Oil pump help!!!!!!!
Old Aug 15, 2010 | 06:21 PM
20B in the making
Exclamation Oil pump help!!!!!!!
i know that the 20B has the same oil pump as the 13B which is the worst thing that mazda has ever done. My question is do they sell an aftermarket oil pump set up or is drysump the best way to go? i know that mazdatrix sells an aftermarket front kit for a drysump but that alone is $3500 not including anything else. i was wondering if anybody has made a front kit for cheaper. I know that with the stock oil pump pushing over 7-9,000RPM the stock oil pump starts failing on a sickly built 20B pushing high boost. Any info or any answers will be greatly appreciated
Old Aug 15, 2010 | 06:41 PM
Lucrum's Avatar
Maxdatrix sells other oil pumps as well : http://www.mazdatrix.com/boil3.htm
So does Atkins : http://www.atkinsrotary.com/store/home.php?cat=649
I considered a dry sump...until I saw the cost.
Old Aug 15, 2010 | 08:32 PM
20B in the making
thank you for trying to help but it did not help mel. They are stock oil pumps Im looking for an oilpump that puts out alot greater amount of oil into the motor.
Old Aug 16, 2010 | 09:56 AM
Lucrum's Avatar
Sorry, so you're wanting a aftermarket higher flow pump that fits in the stock pumps place.
They may very well exist, but I don't recall seeing one.
You might try the sites search function, sometimes you can find what you're looking for.
Old Aug 17, 2010 | 12:41 AM
20B in the making
i guess nobody can help me here. Or if i was going to go drysump find a way to go a cheaper rout then buying the front setup from mazdatrix
Old Aug 17, 2010 | 12:56 AM
t-von's Avatar
Rotor Head Extreme
The only upgrades that I'm aware of are dry sump set-ups. I've never seen higher flowing factory style units that fit in the stock location. If your not running your engine at sustained high rpms on a regular bases, then simple oil mods will be fine if it's a street car.
Old Aug 17, 2010 | 01:35 PM
20B in the making
then this is my next question has anybody ran a drysump set up with out the mazdatrix front and had another front?
Old Aug 17, 2010 | 05:22 PM
t-von's Avatar
Rotor Head Extreme
This is a really nice 3 rotor project with lots of pics. What your looking for will be in this thread here. I too am considering purchasing this engineered front cover for my 20b later on. I don't think it's too expensive either.
https://www.rx7club.com/forum/showthread.php?t=891781
Old Aug 18, 2010 | 05:42 PM
hIGGI's Avatar
In UK FD is used Pace oil pump, question is which one should be 'correct' for 20B if building own drysump system.....
http://www.paceproducts.co.uk/public...pumps&parent=1
Snoopy FD
Dec 8, 2015 01:45 PM
rotor_veux
Aug 31, 2015 07:49 PM
