703rwhp on 34psi PUMP fuel Water Only injection
Old Sep 15, 2009 | 03:50 AM
rx72c's Avatar
Well after so much ******* around.
The car is now doing the right things. New port job is working brilliant.
98 octane fuel with lots of water. ill put pics of engine bay later.
Old Sep 15, 2009 | 08:27 AM
Islander's Avatar
Awesome!
Old Sep 16, 2009 | 08:32 PM
WaachBack's Avatar
Finally Knows
Looking good. What type of port job is this? How much cc's?
Old Sep 16, 2009 | 08:33 PM
darkphantom's Avatar
The king of the highway!
**** YEAH! thats what im talking about. what water injection system did you use?
Old Sep 16, 2009 | 09:16 PM
Havoc's Avatar
Well done mate
So what kit did you use, or did you make your own ?
Old Sep 16, 2009 | 09:55 PM
Viper GTSR's Avatar
Performance Veteran...
Thanks truly amazing bro! And excellent to see it was done on straight water inj**
Can you give us a quick run down on your set-up at these numbers? And isn't 98oct aus equivelent to 93oct us?
Old Sep 17, 2009 | 01:31 AM
rx72c's Avatar
It hasnt changed much since the last time.
2 jets. 1100cc jet and 500cc jet. 150psi cooling mist pump
the car simply has a mildport. Probably different to most but definitely no bridge.
factory inlet manifolds. ill put up an engine bay pic soon. I have put one before but a few things have changed since.
Old Sep 17, 2009 | 06:01 PM
rx72c's Avatar
Turbo is an off the shelf 4202 with a custom rear housing on it.
Old Sep 17, 2009 | 06:12 PM
AlexG13B's Avatar
brap brap brap
wow congrats! how were ur temps?
Old Sep 17, 2009 | 10:41 PM
Chaotic_FC's Avatar
so thats on 98 octane? I wonder how you could perform with 93 octane.
Old Sep 17, 2009 | 11:18 PM
RX7(613)'s Avatar
australia uses ron octane rating , so there 98 octane is our ( northamerica ) 93 octane .
cliffs: australia uses ron rating , northamerica uses (ron+mon)/2
so basically 98---93 etc
Old Sep 18, 2009 | 02:20 AM
rx72c's Avatar
EGTs never went over 950. I couldnt pick up any knock what so ever either.
Old Sep 18, 2009 | 02:39 AM
rotorooter93fd's Avatar
YOUR TRIANGLE NIGHTMARE
incredible! how do you like the tune? does it drive well?
Old Sep 18, 2009 | 01:38 PM
stylEmon's Avatar
FC since 99
Incredible.!
Old Sep 18, 2009 | 05:25 PM
rx72c's Avatar
On boost the tune is silky smooth. But on cruise. Lets just say Microtech and 1700cc primaries and 4 bar map sensor, you dont get a smooth drive.
In the long term the car will get a haltech platinum 2000 when funds allow it. Also then the injectors will change as well to something that atomises better at low rpm.
Old Sep 18, 2009 | 10:47 PM
WLD 07's Avatar
Wow Congratz.
Is it pre or post turbo WI ?
Old Sep 18, 2009 | 10:54 PM
Chaotic_FC's Avatar
thats amazing!
please show me how to tune my car like that!! i would love to see my pp to that limit when its finished.. probably 800rwhp
Old Sep 19, 2009 | 09:07 AM
rx72c's Avatar
Pre turbo of course. Post turbo is for idiots and theorists
Old Sep 19, 2009 | 10:01 AM
classicauto's Avatar
Crash Auto?Fix Auto.
Good ******* show.
These are the highest pump/water numbers I've seen personally! I've always loved your pre turbo setup, its inspired the one I have in the works at the moment lol
Do you know the TQ at that horsepower? TQ scaling on the graph doesn't show the peak.
Old Sep 19, 2009 | 12:06 PM
SENZA PARI's Avatar
Highest I've seen or know of as well.... Nice work you freak!
Originally Posted by classicauto
Good ******* show.
Old Sep 19, 2009 | 04:53 PM
rx72c's Avatar
Yeh i forgot to readjust the torque graph.
But on the 703 run it made roughly 730 foot pound of torque. I cant remember where exactly.
Old Sep 19, 2009 | 05:31 PM
hondahater's Avatar
spending too much money..
So tell me what the secret is to tuning a car on preturbo water injection? Congrats by the way, that is awesome!
Ps. Are you using any special atomizer to keep the mist, preturbo, nice and fine?
Old Sep 19, 2009 | 08:40 PM
rx72c's Avatar
It mists very well on its own. The only water injection i have personally seen atomise better then the coolingmist jets im using is the RICE RACING water injection kit.
And when i look back at it now. His kits are miles better then any other kit i have seen. Any customer car that comes in now gets a rice kit. Their cheap. VERY EFFECTIVE and atomise perfectly.
And as for tuning. I dont know about any secret. But from what i have learnt. Dont get greedy. Set your tuning limits before you start and dont break them. I.e very very conservative timing map and lots of fuel.
Dont tune for maximum hp. Tune for safest tune. ANd what ever hp it makes is how you make it reliable.
Also QUALITY spark plugs are a big deal. Up until i seen the greddy/trust plugs the egvs were not lasting long, and was loosing tips off the plug.
R7420 10.5 ULTIMATE PLUG.
Old Sep 20, 2009 | 07:15 AM
hondahater's Avatar
Thanks for the awesome info man! So you just tune with the same timing and same fuel curve you would a standard car off of water injection then? Also do you guys run with just max flow when the pump kicks on or do you guys vary at all? I would imagine that with pre turbo injection it's just on and off. Anyways again man thanks for the info, and again too bad you aren't in the states
edit: one more question if you don't mind answering. At what psi does your water injection turn on?
Ps. do you sell those plugs at your shop?
Old Sep 20, 2009 | 07:50 AM
hondahater's Avatar
Also I've heard Greddy rebadges NGK plugs, I was wondering if these happen to be them http://www.nolimitmotorsport.com/prod/13000150
