Microtech TII Stock Base Maps
Old Aug 29, 2004 | 09:43 PM
silverrotor's Avatar
Arrow TII Stock Base Maps
I've noticed a few of us have been asking for a given map that one may have In stock format, or simular. So b'c us LT8 owners are unable to zip a map(s) and send It off - I'll just post my stock settings that were sent to me from Microtech themselves. This will help a few to cross-referance their maps, correct what oops that may arise, or even reset It when they receive there unit from another 7, for example.
This Is for a s5 TII stock 550cc FI's. Mods listed at the time of purchase (If this matters) are: big streetport, FMIC, full 3" ss Exhaust no cat, Walbro.
Idle Map
Screen 1
30" ~ 1.33
25" ~ 1.48
20" ~ 1.93
15" ~ 2.38
10" ~ 2.48
05" ~ 3.48
00" ~ 4.0
2-20psi ~ 4.95
Load Map
Screen 3
30" ~ 1.76
25" ~ 1.86
20" ~ 1.95
15" ~ 2.24
10" ~ 2.90
05" ~ 3.90
00" ~ 4.81
2psi ~ 5.62
4psi ~ 6.10
6psi ~ 7.14
8psi ~ 7.86
10psi ~ 8.48
12psi ~ ???
14psi ~ 8.71
16psi ~ 9.00
18psi ~ 9.48
20psi ~ 10.00
RPMwot Map Screen 17 &
RPMcrs Screen 18 expressed as a percentage with all values set at zero.
Pump Map
Screen 19
Pump2Start ~ 2000
Pump1Amt ~ 10
Pump1Pulse ~ 02
Pump1Trig ~ 14
Pump1Stop ~ 00
Pump1Adv ~ 05
Pump2Time ~ 10
Pump2Amt ~ 30
Pump2Trig ~ 16
Pump2Stop ~ 00
Pump2Adv ~ 05
PumpDwell ~ 3.00
PumpTimers ~ No
Pump1Sync ~ No
PumpSpare ~ 00
PumpCold ~ 00
Water Map
Screen 20
-25 ~ 0
-17 ~ 70
-9 ~ 60
-1 ~ 55
5 ~ 50
11 ~ 50
18 ~ 45
24 ~ 35
31 ~ 30
38 ~ 20
46 ~ 15
60 ~ 12
68 ~ 8
82 ~ 0
99 ~ 0
124 ~ 0
Air_t Map
Screen 21
-25 ~ 0
-17 ~ 8
-9 ~ 6
-1 ~ 5
5 ~ 4
11 ~ 3
18 ~ 3
24 ~ 0
31 ~ 0
38 ~ 0
46 ~ 0
60 ~ 0
68 ~ 0
82 ~ 0
99 ~ 0
124 ~ 0
Crank Map
Screen 22
-25 ~ 72
-17 ~ 72
-9 ~ 72
-1 ~ 67
5 ~ 62
11 ~ 57
18 ~ 50
24 ~ 41
31 ~ 31
38 ~ 26
46 ~ 20
60 ~ 15
68 ~ 5
82 ~ 0
99 ~ 0
124 ~ 0
t*rpm
Screen 23
Idle ~ 00
1000 ~ 10
1500 ~ 15
2000 ~ 20
2500 ~ 25
3000 ~ 25
3500 ~ 25
4000 ~ 25
4500 ~ 25
5000 ~ 25
5500 ~ 25
6000 ~ 25
6500 ~ 25
7000 ~ 25
7500 ~ ??
8000 ~ 25
9000 ~ 25
t*map Map
Screen 24
Idle ~ 00
25 ~ 05
20 ~ 04
15 ~ 03
10 ~ 02
05 ~ 00
00 ~ 00
2psi ~ 00
4psi ~ 00
6psi ~ 00
8psi ~ -02
10psi ~ -03
12psi ~ ???
14psi ~ -04
16psi ~ -05
18 psi ~ -06
20 psi ~ -06
t*air Screen 25
Correction value Is expressed as number of degrees you wish to advance or Retard to the Ignition curve and values Is set at zero.
t*gap
Screen 26
0500 ~ 15
1000 ~ 15
1500 ~ 15
2000 ~ 14
2500 ~ 12
3000 ~ 10
3500 ~ 10
4000 ~ 10
4500 ~ 10
5000 ~ 10
5500 ~ 10
6000 ~ 10
6500 ~ 10
7000 ~ 10
8000 ~ 10
t*Inj Map
Screen 27
0500 ~ 120
1000 ~ 150
1500 ~ 150
2000 ~ 150
2500 ~ 150
3000 ~ 150
3500 ~ 180
4000 ~ 180
4500 ~ 210
5000 ~ 210
5500 ~ 210
6000 ~ 240
6500 ~ 240
7000 ~ 270
8000 ~ 270
9000 ~ 270
t*wat Map Screen 28
Option Map
Screen 30
Af_StE ~ 10
Dwell ~ 3.00 *set at Time Base - not at Duty Cycle*
REVstg ~ 3000
MAPstg ~ 05"
%stg ~ 50
I hope this helps for the few.
Old Aug 30, 2004 | 11:39 AM
Jon Goodwin's Avatar
Hi,
Many thanks for your base settings, I am sure that there will be a load of grateful people out there.
To the guys using these settings, be aware that you will need to remove fuel from the base maps, as they are hellishly rich.
On the timming front, from 2500 on the t*rpm map, these values will need to be retarded as rpm rises.IE from 4000-8000 in the region of 12°.
Once again, thank you.
John
88 GT-R
Old Aug 30, 2004 | 12:25 PM
lowkee33's Avatar
Slo Low
I appreciate this greatly you guys have been a tremendous help!!!
Old Aug 30, 2004 | 07:30 PM
Your welcome!
No need for sceptisisim, should It arise. I read the values over and over again to confirm this hour In the making thread was correct.
I hope through this that members may start posting there values too.
Old Aug 31, 2004 | 06:10 PM
White_FC's Avatar
Thaaaank you silverrotor!!
Much appreciated!
Now, just like you say, if only we could get this to turn into a huge thread with people posting all their maps and their mods they have done so people with similar mods have a starting point before heading to a dyno.
Old Aug 31, 2004 | 11:57 PM
surfpac's Avatar
Is there an option in the software that allows us to print out the current Maps?
Old Sep 1, 2004 | 04:57 PM
lowkee33's Avatar
Slo Low
I have another question. I was going through the settings in data mode and I saw my air fuel ratio was 16 to 9. How do I adjust this to bring it down?
Old Sep 6, 2004 | 01:28 AM
I understand for the NA owners the values for the Idle Maps and I *believe* for the Load Maps are different. Please confirm If this Is true and maybe have a fellow NAer post there out-of-the-box values for these Maps.
Old Sep 6, 2004 | 05:58 AM
Dragon's Avatar
20B N/A Wide Body FC3S
I still find it hard to beleve that after over a year they still only have the Beta 1.1 software and haven't updated anything. I even contacted the owners of microtec in Ausi and told them about he software problem I discovered. When tunning in 3D every time I make a change in a 5000rpm block, when I move to the next block it skips to the other fuel map page. Then you have to go search for where you left off.. This happens on all 4 laptops I've put the program on. They basicly told me O' Really and brushed me off. I agree they should at least make a way to save a text file of the map if there not going to let you actually save the map itself to the computer your using.
Old Sep 6, 2004 | 10:38 AM
patman's Avatar
Resident Know-it-All
My car did not run on these numbers. the dwell was way off. I dont know what its preset at from microtech, but i think maybe it should be 30 rather than 3. Other than that, they were helpful, tho.
pat
Old Sep 6, 2004 | 01:01 PM
patman, I've looked at what I wrote down again and looked at my Handcontroller. Both confirm that Dwell Is set at 3.00. Besides, the Dwell feature has been factory set, and should not be be adjusted unless otherwise specified.
Old Sep 6, 2004 | 01:24 PM
patman's Avatar
haha yeah i know...well..im kinda new at this...what could i have done wrong that would make me need to change the dwell so much? my car seriously will not run at all with the dwell set at 3....but it runs great at 30.. This is the first time ive run the car with LT8 in it.
i got some idle problems too..too rich at idle...but i think my load map just needs tweaked for that one... i also had to richen your whole curve some...but i have some mods so that was expected. (I only had an hour to tune my car then i had to come back to school ~100 miles...so i got kinda ghetto with it)
pat
Old Sep 6, 2004 | 05:40 PM
White_FC's Avatar
exactly which 'dwell' setting are you changing patman, theres a couple at least IIRC.
are you chaing the one with the %sign after it?
because that would make sense.
Make sure your in the 'Opt' menu and go across to 'dwell'.
Im pretty sure thats it.
And i'm with silver rotor, I would LOVE to see someone with an N/A post their settings!!!
Because the load and idle maps will be different.
Old Sep 6, 2004 | 06:00 PM
patman's Avatar
yeah...#16 in the Options menu....just says Dwell. It wouldnt rev over 3k, and bogged until 1500 with dwell @ 3. runs great with it @30. Do I maybe have my trailing coils hooked up backwards? thats the only thing i can think of that might cause it to be way off....also IIRC the map that was on the LT when i got it(used) had dwell set at 51. so am i ok?
ps..going to the dyno asap...will throw my map+mods list up here when im done.
pat
Old Sep 6, 2004 | 07:16 PM
kabooski's Avatar
Laying Down Rotary Law
Arrow
Heres a Base 13BT Map (turbo) S4/S5
This just a base map and "not" my actual settings
Once I get my car running with the new setup, I will compare
to my tunned map
You can also notice a diffrence to silverrotors supplied map
I have it in a Excel spreadsheet for download as well
Prog #1 13Bt 1.0
Config +01 Cyl/R
Firing SEQUENTIAL
LOAD = MAP Sensor
DWELL = duty cycle
Input Trig +POS
Spark Trig +MAZ
Timing check OFF
Load
20 psi 10
18 psi 10
16 psi 9.56
14 psi 8.82
10 psi 8.38
8 psi 7.75
6 psi 6.5
4 psi 6
2 psi 5.5
00"hg 4.88
05"hg 3.88
10"hg 3
15"hg 1.82
20"hg 0.88
25"hg 1.5
30"hg 1.75
AUX
20 psi 15.95
18 psi 15.12
16 psi 15.68
14 psi 15.95
10 psi 15.95
8 psi 14.68
6 psi 12.56
4 psi 15.88
2 psi 15.88
IDLE
00"hg 4.88
05"hg 3.82
10"hg 2.25
15"hg 1.32
20"hg 1.56
25"hg 1.5
30"hg 1.56
RPMwot
500 +3%
1000 +4%
1500 +5%
2000 +5%
2500 +6%
3000 +5%
3500 +5%
4000 +3%
4500 +1%
5000 -3%
5500 -6%
6000 -5%
6500 -5%
7000 -5%
7500 -5%
8000 -4%
RPMcrs
500 -1%
1000 -2%
1500 00%
2000 1%
2500 +3%
3000 +6%
3500 +15%
4000 +15%
4500 +15%
5000 00%
5500 00%
6000 00%
6500 00%
7000 00%
7500 00%
8000 00%
T.P.S. prog mode +5%
IDLE jet +5%
off IDLE +5%
MIDrange +5%
MAIN jet +5%
limp home +5%
limp home2 +5%
Pump1 Amt +3%
Pump1pulse +6%
Pump1Trig +16
Pump1Stop 2psi
Pump2Start 2000
Pump2Amt +15%
Pump2Time +10
Pump2Trig +16
Pump2Stop 00"Hg
Pump1ADV +5
Pump2ADV +00
Pump Dwell +20
Pump Spare +00
Pump Timers NO
Pump1 Sync NO
Pump Spare +00
Water
124 C 00%
99 C 00%
82 C 00%
68 C +5%
60 C +10%
46 C +14%
38 C +21%
31 C +19%
24 C +33%
18 C +39%
11 C +45%
5 C +49%
-1 C +70%
-9 C +80%
-17 C +96%
-25 C 00%
Air_t
124 C +2%
99 C +2%
82 C +2%
68 C +2%
60 C +2%
46 C +2%
38 C +2%
31 C +2%
24 C +2%
18 C +2%
11 C -2%
5 C -2%
-1 C 00%
-9 C 00%
-17 C 00%
-25 C 00%
Crank
124 C 00%
99 C +7%
82 C -2%
68 C +5%
60 C +15%
46 C +19%
38 C +30%
31 C +40%
24 C +50%
18 C +60%
11 C +60%
5 C +70%
-1 C +75%
-9 C +80%
-17 C +96%
-25 C 00%
t rpm
500 +9
1000 +15
1500 +12
2000 +17
2500 +18
3000 +21
3500 +21
4000 +18
4500 +19
5000 +20
5500 +23
6000 +23
6500 +23
7000 +23
7500 +22
8000 +22
t map
20 psi +00
18 psi +1
16 psi +1
14 psi +6
10 psi +6
8 psi +6
6 psi +8
4 psi +10
2 psi +13
00"hg +15
05"hg +22
10"hg +15
15"hg +5
20"hg +5
25"hg +5
30"hg +5
t wat
124 C +00
99 C +1
82 C -2
68 C +00
60 C +00
46 C -1
38 C +00
31 C +00
24 C +00
18 C +00
11 C +00
5 C +00
-1 C +00
-9 C +00
-17 C +00
-25 C +00
t air
124 C +00
99 C +00
82 C +00
68 C +00
60 C +00
46 C +00
38 C +00
31 C +00
24 C +00
18 C +3
11 C -4
5 C +00
-1 C +00
-9 C +00
-17 C +00
-25 C +00
Opt MIXtrm +2%
Opt TPScal +33%
Opt TIMtrm +00
Opt Static +00
Opt RPMwot 05"Hg
Opt RPMcrs 15"Hg
Opt AF_ste +15%
Opt REVlim OFF
Opt REVcut 8000
Opt BstCUT 14psi
Opt IDLmap OFF
Opt REVstg 3000
Opt MAPstg 05"Hg
Opt %stg +50%
Opt Decel 20"Hg
Opt Dwell +20%
Aux out RPM 15820
Aux out MAP OFF
Aux out INV NO
Aux Fan ON OFF
Aux POPoff OFF
Aux Trim1 00%
Aux Trim2 00%
Aux Pwm1LO 00%
Aux Pwm1HI 00%
Aux Pwm#2 00%
Aux Pwm ON OFF
Aux Pwmrti sLOW
Log RPM LO OFF
Log HI RPM 15950
Log Load LO OFF
Log HILoad OFF
File Type: zip
Old Sep 6, 2004 | 11:08 PM
kabooski, this maybe a case from getting to bad to worse.
I don't know If Microtech Is dishing out miscellanious values ( which I doubt, but I'd like to hear from them, respectively) or one of us Is not posting correct values. I'd like If you can to post your mods at the time of purchase as they may help.
I can see almost all values differing within our maps - by a considerable margin! The first thing that I noticed to strike me as very odd Is that values for the RPMwot and the RPMcrs have an expressed percentage value greater than 0%. I mean, Microtech Insists that you get your Load Maps down first before moving on to these other Maps. Why would there be values greater than 0 In them? It's not for simplicity sake. They are (and have heard from others) to be all set at 0 for these given Maps...
Old Sep 7, 2004 | 03:29 AM
White_FC's Avatar
That CAN'T be a stock map..
look at the 'OPT MixTRIM'
it's got a value, why would they send a base map with a value in there?
Doesn't make sense to me?
Old Sep 7, 2004 | 03:50 AM
boosted1205's Avatar
10sec rx7... wanna chime in here?
Old Sep 7, 2004 | 03:34 PM
kabooski's Avatar
To clear some things up:
It may of come from a stock turbo'd? tunned s4/s5
this was a map Dale aka 10sec RX7 gave me some months ago
from a car he tunned I presume?
Maybe he can chime is as to what mods that car had if any
Old Sep 7, 2004 | 05:32 PM
You have originally entitled these Maps stock s4/s5 but now you are saying It Is perhaps from a modded one. It's obvious that these aren't stock values - which Is okay. But to post Maps, with no clue as to the origin, let alone the mods associated to It, Is going to have a member with no clue blow there Engine and turn my thread down Into a fictitious one.
Old Sep 7, 2004 | 06:14 PM
kabooski's Avatar
the load maps values are not too* off from your base
as I understand it, the fuel curve is pretty much set from the factory for a giving application
I.E rotary, DSM, WRX, VW etc
you use other functions to add or subtract fuel from said fuel curve
(why you see values instead of 0 on my posted map)
adjust the load map if you go bigger injectors or add more boost
which is not building a fuel map but making the adjustments to keep the curve free of any lean or overly rich spikes (use mixtrim is the whole map is too lean or too rich)
remember anytime some one post a map
the water/air, crank values will always differ due to climate altitude etc
(My cable is out due to the hurricane so
I can't stay online too long on the backup-dialup)
I'll post more later
Old Sep 24, 2004 | 10:31 PM
RexRyder's Avatar
anyone have a map with bigger turbo/injectors?
Old Oct 13, 2004 | 09:13 PM
surfpac's Avatar
Let me know too. I'm using the Bosch coils.
Old Oct 13, 2004 | 11:15 PM
patman's Avatar
AHA!!!!! that answers the question right there. that is why ur map didnt work for me. sweet. that means i can quit worrying about that and get on with it. thanks man.
pat
Old Oct 14, 2004 | 05:24 PM
Originally Posted by patman
ps mods, if its ok with silverrotor, can you erase all my posts about the dwell function and add in time base to his map...?
I am one of the Mods to the Microtech Forum so It's okay. Consider the revision done seeing how this Is an Important value that I overlooked to add.
