Dyno Graphs
Old Jun 8, 2005 | 12:53 PM
  #76
shm21284's Avatar
Fabrineer
Arrow
Originally Posted by cewrx7r1
Not saying you did it but I don't trust your dyno shop if they can't graph your curves correctly as they should be done. There is a reason for industry standards.
Until such time, I will not accept your graph.
Horsepower is just a mathematical equation.
HP=(Torque)X(RPM)/5252
This means that on ALL torque/horsepower curves that use HORSEPOWER and FT-LBS (instead of Newton Meters), the numbers will be EQUAL. its because of math. where the graph crosses has no meaning whatsoever. The numbers ARE equal at 5252 rpm (because when you plug that into the above equation, 5252/5252 = 1, so HP=Torque).
And just because the lines physically cross at 6000 or so rpm means nothing. the scaling is different. and there is NO industry standard on scaling, but there IS an industry standard on that above equation.
Old Jul 4, 2005 | 03:30 AM
  #77
cruiser's Avatar
I dynoed again this weekend.
280rwhp/268tq@10 psi
For more boost I need ignition upgrade/amp, so I think 310rwhp will be quite reallistic at 13psi
Old Jul 6, 2005 | 07:45 AM
  #78
cruiser's Avatar
http://www.moj-album.com/slike/36539...WByA7f_4SQ.jpg
Old Jul 14, 2005 | 10:04 PM
  #79
omochi's Avatar
fd-withdrawal
Red face
25k miles on mazda reman
leaking turbos
dp/mp/cb
pfc, base map.
12psi
261.2rwhp / 227.6 tq
is this # a bit low? any comments would be helpful. thanks!
Old Jul 24, 2005 | 07:58 PM
  #80
finnicky7's Avatar
26.55 psi T04Z Monster
Fresh Banzai Racing Street port
T-70 20 psi on pump gas (very rich)
See Vb garage for mods...
I have video if anyone want to host it.
Old Jul 25, 2005 | 07:09 AM
  #81
neit_jnf's Avatar
here's mine: https://www.rx7club.com/time-slips-dyno-121/my-first-dyno-wohoo-d-444016/
315/246 @ 13.5 psi getting slightly lean at the high end
250/188 @ 8 psi solid afr
one question, how does SAE correction work?
I think the torque in my graphs is uncorrected but the hp is SAE corrected, I plotted the torque graph in excell and used hp=tq*rpm/5252 formula to get the hp graph and it was lower than what the dyno graph says.
If I go the other way and plot hp but calculate tq then I get a higher torque...
Old Jul 25, 2005 | 08:06 AM
  #82
meadespeed's Avatar
drift,grip,drag
I just saw an article at my doctors office about an FD hitting nines on street tires and 25-28 lbs a boost. I dunno know fer sure cause it was in a crazy magazine from europe.
Old Jul 27, 2005 | 09:34 PM
  #83
finnicky7's Avatar
Here a video of my last pull see above for results.
www.morningstarcomputer.net/video/dvideo1.avi
Old Aug 22, 2005 | 10:07 AM
  #84
LUPE's Avatar
Mine put down 533whp this weekend. Steve Kan tuned it.
Old Sep 12, 2005 | 06:37 PM
  #85
Bacon's Avatar
IRS 4 Life
465hp 370ftlbs @ 22psi on t04s,
Steve Kan Tuned....
see thread for other mods
https://www.rx7club.com/single-turbo-rx-7s-23/465-rwhp-%40-22psi-t04s-461991/
Old Sep 20, 2005 | 09:43 PM
  #86
tonyttt's Avatar
Originally Posted by machinis
hows 678 @26psi sound www.ispracing.com
Old Sep 20, 2005 | 09:52 PM
  #87
pianoprodigy's Avatar
Missin' my FD
Kaaaabbbboooommmm
Old Sep 22, 2005 | 08:39 AM
  #88
rob20rx7's Avatar
Injected with a Poison
516 Rwhp
Here you go guys. This is how you make power on Pump 93 octane Fuel
516RWHP
24 PSI
93 octane
http://img.photobucket.com/albums/v2...-05516RWHP.jpg
Old Sep 22, 2005 | 06:46 PM
  #89
David Hayes's Avatar
516RWHP
24 PSI
93 octane
20B? What type of turbo are you running?
Old Sep 22, 2005 | 06:50 PM
  #90
pluto's Avatar
Nah, both the torque and spool doesn't seem like 20B at the boost level.
Good job on the tune nonetheless!!
Old Sep 23, 2005 | 09:35 AM
  #91
You are correct. The torque would have kicked in at a much lower level - and should be higher I would think. Damn nice numbers though.
Old Sep 23, 2005 | 02:48 PM
  #92
rob20rx7's Avatar
this was on a 2 rotor engine with strret port low compression Scalaped rotors
Old Jan 7, 2006 | 04:46 AM
  #93
jacobcartmill's Avatar
just dont care.
how much power should a healthy FD fully nonsequential make with just a downpipe? 10psi
Old Jan 10, 2006 | 08:42 PM
  #94
Upgrayedd's Avatar
Double Dose
208.0 horsepower 180.5 torque
86,000 miles
HKS 3" dp, Hi-Power Cat-back
Old Jan 26, 2006 | 09:42 AM
  #95
Alucard-7's Avatar
I owe you herblenny
268.15 @ .64 bar
rest of the stuff in signature
apparently my signature isnt working
t04 housing, 60-1 wheel, p-trim
full exhaust
Old Feb 9, 2006 | 03:46 PM
  #96
LUPE's Avatar
603 whp/500 torque @ 27psi
Tuned by Steve Kan.
HKS T51R Kai
C16
Old Feb 14, 2006 | 01:25 AM
  #97
89t295k's Avatar
407
stock port PT67
14psi
Old Feb 17, 2006 | 08:38 PM
  #98
crxsi88vtec's Avatar
Newbie
I pull 235 on the wheel with stock turbo, strait pipe 3 inch complete exaust, stock air intake. That been pull on a dynapack at 10 psi. It is an off you think????
Old Feb 18, 2006 | 06:50 PM
  #99
21K95RX7's Avatar
no sounds about right...stock puts out 215-218 usually so you made an \"honest\" 20 hp with exhaust not bad. by honest i mean you didnt have to increase the boost to make the horsepower
Old Feb 19, 2006 | 01:38 AM
  #100
Newbie
I didn't touch anything on the car, just make an 3 inch exaust. The boost is 10 psi, the air fuel is 12 and the engine and everithing else is stock. This summer I will install an Emanage for increase the boost at 15 psi and that will be the last mod than I will do....the torque on the wheel is 220 pound flat curve between 3000 to 6000.
