pilot bearing and flywheel removal!!!
Old May 3, 2006 | 04:47 PM
jawillyrx-7's Avatar
has anyone else had problem getting the flywheel off and also had problems getting the pilot bearing to come out. if so please post (changing out clutch right now) p.s. i dont have a puller for the bearing if anyone know and tricks or tip please post.
Old May 3, 2006 | 04:54 PM
fcdrifter13's Avatar
Play Well
From: We're all fine here now, thank you. How are you?
A pulley puller is your friend
Old May 3, 2006 | 05:27 PM
buttsjim's Avatar
I just posted this alternate method to remove the bearing about a week ago...
https://www.rx7club.com/2nd-generation-specific-1986-1992-17/pilot-tool-533854/ (scroll down)
It works--it'll take you longer to read my write-up than it will to remove the bearing.
Old May 3, 2006 | 07:36 PM
Innovation's Avatar
Didn't read the last post but I took mine out with a chisel. Broke it in two and just dug it out. Took about twenty minutes. Getting the flywheel nut off takes two men and a boy unless you have a big impact wrench and a 2 and 1/8th socket.
Old May 3, 2006 | 11:21 PM
spot_skater's Avatar
The Cause of Death
To get the pilot bearing out shove some grease in that bitch and get the proper bearing puller needed. It shouldn't come out with too much trouble. Mine, with 145k+ on it, came out in about 5 shots.
Good luck.
Old May 3, 2006 | 11:38 PM
Wankel7's Avatar
Haven't we ALL heard this
Go to autozone and rent the puller/slide hammer. Modify the jaws on teh puller.
I had my bearing out in two blasts of the slide hammer.
James
Old May 4, 2006 | 09:04 AM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
really though
if your pilot bearing is in good shape, don't mess with it!
Make sure you align the clutch disk properly too!
To remove the flywheel (have you got the big nut off?) there are two methods.
1st method, put the big nut back on about 2-3 threads, hit with a BIG hammer around the outside (not on the friction surface!) it should come off in a few pops. You have the nut on there so it doesn't fall on your face! If you don't have a big hammer, don't waste your time with a small one. You'll just get an earache and it won't come off anyways.
So then you can use method 2:
There are two threaded holes in the flywheel, put long bolts in them and start tightening them alternatley about a turn at a time once they're snug against the rear iron. This will force the flywheel to come off also. It's probably not a bad idea to have the big nut threaded onto the flywheel for this one too.
if you DON'T have the nut off yet, its 2 1/8". A big impact gun will take it off. You should use a propane torch to heat it some first though.
Old May 4, 2006 | 10:01 AM
riverzendz's Avatar
Interruptor Illuminada
Originally Posted by Terrh
really though
Didn't you just post the other day asking about removing or replacing the pilot bearing? Didn't you trash your eccentric shaft?
Old May 4, 2006 | 10:24 AM
Sideways7's Avatar
The pilot bearing remover from advance auto works perfectly with no modifications. As for the flywheel nut, I used the racing beat "super wrench". It worked great. Once thats off, put it back on a few turns and whack ths **** out of it with a hard rubber mallet. It will take a few more whacks than with a solid hammer, but you dont have to risk damaging the flywheel. Just bang all the way around the edge of it.
Old May 4, 2006 | 10:31 AM
KNONFS's Avatar
B O R I C U A
Not in my case
Old May 4, 2006 | 10:35 AM
Aaron Cake's Avatar
Engine, Not Motor
Flywheel removal (found via searching for "flywheel removal"):
https://www.rx7club.com/forum/showthread.php?t=485098
https://www.rx7club.com/forum/showthread.php?t=483905
https://www.rx7club.com/forum/showthread.php?t=399637
https://www.rx7club.com/forum/showthread.php?t=408309
https://www.rx7club.com/forum/showthread.php?t=273219
https://www.rx7club.com/forum/showthread.php?t=244162
https://www.rx7club.com/forum/showthread.php?t=176418
https://www.rx7club.com/forum/showthread.php?t=169323
https://www.rx7club.com/forum/showthread.php?t=83807
Pilot bearing removal (found by searching for "remove pilot bearing"):
https://www.rx7club.com/forum/showthread.php?t=212003
https://www.rx7club.com/forum/showthread.php?t=153568
https://www.rx7club.com/forum/showthread.php?t=433170 <-- really good
https://www.rx7club.com/forum/showthread.php?t=505764
https://www.rx7club.com/forum/showthread.php?t=474511
https://www.rx7club.com/forum/showthread.php?t=399408
https://www.rx7club.com/forum/showthread.php?t=396586
https://www.rx7club.com/forum/showthread.php?t=272767
In the past I have often had to remove pilot bearings by grinding them out with a Dremel/die grinder and then prying out the race as they tend to self-destruct...
Old May 4, 2006 | 01:29 PM
i got it out with a 1/4 in chissle and a dremal, didnt have time or money to get a puller but thanks for the posts
Old May 4, 2006 | 01:54 PM
RotaryEvolution's Avatar
Sharp Claws
i have never had to remove a pilot with anything other than a puller.
you can rent them at Checker/Schucks/Kragen
Old May 4, 2006 | 05:12 PM
Terrh's Avatar
no, the eshaft was allready trash. I was asking what I could do to fix it.
Enzo1944
Sep 6, 2015 08:57 AM
