Dyno Graphs
Old Nov 6, 2004 | 12:42 PM
  #51
Speed of light's Avatar
Form follows function
pdiazbtc-- Who's hi flow CAT were you using to make the 299.9?
Thanks.
Old Nov 6, 2004 | 11:17 PM
  #52
sk8world's Avatar
Chasing numbers
Originally Posted by pdiaztbc
94 Touring 60,000 miles original motor
320.7 rwhp @ 1 bar
Mods:
Greddy intake
modified/polished intake manifold
Greddy standard mount intercooler
Power FC tuned by Chris at RP
850cc injectors
RP Competition fuel pump
Effini Turbos (sequential)
downpipe
midpipe (299.9 rwhp with hi performance cat @ 1bar)
Greddy EVO catback
No offense but I would have expected to see a higher number. I made 325 at 1 bar (to be honest I would have to dig up my old dyno sheet but I think it was 14psi) on my stock non sequential set up before I went single. Mods were stock motor, stock non seqential turbos, no cats, smic, hks f-con, profec b, RP fuel pump. Do not take this as a put down but I just thought the effini turbos with a tuned pfc would have made more at 1 bar..
Old Dec 1, 2004 | 04:59 PM
  #53
rob20rx7's Avatar
Injected with a Poison
Proof Is in the Paper !!
Here is the Pic. shows my Dyno Run from Friday.
492 RWHP @23Lb Boost 393 Torque
Might i add on Pump Gas 93 Octane and Alcohol Injection
http://img.photobucket.com/albums/v2...0Sheets/11.jpg
Old Dec 1, 2004 | 05:06 PM
  #54
rob20rx7's Avatar
Sorry, Try this
Old Dec 1, 2004 | 05:39 PM
  #55
cloead's Avatar
sold--no longer in debt
93 RX7
Stock (to my knowledge) motor with 75k miles
3" dp
3" catback
drilled out intake box
power fc running a basemap
12-13psi
285.7rwhp
torque reading was way off (55 on the first run, 780 on the second.. they couldnt make it calculate right)
And my afrs were in the 11 range and went to about 10.9-10.8 around redline.
Once I get my hands on a scanner I'll upload the graphs.
http://mindclarity.com/cloead/dyno.jpg
Old Jan 14, 2005 | 10:53 AM
  #56
855m0n0's Avatar
off camber
Here is mine: 497.7whp, 350.6ft/lbs
17psi, 93 octane, super conservative AFRs
Relivant Mods:
Greddy T-88 turbo kit
850/1600 injectors
Porsche fuel pump
Power FC w/commander
Ceramic Apex seals
large street port
ACT 9.5lbs flywheel
ACT clutch
Pettit Racing pully kit
4" downpipe w/external Greddy wastegate to 4" custom exhaust
HKS ignition
Pettit racing coolcharge III intercooler
engine was ballanced and blueprinted
ported and polished intake manifold
Old Jan 14, 2005 | 12:32 PM
  #57
rx7tt95's Avatar
Photo Diety
Rob, your dyno graph's hp and torque curves don't cross over at 5250 either....Any idea why?
Old Jan 14, 2005 | 08:49 PM
  #58
rob20rx7's Avatar
Alot of that depends on the software or dyno u use. Dyno Jet doesnt calculate HP from torque. they use time and Rpm to to calculate these numbers. it has been brought up on another threat so if you like read it there. i think its explained better.
https://www.rx7club.com/showthread.p...2&page=4&pp=15
Old Feb 15, 2005 | 06:58 PM
  #59
pianoprodigy's Avatar
Missin' my FD
The dyno software obviously adjusts the scale for horsepower and torque according to peak numbers. On an LS1 making 350whp and 350 wtq, the software would scale each side the same and allow HP and TQ to cross at 5252. I do agree though that it is annoying to have to read the chart differently on each side. I'm not sure why the software does that. I'm sure it's just an option that could be easily changed.
Old Mar 3, 2005 | 08:30 PM
  #60
books's Avatar
dyno run prior to single
This is a crappy pic of one dyno (15 psi) run out of a set of 7 prior to going single. Initially I was somewhat pleased, but as I was leaving I noticed all the dyno numbers were in standard and not SAE (corrected) format. I then asked the dyno operator for a few graphs with SAE data, which resulted in lower numbers. The first 6 runs were performed at 0.95 on the PFC, 15psi on the Autometer. The split was kept at 12 for the first 3 runs to determine the optimum timing maps. I then varied the split to 10 and 14 on the timing map, which performed the best on the first 3 runs. With the exception of one all runs were data logged including AFRs and EGTs. stock sequential twins, stock ports, PFC, 1300s, dp, mp, cb, intake, smic, HKS Twin Power
Old Mar 3, 2005 | 08:32 PM
  #61
books's Avatar
This is a crappy pic of one dyno (15 psi) run out of a set of 7 prior to going single. Initially I was somewhat pleased, but as I was leaving I noticed all the dyno numbers were in standard and not SAE (corrected) format. I then asked the dyno operator for a few graphs with SAE data, which resulted in lower numbers. The first 6 runs were performed at 0.95 on the PFC, 15psi on the Autometer. The split was kept at 12 for the first 3 runs to determine the optimum timing maps. I then varied the split to 10 and 14 on the timing map, which performed the best on the first 3 runs. With the exception of one, all runs were data logged including AFRs and EGTs. stock sequential twins, stock ports, PFC, 1300s, dp, mp, cb, intake, smic, HKS Twin Power
Old Apr 22, 2005 | 06:07 PM
  #62
jakethesnake$$$'s Avatar
how can you get big power like these numbers and still pass california smog
Old Apr 22, 2005 | 06:34 PM
  #63
rynberg's Avatar
*downpipe
*cat-back exhaust
*intake
*intercooler
*hi-flow cat
*bored out secondary injectors (1300cc)
*upgraded fuel pump
*mild streetported engine
*PFC with little trick to light check engine light at start-up
You should be able to make 330+ rwhp with this setup at 15-16 psi. If you want more power, you can run a midpipe and make 350+ rwhp. You'll have to swap a stock cat back in for testing.
If you get a tester that holds you on the visuals (some will ignore some visuals if you pass sniffer), you can get CARB approved intake and intercooler setup. They won't notice any of the other items. Or you can just swap back in the stock intake and IC, it doesn't take that long.
Old Apr 23, 2005 | 03:22 PM
  #64
just a question how many motors have you guy gone through building and tuning your cars
Old Apr 26, 2005 | 08:15 PM
  #65
Jonptp's Avatar
Protech Performance
Greddy T-78
Apex N1
Midpipe
PTP Fuel System
850's/1600's
Street Port
2mm 2 piece seals
PTP built motor
Power FC
HKS Twin Power
NGK 115 Plugs
Greddy Front Mount
Extrude honed intake manifold
Greddy Profec B
HKS Coilovers
Tuned by PTP (Protech Performance)
561 hp / 509 tq
Jon
Protech Performance
www.ptpmotorsports.com
512-834-8771
Old Apr 26, 2005 | 08:53 PM
  #66
rx7tt95's Avatar
Photo Diety
Dyno graph?
Old Apr 27, 2005 | 12:39 PM
  #67
Jonptp's Avatar
Sorry computer wouldn't let me log back on last night so i gave up here is the dyno.
http://store1.yimg.com/I/ptpinc_1843_56180
Jon
Old Apr 27, 2005 | 01:30 PM
  #68
Missin' my FD
Jon
At what boost was this dyno run done?
Old Apr 27, 2005 | 06:12 PM
  #69
Jonptp's Avatar
27-28 lbs
Old Apr 27, 2005 | 06:52 PM
  #70
Missin' my FD
27-28 lbs
Impressive. And that was a 3rd gear pull as well. You should see an increase when doing a 4th gear pull (at least I always do).
Old Apr 27, 2005 | 07:10 PM
  #71
Jonptp's Avatar
Thank you
well I changed the computer in the dyno about 3 months ago and cant find my other dyno graph. We changed computers because the old one was messing up so maybe it got erased or something. But the other graph had more power.
Jon
Old Apr 27, 2005 | 07:50 PM
  #72
Missin' my FD
Thank you
Jon
Jon,
Could you change the MPH scale to RPMs? I know I could figure it out, but I'm too lazy. Also, you should submit your dyno chart to Wargasm's dyno comparison site. If you haven't seen it, check it out at http://dyno.zeroglabs.com/dyno.php
Alan
Old Jun 6, 2005 | 01:24 PM
  #73
Cory Simpson's Avatar
I wanta be with the BUC!
Just got back from getting my Power-FC tuned, and it turns out by 7000 RPM's my stock injectors are hitting 99.9% injector duty (after being tuned.)
Also mods include:
Blitz FMIC
Apexi Power-FC
Apexi inake
Pettit DP
MP
Blitz Nur-spec ca-back
Spec stage II clutch
ACT X-ACT streetlight flywheel
Koyo radiator
Here is my dyno sheet: (and it was on a mustang dyno so my #'s are like 10-15% lower than other dyno's)
Old Jun 8, 2005 | 12:38 AM
  #74
your numbers seem alittle low for your mods you definatly ned bigger injectors 99.9% load holy crap
Old Jun 8, 2005 | 02:29 AM
  #75
rynberg's Avatar
No they don't....Mustang Dyno numbers....he would be putting down about 320-330 rwhp on a Dynojet, which is pretty good on the stock fuel system with a good tune.
But yes, he definitely needs upgraded fuel system (injectors and pump)!
