Car Wont Stop Beeping!!!!
Old Oct 26, 2008 | 06:28 PM
camarols6's Avatar
Angry Car Wont Stop Beeping!!!!
so i deleted my a/c,p/s and rear window wiper today. Well i started it up to go get gas and the car just wont stop beeping. i mean it aint like it beeps pauses beeps its like one long continuous beeeeeeeeeeeeep. and i looked under my dash and found the owner b4 me unplugged this switch that goes to the accelerator, its black and all the way up top so the more gas you give it the more it the more it gets pressed in. whats that? i plugged it back in and it didnt help so someone plz help cuz i drive an hour to work and i will die if i have to listen to that.
Old Oct 27, 2008 | 11:38 AM
nho?'s Avatar
is it your add coolant buzzer?... those are a bitch.
Old Oct 27, 2008 | 11:40 AM
camarols6's Avatar
i dont know man im not getting any dummy lights. it beeps weather or not the cars running. like you can have the key in the on position and it still beeps.
Old Oct 27, 2008 | 11:57 AM
RotaryRocket88's Avatar
Top Down, Boost Up
Most likely the coolant or oil buzzers. Just because there's no warning light, doesn't necessarily mean it's not one of the two. Some of your warning lights might not work in the first place.
Check the oil & coolant levels, and be sure the coolant system has no air in it.
As for the switch you have under the dash on the gas pedal, there's no such switch on a stock car. The only thing connected to the gas pedal is the accelerator cable. So whatever that is, it's aftermarket.
Old Oct 27, 2008 | 01:21 PM
camarols6's Avatar
would those buzzers come on even when the car is not on?
Old Oct 27, 2008 | 01:45 PM
Top Down, Boost Up
If the key is in the "ON" position, yes. The engine does not have to be running.
You might also want to make sure the coolant level sensor is connected. It's on the top of the radiator in the center & has 1 wire coming out of it.
Old Oct 27, 2008 | 07:18 PM
aspecjakob's Avatar
the screw on the top of the radiator near the upper hose loosen that a bunch and fill coolant until its pouring out of there
Old Oct 28, 2008 | 01:47 PM
Charb's Avatar
It could also be an eletrical issue as a result of removing your rear wiper, power steering or a/c. I know when I had a faulty power steering controller, I heard the constant beeping that you are describing. The quick, and jinky way I fixed it was to disconnect the a plug to a breaker box located underneath the dash on the left side of the clutch pedal. Sorry I can't be more specific but it was a while ago, and I don't have access to the car right now.
Old Oct 28, 2008 | 04:13 PM
camarols6's Avatar
well i unplugged the fuses to the power steering and rear wiper and it worked. its amazing the little things you forget to look at i thank all of you for your help!
Old Oct 29, 2008 | 06:25 PM
lmarie's Avatar
girls can have fast cars
Question beep beep beep
how do you get rid of that? my add coolant comes on all the time but i dont need to...
Old Oct 29, 2008 | 06:45 PM
lmarie's Avatar
Question ?
you poor it into the hose?
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
smikels
Aug 18, 2015 01:26 PM
Craze8
11
Aug 14, 2015 06:11 PM
