87 and 88 Rx7 Engine Harness the same??
Old Feb 9, 2009 | 12:06 AM
JCurry's Avatar
Shpee
Arrow 87 and 88 Rx7 Engine Harness the same??
Just like the title says...im getting a 87 TII tomorrow that needs a engine wiring harness...well i have my 88 TII harness at my house thats in great shape...can i just swap these out?
thanx
Old Feb 9, 2009 | 12:19 AM
dawicka2's Avatar
well rested,buffet o food
Aside from the resister pack for the lower impedence injectors if its an early 87, they should be the same.
john ny
Old Feb 9, 2009 | 02:36 AM
HOZZMANRX7's Avatar
Driving RX7's since 1979
john ny
Which, by my understanding means you CANNOT use the 88 harness in an 87 car because the 87 is set up for low impedance injectors so NEEDs the resistor pack. 88's are high impedance injector design.
You CAN use an 87 harness in an 88 car however if you simply cut the harness running to the resistor pack and twist all the wires together (assumes you will solder them all together and then insulate with shrinking tubing or the like).
Old Feb 9, 2009 | 12:49 PM
JCurry's Avatar
Shpee
so wat do i have to do to get the 88 harness to work in the 87?
Old Feb 9, 2009 | 12:50 PM
JCurry's Avatar
Shpee
can i just use the 88 harness and put high impedance injectors in?
Old Feb 9, 2009 | 12:54 PM
dawicka2's Avatar
You just simply locate the resister pack, remove the resisters, then recrimp all of the wires together. The fsm can be found online, or its location is in your haynes or chiltons manual. Late 87s, i have been told, do not have this pack.......so you still may be good. No big deal at all removing it, in the greater scheme of putting an engine in.
yup.... or you can put higher imp injectors in.
john ny
Icemark's Avatar
Okay, on the 87 what is the ECU? A N332 or a N333?
If it is the N333 then you can use the 88 harness as plug and play with no issues.
If the ECU is a N332, then there are minor re-wiring needed in regards to the injectors and resistor pack to use the 88 harness in it..
There were 1987 model year Turbos made with both the N332 and N333 harnesses and ECU's. The switch over happened around 1/87.
If you don't know the ECU number then the production date and last 10 digits of the VIN will tell us if you can use the 88 harness without modification.
Old Feb 9, 2009 | 01:04 PM
JCurry's Avatar
Shpee
ok so i have some more info on the car, it has a jspec engine in it now but they used the original wiring harness...wont kno wat ecu it has till tomorrow but he said it used to have a resistor box but they bypassed it. Im thinking they used the injectors that came with the jspec and not the original ones. They say it needs a new harness cause everything works but the fuel injectors wont fire....how do you tell the high I. from the low I. injectors?? cause he has like 3 sets of injectors maybe the wrong ones are in the car right now thats y its not working...
Old Feb 9, 2009 | 04:28 PM
dawicka2's Avatar
Borrow an ohm/volt meter/tester. Set that **** to U. Put one lead to each of the connections on the injector. High impedence injectors were 15 or so on my 88 if i remember correctly.
john ny
Old Feb 9, 2009 | 06:12 PM
JCurry's Avatar
Shpee
ok will do....thanx
Old Feb 9, 2009 | 09:28 PM
JCurry's Avatar
Shpee
lol wat setting is U on a multimeter??
trickster
Jul 1, 2023 04:40 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
