so a little less than 4k for the kit and then fuel mods and a pfc/standalone and im at 450-500hp? im just starting out on my car(stock except downpipe and cat back. i want to retain air, ps, etc and have everday drivability as my car runs GREAT. i was thinking of going BNR stage 3s and a street port. right now i have a new engine and its unported. excuse the noobness but im trying to get my plan for what i want to do for this car down and there are soooo many options. streetability and reliability are a big thing for me. im trying for the triple threat... drag road couse and everyday type setup. i have another vehicle so i can drive other cars but if i WANTED to. I dont want a track car or a trailer queen. wuld this be a good one for me?
Old Jun 12, 2006 | 09:46 AM
  #103
pwwatkins's Avatar
Supra Smasher
don't forget intercooler, radiator, midpipe, boost controller, clutch, and i am sure that there is more that i am forgetting.
Old Jun 12, 2006 | 10:12 AM
  #104
Zero R's Avatar
Just in time to die
Basic things needed are ECU, fuel, IC, Rad, After that all the other stuff that will come up as needed. But you have to have those things addressed.
-S-
Old Jun 12, 2006 | 10:25 AM
  #105
RX7JCHIII's Avatar
Originally Posted by Zero R
After thinking about it for awhile for numerous reasons (confusion being the main one) I have chosen to close out the old thread and start this fresh and new. So here is all the relavent information needed. Even if you read the old thread reread this as there have been changes made of significance.
It will be available in T4 only. Rear housing options are .82, 1.00, 1.06, 1.12 Divided. Our 500R will offer almost identical response to the 35R with a much more efficient top end. So if you were looking at a 40R this will offer roughly the same power with quicker response. If your looking for something that has more topend than a 35R but quicker response than the larger turbo's this will do it. It is more efficient across the board and especially at higher pressure ratios. Example 15lbs on a 35R 74% eff. 500R 77%.. @18lbs 35R 72% 500R 75%.. @20lbs 35R 67% 500R 75%.. @25lbs 35R is out of breath, 500R is 73%.. It will support up to 75lbs/min. at a pressure ratio of 2.75 I can even broaden this for you further if you opt for the anti surge compressor. The best part is you wont have to sacrifice response for this setup. It will be very similar to the standard 35R in response. I spent a while finding this combination and I think it will be the absolute best offering out there for those who want response and power.
Ordered my GT 500R kit friday thanks for all the help guys!!
My supporting mods are:
m2 Med Intercooler
Walbro Fuel Pump
XS Power Pack
850 primaries
1600 secondaries
RX7 Store Extreme Fuel Rail Kit
FPR
HKS BOV
Power FC - with intergrated Boost controller
(Mazda Reman)
What kind of numbers can I be looking at with this setup? Thanks again guys
Last edited by RX7JCHIII; Jun 12, 2006 at 10:28 AM. Reason: forgot to add xs power pack
Old Jun 12, 2006 | 10:34 AM
  #106
matty's Avatar
m2 Med Intercooler
Walbro Fuel Pump
XS Power Pack
850 primaries
1600 secondaries
FPR
HKS BOV
(Mazda Reman)
are u keeping your m2 med?
i am thinking about this kit vs a t-78 but was definately thinking of selling the m2 med ic for a greddy three row no matter which turbo kit i get.
Old Jun 12, 2006 | 10:35 AM
  #107
Juiceh's Avatar
Saiga-12 Power!
I do not like to give out numbers as I can never tell what "YOUR" car will do.
Now, quit pestering Sean and let him work on my car!
Old Jun 12, 2006 | 10:45 AM
  #108
RX7JCHIII's Avatar
I have the M2 Med on the car now if anything I might upgrade later down the road to the M2 Large
Old Jun 12, 2006 | 11:18 AM
  #109
Mentos and Magnums
-S-
yeah im going v mount rad/ intercooler setup and not crazy high boost so 15-17 max. exedy clutch is probly the way of that issue. i am very interested so ill chech into it. good thread!
Old Jun 12, 2006 | 10:12 PM
  #110
Lightbulb
Not sure if you will really need the greddy 3 row Matt, a 'normal' 2 row will suffice, or an ASP Race SMIC. The 3 row will just add to your boost lag. You don't plan on running 30 psi *all* the time, do ya ?
Old Jun 13, 2006 | 07:15 AM
  #111
matty's Avatar
yeah i was worried about that. i will have to see. this is why i am taking my time with this project.
Old Jun 13, 2006 | 09:45 AM
  #112
Zero R's Avatar
Just in time to die
I would somewhat agree, whenever you go to a longer core you will lose good amounts of CFM which in turn will add to a laggy feeling system. The plus side is you get cooler charge air at that expense. But if your running lower boost levels it is not needed.
-S-
Old Jun 13, 2006 | 11:04 AM
  #113
IndyFC's Avatar
Drift SE3P
so I guess it was never answered. If I drop a 13bt into my '86 GXL and then get this kit and do all the other"bolt-on" supporting mods and put a FMIC will I be able to reach 400-450 rwhp? If I was to rebuild the engine and port it could I hit 550-600 rwhp on pump gas?
Old Jun 13, 2006 | 11:35 AM
  #114
Juiceh's Avatar
Saiga-12 Power!
It was answered previously. A-spec has yet to install and dyno this on an FC yet. They are workin on mine. We'll find out how it works out when its done. Results will be posted eventually, give it time.
Old Jun 13, 2006 | 01:35 PM
  #115
Zero R's Avatar
Just in time to die
No you will not hit 550-600rwhp on a 13bt on pump gas. 450whp is do-able.
-S-
Old Jun 13, 2006 | 06:21 PM
  #116
IndyFC's Avatar
Drift SE3P
Even if it has a race port? I'm new to rotaries so I'm not sure.
Old Jun 13, 2006 | 08:15 PM
  #117
Zero R's Avatar
Just in time to die
The turbo and fuel both wont support that airflow on pump fuel. What is your power goals and use of vehicle then we can go from there.
-S-
Old Jun 13, 2006 | 08:29 PM
  #118
IndyFC's Avatar
Drift SE3P
I would like to get 500rwhp, more if I can do it on pump. Time Attack/Drift/Auto-X/Street/Drag. Thats my main uses for the car
Old Jun 13, 2006 | 08:41 PM
  #119
People have been modding these cars for many, many years. A turbo rotary that makes 450 rwhp safely and reliably on pump gas (93 octane) over a long period of time (say 20k miles) is in the vast minority. And that's 450......you will not get 475 on 93 octane, so don't waste money trying.
Old Jun 13, 2006 | 08:49 PM
  #120
Juiceh's Avatar
Saiga-12 Power!
Wasn't the 20psi 503rwhp pull with Broken09's car on 93 pump gas with water injection?
LoL What don't you use the car for? Towing and plowing snow?
Old Jun 13, 2006 | 09:04 PM
  #121
IndyFC's Avatar
Drift SE3P
Well the car is my daily driver and will get used for time attack/drifting alot. Auto-X and Drag are a every now and then thing.
Old Jun 13, 2006 | 09:06 PM
  #122
GoRacer's Avatar
Speed Mach Go Go Go
I thought the only secret sauce besides 93oct (over 91oct/pump) @ 14lbs was Broken9's MSD ignition? I don't remember reading that he had water injection. I was assuming 1 bar on 91oct would yield the same 450hp. Whether the ignition amp' is needed <15lbs, I don't know.
Old Jun 13, 2006 | 10:34 PM
  #123
Zero R's Avatar
Just in time to die
No water injection on broken09s car. And unless you've driven a 450whp RX7 I would say try that first. It is more than fast enough for 99% of everything you would need.
-S-
Old Jun 13, 2006 | 10:57 PM
  #124
Juiceh's Avatar
Saiga-12 Power!
Ahh ok, so it was it with 93 pump gas at 20psi or was it race gas? How much farther do you think it could be pushed with water\meth injection?
Old Jun 14, 2006 | 12:35 AM
  #125
GoRacer's Avatar
Speed Mach Go Go Go
Well, I have 5 gal of 100oct premium (w/ethonal) for the dyno. I can get it free but it costs money to pick it up "lol". I forgot what my max is, but I don't think my injectors (850/1300's) will handle 25lbs even if my pump (285 l/h) can.
It's easy to want more dyno queen numbers when we see how much a Supra or a Skyline has but if there was some sort of popup calculator to factor in power to weight, then we would realize we will be wetting the drivers seat allready (haha).
