ATF But Oil use trick
Old Feb 6, 2007 | 10:00 PM
RX7freak08's Avatar
Wish he had a running rx7
Talking ATF But Oil use trick
I want to know what kind of oil i need to use? I know not to use atf because it ruins the oil seals.
Old Feb 6, 2007 | 10:25 PM
RX7freak08's Avatar
someone please send something and yes i have looked it up so there some people said use 2 stroke engine oil but i don't know for sure
Old Feb 6, 2007 | 10:42 PM
jdmdavey's Avatar
RE WannaBE
you can use 2 stroke oil if you are willing to bypass the omp to a resevoir of 2stroke oil..not atf tho..
it can be used in a mix of oil and atf to clean engine internals due to ATF's high amount of detergents... but that is in the case of piston engines, i dont know about it in a rotary...
heres a link to patman's DIY
https://www.rx7club.com/search.php?searchid=2926507
Dave.
Old Feb 7, 2007 | 06:53 AM
My5ABaby's Avatar
Rotaries confuse me
If you're talking about to help rebuild compression after a flood or something then just use regular motor oil.
Old Feb 7, 2007 | 07:56 AM
gxl90rx7's Avatar
destroy, rebuild, repeat
just 2 stroke oil, it will burn off easier when it starts
Old Feb 7, 2007 | 08:50 AM
Aaron Cake's Avatar
Engine, Not Motor
What are you trying to accomplish with this "trick"?
If the engine is just flooded, then motor oil/two stroke oil is fine. ATF if you can't find anything else and intend to start and drive the car immediately.
But if you are trying to clean out carbon, then search for the "water trick". Keep in mind that it is possible to do more damage then you "cure" since large chunks of carbon can fall off an jam up...
In my opinion, it is best to just leave it alone.
Old Feb 8, 2007 | 04:33 PM
RX7freak08's Avatar
Now how much do i need to put in each housing and how many times do i need to do it. One more thing do i need to take the starter out.
Old Feb 8, 2007 | 05:45 PM
dreadseb's Avatar
Just what is it that your trying to do?
Old Feb 10, 2007 | 11:12 AM
Aaron Cake's Avatar
Engine, Not Motor
What are you trying to do?
If the car is flooded, try searching for "unflooding" and checking the FAQ.
If you want to try and clean out any carbon, search for "water trick".
Otherwise you're going to need to give us a little information...
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
tiger18
Sep 3, 2015 08:27 PM
rotor_veux
Sep 3, 2015 07:10 PM
