Front Eshaft Bolt Wont come off.
Old Oct 20, 2011 | 07:42 PM
rx7_FREAKKK's Avatar
They live We sleep
This is gona sound Dumb But i just spend a half of a day on this bolt(FRONT ESHAFT Bolt).. IT wont come off. i Dont have a torch so i cant heat it up. I broke a breaker bar. a 19mm Socket. and bent a socket Wrench.. I Dont get it? I put some oil on it. It wont come off. I am 260 Somthing pounds.. I put all of my weight on it.. Everything breaks before the bolt loosens.. I even got an Impact gun on it.. and still wont do Anything.. help. Im going NUTS
Old Oct 20, 2011 | 07:47 PM
john ward's Avatar
oi oi oi
Get a better impact. Is it in car or out?
Old Oct 20, 2011 | 07:51 PM
They live We sleep
Its out of the car..on the floor
Old Oct 20, 2011 | 08:00 PM
jgrewe's Avatar
GET OFF MY LAWN
Torch is probably the only way. You might try a propane plumbers torch first and get it as hot as you can, or go with a MAPP gas(yellow tank that looks like a tall propane tank) that will get hotter.
Old Oct 20, 2011 | 08:20 PM
gear_grinder's Avatar
Don't hate my V8
get a craftsmen 19mm wrench and a 2ft pipe
Old Oct 20, 2011 | 08:38 PM
They live We sleep
cant get a 19mm wrench on it... its inside the metal..
Old Oct 20, 2011 | 08:43 PM
GregW's Avatar
~!@#$%^&*()_+
You can squirt all the oil on it you want, it wont do any good. The threads are sealed. They have lock tite from the factory.
1inch breaker bar with cheater or a proper impact. If you hafta ask what a proper impact is you dont own one. Throw it in the back of a truck, go to nearest shop, flip them a 10.
Job done.
Old Oct 20, 2011 | 08:59 PM
They live We sleep
Job done.
This engine was Rebuilt already..If their is lock tight on it. then it was From the Guy that Rebuilt the engine 5 or 6 years ago
Old Oct 20, 2011 | 10:18 PM
J5sense's Avatar
i agree with bringing it to a local shop and have them but the shop air pressure on it with a nice snap-on or matco impact gun. it will come off.
Old Oct 21, 2011 | 12:14 AM
misterstyx69's Avatar
Retired Moderator, RIP
I was able to get a Truck service Truck(you know they change tires on Big rigs?) to come to the house and zip my Flywheel nut off,so maybe you can locate a shop that does tires.Take the keg and go to the shop,Zip!, and you are done.
Maybe your problem is that you are not securing the Flywheel while trying to take the Front bolt out.You can't put the force needed onto a rolling object and expect it to pop off!
Old Oct 21, 2011 | 11:15 AM
Aaron Cake's Avatar
Engine, Not Motor
You need to heat it up, period. Red loctite typically used require heat to release. Even the blue stuff holds tight and heat helps a lot.
A torch is $10 at the hardware store. Heat the bolt for about 5 minute and then use the impact on it.
Old Oct 21, 2011 | 12:09 PM
freemanrx7's Avatar
^Hold On
This worked for me! Borrow a small torch or buy one. You'll be done in 10 min. Tools make all the diffrence!
Old Oct 21, 2011 | 01:55 PM
87 t-66's Avatar
not a drifter
get a better impact.
+1
heat and a good impact is probably the only way.
Old Oct 21, 2011 | 03:17 PM
Don't hate my V8
more muscle, and how can you not get a wrench on the bold when you can get a socket on it?
Old Oct 21, 2011 | 03:21 PM
Furb's Avatar
Rotary and Engineering
loctite loses its bonding characteristics above 80 degrees celcius, so indeed.. heating is the only way to go
Old Oct 21, 2011 | 03:41 PM
Osirus9's Avatar
Jackstand Drifter
The hub covers the bolt from the sides.
I just got a breaker bar and improvised a poor man's impact gun by hitting the end of it with a mini-sledge. Just be sure the socket is all the way on before you hit it, and make sure the flywheel is braced solidly (I used a concrete step and a crow bar lol).
The breaker bar will probably fly off and try to hit you in the face when you hit it with the hammer, so... be ready lol. I did this TWICE last week and it worked for 2 engines, so it works, its just a bit ghetto.
Old Oct 21, 2011 | 04:15 PM
pistones's Avatar
man I remember the flywheel was a bitch to break loose too, ah those were the days.
Old Oct 21, 2011 | 04:54 PM
Molotovman's Avatar
Ban Peak
Did you remove the bolt locking ring?
Just wanted to make sure.
Chris Boots's Avatar
I blame the TPS
Heat then impact. Like everyone else is saying, it's probably been lock-tight'd on. Even I apply blue lock-tight to bolts like that. However my impact always takes them right off. A breaker bar honestly probably won't take it off since you can't exert a static amount of pressure without somehow locking the e-shaft down so it won't budge. Otherwise your force is also being transferred through the shaft and into what is holding the the shaft in place.
An impact gun hammer's a tremendous amount of force faster than the force can be absorbed. If I remember correctly, that bolt is only torqued to about <60ish ft.lbs so it's definitely not being held on from being too tight. Also if it's torqued down too tight you crush the copper ring behind it and then develop one hell of a nasty oil leak.
Old Oct 22, 2011 | 03:25 AM
They live We sleep
this is why.
http://i137.photobucket.com/albums/q...m/IMG_0024.jpg
http://i137.photobucket.com/albums/q...m/IMG_0025.jpg
http://i137.photobucket.com/albums/q...m/IMG_0027.jpg
http://i137.photobucket.com/albums/q...m/IMG_0030.jpg
http://i137.photobucket.com/albums/q...m/IMG_0032.jpg
http://i137.photobucket.com/albums/q...m/IMG_0033.jpg
http://i137.photobucket.com/albums/q...m/IMG_0034.jpg
Is that right? I broke like 30 bucks worth of Tools.. How is that not muscle, Do i need to Break an arm?
Old Oct 22, 2011 | 04:13 AM
Derekcat's Avatar
Rotary Zealot!
Originally Posted by 87 t-66
+1
+1
If it was tightened down normally you should only need to heat it with propane for 10 or 15 seconds and then immediately hit it with an impact gun. Never been an issue for me.. [Once I got an impact gun anyway XD]
Old Oct 22, 2011 | 04:27 AM
nycgps's Avatar
PedoBear
You have to heat it.
when I was trying to remove mine, no matter what I did (impact, 5 feet cheater bar), it won't even move one bit. the cheater bar almost knock the engine stand off to the floor.
at the end, I have to find my propane torch, heat it up for hmm like a minute or 2, BOOM. Instant off.
Old Oct 22, 2011 | 04:30 AM
nycgps's Avatar
PedoBear
spec was about 90 ft lbs. but factory (if it's still factory) probably torque it to like 1000 lbs.
Locktite Red is nutz, even blue is nutz.
Old Oct 22, 2011 | 07:15 AM
Molotovman's Avatar
Ban Peak
I had to hit mine with an impact and it came out slowly. No heat though. I even forgot to take the locking ring off and round it out.
Old Oct 22, 2011 | 08:13 AM
SirCygnus's Avatar
whats going on?
heat the SOB up dude. also, get a new nut.
ps, once you get that ****** loose, be sure to keep everything that falls out of it.
FD7KiD
15
Feb 26, 2021 10:12 PM
astrum
24
Nov 15, 2017 08:44 AM
FD7KiD
Aug 17, 2015 11:50 PM
