Pilot bearing removal, need some help.
Old Aug 6, 2003 | 12:37 PM
O 16581 72452 5's Avatar
The infamous number guy!
I've searched for this but some things are left unclear, is the pilot bearing what the flywheel nut was attached to and has the orange seal? i've removed the 6 bolts from it and need to know how to pull it using a hammer and screw driver, i've tried hamming along the seam of the outside border of the entire assembly and it will not budge. I also need to know how to remove the main(?) bearing in the front of the motor and whatever else is needed to get this motor taken apart, thanks in advance.
Old Aug 6, 2003 | 12:54 PM
SonicRaT's Avatar
Super Raterhater
The pilot bearing sits inside the eccentric shaft, you don't have to touch that big flywheel bolt, just remove the pressure plate & clutch, and tada it's inside the eccentric shaft.
Old Aug 6, 2003 | 01:15 PM
Zach McAfee's Avatar
FTD Wanna Be
Re: Pilot bearing removal, need some help.
That's the stationary gear. The pilot bearing is inside the E-shaft.
Old Aug 6, 2003 | 01:16 PM
FTD Wanna Be
You need to do some serious reading before you start taking stuff apart.
Do your HW, or it's gonna get nasty.
Old Aug 6, 2003 | 01:26 PM
Too late
Old Aug 6, 2003 | 02:02 PM
FTD Wanna Be
your crazy.
Old Aug 6, 2003 | 02:25 PM
Heh, it's the motor from my gsl-se, i'm basically doing this for the learning expirence.
Old Aug 6, 2003 | 03:46 PM
Aaron Cake's Avatar
Engine, Not Motor
You don't need to remove the main bearings to disassemble the engine. Break loose the front eccentric bolt, then remove the flywheel bolt and flywheel. Remove the front eccentric bolt, front hub and front cover. Remove the sproket from the oil pump, and slide the sprocket and chain assembly off the eccentric as well as the counterweight and all the shims and bearings. Loosen the tension bolts, then disassemble the engine from the rear to the front.
Enzo1944
Sep 6, 2015 08:57 AM
