The Monsterbox 4 Rotor
Old Sep 7, 2016 | 09:59 PM
  #576
t-von's Avatar
Rotor Head Extreme
^Damn!
Old Sep 8, 2016 | 07:22 AM
  #577
Monsterbox's Avatar
Mazzei Formula
Originally Posted by MattGold
Why not go all the way?
ok you inspired me to cut more!
Old Sep 8, 2016 | 07:27 AM
  #578
Monsterbox's Avatar
Mazzei Formula
Update:
Side mounted alternator fitted. Sump lines for oil system fitted. Cut the hood even wider. If you're going to cut a $1,000 hood, why not destroy it all the way so as to see the vaccuum cleaner in all its glory haha. Just need to smooth/paint the edges and then recut/buff the hood back up.
The car will not be driven very much, so a screen/mesh filter will be fitted as seen on the last car. As of now the radiator sits upright, so there's limited room for a full size filtering unit. The radiator may be re positioned at an angle at a later date to allow clearance.
Waiting on a few parts, like the 4 channel EGT bungs to weld into the manifold, intake manifold from powdercoater and a couple other odds and ends. Then it should be nearing final assembly time.
If all goes well, we hope to reveal the final and running engine on November 1, the same date as SEMA Convention, but from our own American Convention broadcasted from the storage unit.
Thanks for following.
Old Sep 8, 2016 | 07:30 AM
  #579
Valkyrie's Avatar
Gonna cover it with some mesh? Don't want to see a tiny pebble grenading your engine.
Edit: Just saw your update.
Old Sep 8, 2016 | 07:32 AM
  #580
Monsterbox's Avatar
Mazzei Formula
Most definitely
Old Sep 10, 2016 | 10:11 AM
  #581
Monsterbox's Avatar
Mazzei Formula
Old Sep 10, 2016 | 10:54 AM
  #582
Broke_A_Baller's Avatar
OMG a Chupacabra!
Progress yayy!!!
That will be one cramped bay lol.
What amperage is the alt? I've been thinking of using the gmc 240amp one.
Old Sep 10, 2016 | 01:10 PM
  #583
Monsterbox's Avatar
Mazzei Formula
Yea for sure everything is millimeters tolerance
Was told it should be around 130amps, its a re-wound new FD type alternator
Old Sep 10, 2016 | 02:12 PM
  #584
RCCAZ 1's Avatar
Originally Posted by Monsterbox
nah not too worried about it, will be using EWP which should help maintain even flow
I'd watch it very closely. Are you monitoring EGTs front to back? It will be interesting to see how your temps vary.
Old Sep 11, 2016 | 02:51 AM
  #585
Monsterbox's Avatar
Mazzei Formula
Yes will be doing that
Old Sep 11, 2016 | 11:38 AM
  #586
Skeese's Avatar
Rocket Appliances
I apologize if I missed this earlier, but who is going to be tuning this monster?
Old Sep 11, 2016 | 12:18 PM
  #587
Monsterbox's Avatar
Mazzei Formula
Hasnt been decided yet. It would be nice to have PPRE tune it when they are in the states for next Formula Drift season. Or possibly Nelson Siverio here. Need someone who understands how to tune in 4D with alpha-n and boost compensation, so that we can use TPS for load sensing in cruising, and refer to the MAP sensor for load sensing under boost only. That way the pport can be tuned more precisely, as standard map based tuning will have very low vaccuum signal.
Old Sep 11, 2016 | 05:05 PM
  #588
Monsterbox's Avatar
Mazzei Formula
Update on the weekend:
All oil lines are ran. 12an's from each pickup on the pan, to the internal oil pump and to the external pump. Oil lines to and from oil coolers to oil pedestal, turbo oil return. And all polishing on metallic parts is being wrapped up tonight.
Intake comes back from powder coating this week. Waiting on EGT bungs to arrive to weld on, so that the exhaust manifold/turbo system can be re-wrapped and permanently installed.
Fuel injectors and EWP should arrive this week. Wiring harness has been test fitted, fits pretty well, EBturbo did a tremendous job. The coil wiring is dumbfounding, can't even see the wires, love this coil setup. Everything in this engine bay will be fit cleanly/securely/neatly yet every square inch will be fully maximized. AN fittings are ordered and will utilized on all vaccum lines to ensure no leaks. Push-to-Connect fittings will be fitted on the dual 50mm wastegates and wrapped with fire sleeve to ensure protection and to make for easy removable/spring swap. We will start with 5psi springs and work up.
If additional cooling is necessary a secondary shorter radiator will be fabricated in front of this radiator and ran in series w/ 16an lines from the EWP.
The goal is to get the car running, as running is what matters, not an engine bay full of parts that will claim to run.
Once the car is running, basemapped, and tuned for low boost, the HGT precision sequential box will be ordered. If more power is desired the turbo can be easily replaced as we have clearance in the hood and from frame-rail for larger, and only requires a charge pipe from turbo to throttle body, but power is not the goal. Reliability, on low boost, with efficient inter-cooling and a fun to drive car is the goal.
Make no mistake, this is a zero hype build, no sponsors, and no big talk. No claims to be anything other than what you see.
We encourage, Less words, more action. No secrets here, all for sharing the love of rotary, to give back to those inspirations that influenced.
Pride is earned in trusting yourself, sacrificing, working with others, giving back to your community, and sweating hard hours to build your dream. If this build encourages one person to dive into their dreams our job is successful.
We're going to make america brap again.
Old Sep 11, 2016 | 08:11 PM
  #589
silverfdturbo6port's Avatar
500+hp club
Nothing short of amazing. The moral and ethics are in the right place.
Old Sep 11, 2016 | 11:42 PM
  #590
Monsterbox's Avatar
Mazzei Formula
Thank you. Your projects and advice have been great motivators, cant wait to meet up
Old Sep 12, 2016 | 07:25 AM
  #591
Looking great, keep pushing forward
Old Sep 12, 2016 | 09:01 AM
  #592
jetlude's Avatar
BadAss DoItYourselfer
Congrats on the progress.
Old Sep 12, 2016 | 09:06 AM
  #593
Valkyrie's Avatar
What are you doing for the diff, again? I get the feeling it would be completely undriveable without a pretty aggressive clutch-pack mechanical LSD.
Old Sep 12, 2016 | 10:55 AM
  #594
Monsterbox's Avatar
Mazzei Formula
This is installed
Old Sep 12, 2016 | 10:56 AM
  #595
Monsterbox's Avatar
Mazzei Formula
Thank you Jetlude
Old Sep 12, 2016 | 12:18 PM
  #596
Monsterbox's Avatar
Mazzei Formula
Old Sep 12, 2016 | 01:02 PM
  #597
Narfle's Avatar
Rx7 Wagon
Yes.
Old Sep 12, 2016 | 01:39 PM
  #598
lastphaseofthis's Avatar
My job is to blow **** up
when i get to tuning my 13b pp i plan to keep it simple and use a MAF for fueling.. and tps for timing. i'm wiling to help you tune it yourself (for free) if you decide u want togo that path. or at least roughing it in, then again i want to see it n/a lol...
Old Sep 12, 2016 | 01:48 PM
  #599
Monsterbox's Avatar
Mazzei Formula
hey thats a great idea for N/A!
Thanks for offer
Yea been reading up on this. A great guy Zebbi from NZ in here was telling me about how he tunes GTR's with ITB's on TPS as reference for all RPM points in vaccuum for fueling, using MAP sensor only for boost compensation and MAP sensor for Timing. Same should be applied for a low vaccuum engine, super large throttle body, etc
Old Sep 12, 2016 | 02:47 PM
  #600
RCCAZ 1's Avatar
Dude... you SERIOUSLY need to sell those hats!
