broken pilot bearing in eccentric
Old Feb 18, 2005 | 12:11 AM
slpin's Avatar
7th Heaven
lets say theres a complete engine in car
and the last owner tried to replace the pilot bearing
however, they broke the pilot bearing, needles out, the inner part out, but the outter ring is stuck in eccentric shaft
what do you do?
Old Feb 18, 2005 | 12:18 AM
HAILERS's Avatar
HAILERS
A small common screwdriver and a hammer. Insert the blade at the races edge and hit it. Maybe it will crumble.
Or if skilled, take a dremel motor with a small stone and grind part way thru the thickness of the race. Grind that raised edge of the race in just one place/area. Then hit that area with a small, common screwdriver. I've done one that way before...with success and no damage to the eccentric shaft. You've gotta estimate the thickness of the race and not go all the way thru.
Old Feb 18, 2005 | 12:20 AM
RotaryEvolution's Avatar
Sharp Claws
even if you do nick the e-shaft it will still hold a new pilot bearing just fine unless you go nuts and try to auger it out of there.... lol
Old Feb 18, 2005 | 12:42 AM
Project84's Avatar
Open up! Search Warrant!
Get a pilot bearing removal tool and remove the outer race as if the entire pilot bearing were there. The tool pulls on the outer race anyway, so it will remove what you have left in the hole.
ls1swap
Jun 3, 2024 03:25 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
