FP Rewire Necessary?
Old Aug 22, 2001 | 03:16 PM
raenner's Avatar
Question FP Rewire Necessary?
I have an 88 N/T. At WOT, my A/F gauge shows the first 2-3 bars rich. Shouldn't I be seeing full rich at WOT? I've been trying to track this down for a long time, and it's gotten a little better (used to only have 0-1 bars rich at WOT).
I've added extra grounds, new fuel filter, etc. etc. Today I checked the voltage at the fuel pump @ WOT. It was in the 11 to 12v range (w/ no electrical load except for the windshield wipers). Is that OK, or should I see at least 12v -- if not 13 or 14?
I know that because it's not a turbo, it's not a critical, but I would like to know if it'd make a difference. Thanks for all the help so far!
-Jonathan
Old Aug 22, 2001 | 11:48 PM
HAILERS's Avatar
HAILERS
Just read a Third Generation post called *A/f gauge reading?* by xswlr8nrx7. You might want to read it. It seems relevant. I put in *gauge* in the search engine on this site and it was among the first ten or so. Good luck. Hope someone answers your post soon.
Old Sep 4, 2001 | 01:24 PM
deadof_knight's Avatar
Hailers where you located ?in dfw
and next whats the fp mod for to make sure your getting a full 12v to the fuel pump ,next the turbo pump pumps more ? fuel can you swap out the turbo fuel pump with the n/a model straight out i have acces to a turbo fuel pump for lil to nothing ,oh and where did you guys get your air/fuel meters at i got moeny to spend and its killling me .....need more stuff for my car muhahaha
Old Sep 7, 2001 | 11:58 AM
HAILERS's Avatar
HAILERS
RAENNER.....There is a post that might be relevant to your situation on this site. Its about the car dying in hard cornering. I thought it was just fuel slosh but that is not the case. I put in another fuel pump from the wreck yard and it did not do it. The problem I found is the strainer on the pump. Its so fine that it clogs up and you can remove the pump from the tank and the fuel trapped inside the filter will be real slow to dribble out . I'm thinking your problem is a restricted screen on the pump. All the fuel pressure checkout will look just fine because there is no real demand for flow. I think when you are wot the screen is preventing the proper flow. What do you think? I have not yet tried to clean the strainer on my pump. Too tied up right now. By the way, during the testing I did, the fuel gauge was on the empty hash mark, probably a gallon or less. One pump would stall the car, the other pump with the same fuel level would not.
Old Sep 7, 2001 | 12:19 PM
raenner's Avatar
Thanks for the good info. I didn't even expect any more replies to this thread. Anyways, things have been really busy for the past couple weeks (school starting up) but I'll definitely have to find time to check those fuel pump issues.
Thanks again.
-Jonathan
Old Sep 23, 2001 | 07:29 AM
1.3literv8eater's Avatar
Hey i got a fuel pump out of a 90T2. Iworks good but just put in a TT Supra pump. you acn have it for 25 dollars. Email me if you need it. ifuelu@aol.com
Old Sep 25, 2001 | 02:50 AM
Scott 89t2's Avatar
SOLD THE RX-7!
89+ pump won't fit in a 86-88, different. you should not be seeing full rich. if you were you would have less power. I'm sure it's fine where it is besides you can't trust a A/F gauge anyways.
Old Dec 1, 2001 | 05:34 PM
dcamcoTII's Avatar
I've got a pump from my 87T2 if you're still in need.
Old Dec 1, 2001 | 09:21 PM
13BAce's Avatar
On a long vacation
Those A/F gauges with the bars aren't very accurate. My car always runs richer than the gauge says I'm running.
Old Dec 15, 2001 | 01:16 AM
fLyiNgOuFeR's Avatar
check this out
i was going to do this mod as soon as i had time.
http://www.1300cc.com/howto/how2/rewire.htm
after i intalled my rp fuel pump, my car was leanig out alot. it was boggin alot too. hope this helps you and me
NEWGENRX7
Jun 26, 2019 12:20 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
tidanb0utch
11
Oct 7, 2015 07:36 AM
rotor_veux
Sep 19, 2015 07:13 PM
