aesa 127
Old Apr 22, 2009 | 03:58 PM
dnortherner40rx7's Avatar
MI aesa 127
I have a 1985 rx-7 1.1 carb I have been having a hard time getting it to turn over
changed plugs,dist cap, rotor button, coils, and wires, with no luck. I just dis-
covered a soleniod broken on the carb. I can not find it in my repair manual. The
only numbers on it are AESA 127. It has two vacuum lines and electrical
connection on the bottom with a rubber cap also on the bottom.
Can someone please help me figure out what the name of this part is, so
I can order another one.
Old Apr 24, 2009 | 02:42 PM
mar3's Avatar
Administrator
Still sounds like a "flood" situation to me, but let's here from the rest of the group first....myself...a little cup of tranny fluid down the carb, then have a friend stand by with Gumout carb cleaner while you crank it over...works everytime and the mosquitos are sent packing as the smoke bellows out...
Mario III
Old Apr 27, 2009 | 11:15 AM
Kentetsu's Avatar
I use Seafoam to deflood. A couple ounces down the carb then start her up.
9 times out of 10, a no start on a 7 is related to flooding. Happens to the best of us at some point.
clandestine
May 23, 2011 07:06 AM
FD3S4Life
Sep 23, 2009 09:48 AM
AznRasta
Aug 5, 2007 07:41 PM
BlackR1
Dec 20, 2002 05:29 PM
