flooding problem?
Old May 14, 2009 | 11:30 AM
knewtorotory69's Avatar
IL flooding problem?
i hear that rx-7 have a flooding problem i have not picked mine up yet but wats the solution on fixing that
Old May 15, 2009 | 10:57 AM
Aaron Cake's Avatar
Engine, Not Motor
Keep the car in good tune. Don't short start it.
Old May 15, 2009 | 11:25 AM
TYko's Avatar
read and remember all of this
http://rx7.com/techarticles.html
Old May 15, 2009 | 04:22 PM
Kentetsu's Avatar
If it ever does flood, a couple of ounces of Seafoam down the carb (or in through the spark plug holes if fuel injected) will do the trick every time.
The "old way" was to use Auto Tranny Fluid (ATF). Problem is that it can be hard on the seals, and fouls your spark plugs.
Old May 15, 2009 | 05:12 PM
etx4's Avatar
etx4
-how I do it in my 12a takes about 4-5 minutes[i used to do it a lot before my carb rebuld]:
Disconnect negative battery terminal
Pull your top two spark plugs(**make sure you can put them back in right holes)
Disconnect your ignition coils- that's right- you've got two of them!! remember both ...
Turn the ignition so that all the excess feul comes out the side of chamber through the plug holes this may take about 8-12 revolutions-, you'll feel and hear air coming out**(it is highly advisable to extinguish your cigarettes,etc prior to this operation)
Re-assemble
to buld feul pressure afterwards, leave your key in the 'on' position for 20 seconds or so before cranking it.
Sometimes it requires a shot of starting fluid..or like Kentetsu said: ATF works too. haven't tried seafoam..
Old May 18, 2009 | 03:49 PM
possuman's Avatar
Flooding?
My FB has never flooded. Perhaps this is just a symptom of needing a carburetor rebuild. Mine is fresh.
Old Jun 3, 2009 | 12:23 AM
drift slut_fd's Avatar
Team HND
i got a 93 fd and never had a problem with it....turbo timers work wonder for situations like that a common way to flood is to start the car and shuting it down before it has a chance to burn the fuel......there to ways to solve a flood....1st- pull the fuel pump fuse located right next to your battery crank to car over for about 10 seconds put the fuse back in and try to start..if that doesnt work...you would have to remove your spark plugs clean them up....clear the gas out..put them in and try it again....might also need to replace spark plugs
Old Jun 3, 2009 | 08:27 AM
Handful's Avatar
International Expert
I normally dont have a problem with flooding. But when i do i drink Dos XX. No bad joke. Just make sure you let your car warm up all the way when you start it. If you dont thats when trouble happens. Mine will also flood when it sits for an extended period of time. But Im leaning towards having a leaking injector on that on.
Old Jun 3, 2009 | 10:19 AM
farberio's Avatar
NASA-MW ST4
lol
Old Jun 5, 2009 | 06:28 PM
etx4's Avatar
etx4
***AMENDMENT TO MY ABOVE POST***
Yes-- thanks for the reminder Drift ****!!!
I forgot to list the step where I'd pull my fuel pump fuse before cranking the engine over.. Enjoy your seven 'Knewtorotary'!
I just celebrated 2 yrs of ownership- got mine out of a guys pasture and it hadn't run in over 3 yrs. Crash course in rotary repair-lols
Luckily this site has fixes for just about everything- learn the Search tool- You'll probably need it./
tidanb0utch
11
Oct 7, 2015 07:36 AM
FbFuninthesun
Oct 6, 2015 08:03 AM
PinkRacer
43
Oct 1, 2015 09:13 AM
Monsterbox
Sep 11, 2015 03:29 PM
