PD Swap MIST SEE...PICS! ( have some questions too)
Old Apr 23, 2002 | 02:02 PM
rxhevin's Avatar
PD Swap MUST SEE...PICS! ( have some questions too)
Ok, I am in the process of doing the PD and lower fuel rail removal. I have done each step while taking pictures and will post a detailed description of the process. My FC could have cought fire any day now, as the famous screw in the PD was completely backed out. Below are a series of pictures of the swap, and instructions will follow. I do have a few questions for the "experts" While I have the whole TB,Dynamic Chamer, and both fuel rails off, is there anything that I should do before I put it all back together. So far I plan to clean everything, install 550cc injectors in the secondaries, replace the lower fuel rail (of course) and maybe new vacuum lines. Should I reuse the clips that go on the fuel lines or should I get new hose clamps. Mazda used those clips that you squeeze to remove. Anyone have a preference? Well, here are the pictures, and once VERY good one of a side-by-side S4 and S5 fuel rail.
-DL
Old Apr 23, 2002 | 02:20 PM
rxhevin's Avatar
fixed broken pic links..sorry
Old Apr 23, 2002 | 02:48 PM
I wish I was driving!
Nice pics.
Anyone know how necessary the plastic air bleeds are? Is it at all beneficial to remove them, or at all detrimental?
Sean Cathcart
Old Apr 23, 2002 | 03:07 PM
rxhevin's Avatar
Thanks Sean, not sure about the air bleeds. I am considering blocking off the EGR, but I wonder if I will ever pass emissions with out the EGR (assuming I put the air pump and ACV back on). Anyone know if the EGR is absolutely necessary to pass emissions?
-DL
Old Apr 23, 2002 | 03:18 PM
You should be fine to ditch it.
After all, none of the S5 cars had one, and they all passed.
Sean Cathcart
Old Apr 23, 2002 | 04:51 PM
rxhevin's Avatar
ok, anyone have advice on the hose clamps vs. clips? Also anything else I should do while im "in there"?
Old Apr 23, 2002 | 05:09 PM
NZConvertible's Avatar
I'm a boost creep...
Re: PD Swap MUST SEE...PICS! ( have some questions too)
Good work, I’m sure lots of people will appreciate your efforts!
So far I plan to... install 550cc injectors in the secondaries...
It’s been said before, but there’s really no need to do this. The stock 460cc/min injectors flow enough fuel at 80% duty for ~250fwhp. That’s bridgeport territory! You’d also need a fuel controller with these injectors or it’ll run like a bucket of ****.
Throw those POS clips away and get decent screw clamps. Much better.
Old Apr 23, 2002 | 07:33 PM
rxhevin's Avatar
NZConvertible, Thanks for the advice. Well one of the reasons that I want to throw the 550's in the secondaries is because they were recently remanufactured by RC Engineering. The ones I removed looked kinda crappy. Will it really run poorly without a fuel controller or will it just not reach their full potential?
Old Apr 23, 2002 | 08:04 PM
Will it really run poorly without a fuel controller...?
You betcha. At full flight, you'll be pumping in about 10% more fuel than the computer thinks the engine needs. Running that rich will simply kill your top-end power. It'll cost a lot less to get your old injectors reconditioned than buy a fuel controller. Having said that, if you plan to get serious with your NA, a fuel controller will help a lot, but you still won't need 550's unless you go beyond a street port.
Old Apr 23, 2002 | 08:48 PM
rxhevin's Avatar
NZConvertible,
quote from HAILERS "I put 550's in my 87n/a secondaries, and I have no doubts that it runs a darn site faster, on top end especially. That said, John Gibson wrote and said I needed to get some type of fuel controller for them to be effective. Got me. He's been around and doing rx longer than I. I still, seat of the pants know its faster. Just have Mazdatrix dual from front to rear and a K and N. The K and N don't do much for me. Probably just me. Not sensitive enough. If you go out to my car tonite while I'm sleeping and put the 460's in the car, I guarantee that I'll know it when I drive to work tomorrow. There! My story and I'm sticking with it."
Go to post: CLICK HERE
Old Apr 23, 2002 | 09:09 PM
Re: NZConvertible,
quote from HAILERS "I put 550's in my 87n/a secondaries, and I have no doubts that it runs a darn site faster, on top end especially."
Well I can’t explain that. All I know is that under load (when the ECU is in open-loop) the ECU has no idea how much fuel is being injected. It just looks at airflow, air temp, water temp, etc and calculates a pulsewith (the length of time the injector is to be open) by looking up preset tables. It’s only logical that a bigger injector will flow more fuel than a smaller one if they’re open for the same length of time and have the same rail pressure. So if more fuel is going in than the computer has calculated is necessary for an appropriate mixture, it should be running rich. Too rich equals slower, not faster! Perhaps Hailers can shed more light, but I’ve heard a lot more people say it doesn’t work than that say it does.
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
OrangeMax
Sep 4, 2015 10:42 AM
RotaryBobby
Aug 29, 2015 10:32 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
