Pineapple Racing Premier Rotary engines and performance parts supplier
Pineapple Racing FC aluminum sump (oil pan)
Old Dec 1, 2005 | 05:15 PM
Blake's Avatar
Pineapple Racing has developed a new aluminum sump (oil pan) for 2nd gen RX-7s (86-91, FC, S4 & S5, yadda yadda).
Features:
• High quality cast aluminum with machined mating surface
• Higher capacity (exact measurement pending, but physically as large as possible without exposure below cross-member).
• Cooling fins cast into bottom
• O-ring sealing for leak-free use as well as ease of installation and removal
• Double drain holes make it easier to drain sump completely
• Thick flange contributes to engine stiffness (yes, really)
• Stainless steel windage tray to reduce oil aeration
• Vertical baffles to prevent cornering starvation
• Includes o-ring, windage tray with baffles, drain plugs, and new, longer fasteners for both the flange and the engine mounts
• Cool enough to leave on your coffee table in your living room for 6 months until you get around to installing it
We expect to get the first batch of pans back from our machinist Monday. The windage trays and baffles are being CNC laser cut tomorrow. Fasteners are on order and should be here early next week.
Retail price is a very reasonable $350 but we can do a GB price of $299 plus shipping! As a comparrision, the FD aluminum sump we co-developed with Ground-Zero Motorsports retails for $450 and isn't this nice.
Here is a picture of the FD one, for reference.
Same o-ring seal (no leaky gasket!!!) but the windage tray for the FC pan is MUCH cooler, too...stainless steel with a rotor-shaped pickup hole and our name cut into it. I'll get some picture when they are done.
Let me know if you want to do the GB on the FC pan. Haven't given much thought to the minimum buy-in, but 5 sounds good for the $299 price. More would be better, obviously.
If the GB does not take off, you can buy the pans through our new online store HERE. Also, be sure to check it our because we have a bunch of other stuff on there that may be interesting.
Blake Qualley
Pineapple Racing
Old Dec 1, 2005 | 05:30 PM
Juiceh's Avatar
Saiga-12 Power!
I'd be interested in grabbing one of these. Lookin forward to more pics already.
Old Dec 1, 2005 | 05:40 PM
The Wankler's Avatar
FKITALL
Very nice, I as well will be intersted. Time to sell some more chit on ebay!
Old Dec 1, 2005 | 05:42 PM
RX-Heven's Avatar
I'll blow it up real good
I talked to Rob yesterday and he was excited to tell me about these. I have been asking him about one since they came out with the FD version.
I am in for the group buy 100%.
Old Dec 1, 2005 | 05:45 PM
RX-Heven's Avatar
Now if they could only come out with a lower intake manifold like they have for the FD....
Old Dec 1, 2005 | 05:54 PM
Blake's Avatar
Here is a drawing of the windage tray, since I don't have any to photograph yet. The drawing was the basis for the Autocad file used for the CNC laser, so it will basically look identical.
Blake
Old Dec 1, 2005 | 06:00 PM
RX-Heven's Avatar
The nicest part no one will ever see. Well that and some aluminum flywheels
Old Dec 1, 2005 | 06:52 PM
Blake's Avatar
Sure, when it's installed, but check the last "feature" in the first post It's value as obje d'art easily rivals it's functional value under your car...perhaps you should buy two!
Blake
Old Dec 1, 2005 | 07:09 PM
RX-Heven's Avatar
I'll put it with the glossy illustration I got from you several years ago that still needs framed
So what about those LIM?
Old Dec 1, 2005 | 07:18 PM
Blake's Avatar
Well, let's see how these pans do first, eh? We have a lot of capital tied up in casting, machining, laser cutting, etc. for these pans and need some of that back before we dive into another big product.
For those who don't know what you're referring to, here is the link to our online store: http://pineappleracing.com/Merchant2...egory_Code=IND
Blake
Old Dec 1, 2005 | 08:43 PM
vipers's Avatar
IIMMM BBAAACCKKK!!
im in...lemme know when it starts and ill give you your $$$$$$$
Old Dec 2, 2005 | 12:50 AM
SmogSUX's Avatar
No money. No love.
I'm 100% in also..have money in hand.
Old Dec 2, 2005 | 12:53 AM
fc_dorifto's Avatar
I'm in and i've got the money !!!!! would you ship to Canada ????
Old Dec 2, 2005 | 01:08 AM
88t2romad's Avatar
(_8(|)
how long is this group buy open? Or is it interest depending? Id be in right now, but ive got other priorities. (Plane ticket home, presents, yadda, yadda)
Old Dec 2, 2005 | 02:38 PM
Blake's Avatar
Okay, this is looking good for a GB. I will contact Ryan and see if we can proceed. No idea on the timeframe of the GB right now...we will probably play it by ear, like with the alternator relocation brackets. I might even give more leeway to those who have bought stuff from us before, like 88t2romad. Maybe take a small deposit to sort out the serious from the pretenders, then give everyone a comfortable payment time-frame (a month? two?). Let me know what sounds good.
Blake
Old Dec 2, 2005 | 02:41 PM
Blake's Avatar
Sure, but you will obviously pay moe postage and perhaps customs fees on your end. FedEx seems better and quicker than USPS but the cost is much higher up front. One way or another, we can deal with it.
Blake
Old Dec 2, 2005 | 05:24 PM
Blake's Avatar
Went to the CNC laser cutting place today and saw the test piece. I was really worried because the guy called up and said there was a "problem" and we really needed to come down and look at it. Turned out to be a matter of moving a fastener slot 20-thou to one side. Everything else was perfect! Better than expected. I should have the run of windage trays on Monday...the same day as our pans come back from the machinist.
Blake
Old Dec 2, 2005 | 10:33 PM
88t2romad's Avatar
(_8(|)
Blake
Id definatly be willing to put down a deposit if BG goes through.
About how much closer will the pan be to the ground? My car is pretty low as is. And i justwant to make sure there wont be any problems. (road aernt the best up here in fairbanks)
Old Dec 2, 2005 | 11:21 PM
Juiceh's Avatar
Saiga-12 Power!
I'd throw down on a deposit!
Old Dec 3, 2005 | 12:13 AM
bigdv519's Avatar
IFO Forced Induction Slo
Keep me posted. I'm pretty much in since its the season of giving. I'll give it to me!!!
Old Dec 3, 2005 | 09:03 AM
NOPR's Avatar
Rotary Apprentice
I'd possibly be interested in this around janary-february, not sure how long this GB will last.
Old Dec 3, 2005 | 07:37 PM
trooper55's Avatar
Fire Fighter
Ill take one, they look awsome just wanan know when the gb is goin down
Old Dec 4, 2005 | 11:00 AM
Rotortuner's Avatar
Undercover
IM interested, add me to the list.
CJG
Old Dec 4, 2005 | 11:30 AM
fast87t2's Avatar
Elder Wankle
im deff intrested in the gb
Old Dec 4, 2005 | 02:36 PM
FCNAred's Avatar
i don't care about the group buy, how long until its READY? My pan is leaking now and i was going to reseal it this week....
