type of oil
Old Jan 8, 2009 | 06:35 AM
mazda.rx7's Avatar
Newbie
type of oil
hi guys i have a rx 7 type r year 1999 what type of oil the rx 7 need and how does the gage of the oil thanks a lot
regards Elton
Old Jan 9, 2009 | 04:57 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
20w-50 or 10w-40
It really depends on where you liver and what temp it is outside.
Also Please look where you are creating your threads next time
Old Jan 29, 2009 | 07:51 PM
nvturb's Avatar
Mazda proposes to use mineral oil 5w-30 for rotary engines after 1998.Don't forget that 5w-30 is the oil that rx-8 use.However, your car is made in 1999 but the engine uses older technology.So if you got in mind that you live in a hot country you can use 15w-50 or 20w50.
Old Feb 10, 2009 | 10:04 PM
reier89's Avatar
yea i use this type of oil my dad happen to show me it's from lubrication engineers its designed for harley davidsons to keep them cooler since they don't use coolant it keep the engine up to 25 degrees cooler
Old Feb 11, 2009 | 08:01 PM
82mazda's Avatar
82mazda
how much is it? and where can you get it?
Old Feb 11, 2009 | 08:22 PM
Sumospeed's Avatar
So glancing through some of the other posts it looks like most people agree that synthetic oil is ok to use. The weight is just dependent on the climate of the area that you live in, just like when you use it with every other type of car.
So it looks like 20W50 is the type to use in most mild climates and is a good summer oil weight.
Whereas 5W30 is the type to use during cold times of the year up north.
I have another question all together. On average how much oil does everyone burn off, I.E. how often do you have to add a quart or so?
Old Feb 11, 2009 | 09:37 PM
dgeesaman's Avatar
I change oil in my FD every 2-3k miles and never need to add oil.
Earlier RX-7s meter in the oil faster and might need a top off now and then.
Old Feb 12, 2009 | 12:14 PM
Sumospeed's Avatar
Ok, thanks alot man.
Old Feb 12, 2009 | 06:21 PM
reier89's Avatar
i'm not sure right off hand how much it costs i can find out for you and the thing about synthetic oil is you shouldn't use it the engine is designed to burn a little bit of oil to keep the internal case lubricated and if you've seen any of the commercial how they cook syntheic in a frying pan it doesn't burn not like mineral oil
Old Feb 12, 2009 | 08:51 PM
dgeesaman's Avatar
Frying pans and engine conditions are two very different things. Low-ash synthetics burn relatively well. Early synthetics were not as good at this, so any intelligent marketer will always try to compare their stuff with the oldest crappiest synthetic oil they can get their hands on.
In any case there is always a tradeoff - synthetics have much better viscosity index and wear characteristics, but mineral oils do tend to burn a little cleaner. In an FD, the oil change interval is short enough and fuel dilution is usually extreme enough to nullify any longevity advantage with synthetics.
Dave
FD7KiD
15
Feb 26, 2021 10:12 PM
Snoopy FD
Dec 8, 2015 01:45 PM
andyvideopro
Aug 20, 2015 10:55 AM
20B Forum
Aug 18, 2015 02:46 PM
FD7KiD
Aug 17, 2015 11:50 PM
