Firing up my rebuild soon..any tips?
Old Sep 9, 2008 | 04:12 PM
MDD0101's Avatar
slowmotion
Everything is close to being togethor, just waiting for some belts and spark plug wires from mazdatrix. I received the rebuild from banzai a little over a month ago.. is there anything i should do before trying to start it up? anything that is normally llooked over, or easily missed while putting the motor back togethor?.. just a little nervous/anxious about it
Old Sep 9, 2008 | 04:57 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Pull the ECU Fues, crank for a few secs to prime the oil system. Check for leaks after.
There is going to be alot of smoke for about 5-10min
Good Luck and everything will be fine.
Post back if you have problems i will solve them.
Old Sep 9, 2008 | 05:01 PM
MDD0101's Avatar
slowmotion
how can i be sure the oil system primed?.. should i look at the omp lines to if oils in them?
Old Sep 9, 2008 | 05:03 PM
Rx7_Nut13B's Avatar
Well without a aftermarket gauge it is hard.
Normally about 10-15secs will be plenty to oil everything.
Old Sep 9, 2008 | 05:12 PM
MDD0101's Avatar
slowmotion
its the EGI fuse..not the ECU fuse that i need to pull.. correct? i thought EGI but u said ECU
Old Sep 9, 2008 | 05:42 PM
K-Tune's Avatar
FD Daily
watch the oil pressure gauge inside. you should see it start to build.
Old Sep 9, 2008 | 05:58 PM
fcdrifter13's Avatar
Play Well
From: We're all fine here now, thank you. How are you?
First you need to make sure you dizzy is out of time, and it is 11pm in a gated community, then pull the car around the whole community with a 6cly firebird and wonder why in the world it sounds like a 10ga shotgun is going off.
Ok thats more or less what not to do.
Old Sep 9, 2008 | 06:10 PM
MDD0101's Avatar
slowmotion
should i pour some oil in the lower spark plug holes also?
Old Sep 9, 2008 | 06:21 PM
katkaroto's Avatar
dewey
dont over do yourself when you finally get the motor going, i also heard its going to test low compression at first then compression will start to build up after break in miles. break in miles are about 5000-10000 miles? i dont remember but, just drive with care dont go crazy or your seals will all break out before breaking in.
Old Sep 9, 2008 | 06:35 PM
Banzai-Racing's Avatar
Rotary Specialists
Do not put any more oil in the plug holes. You will soak the plugs.
Make sure it is full of oil and coolant. The S5 is not as easy to burb as the S4 make sure you have close to two gallons in there.
Prime the fuel system at the jumper to make sure you do not have any fuel leaks and get fuel to the injectors.
Remember if you installed o-rings at the lower intake manifold to block... this seems to be something lots of people are forgetting recently.
Start the car, check for leaks, watch the temp gauge.
Old Sep 9, 2008 | 06:48 PM
MDD0101's Avatar
slowmotion
what would happen if o-rings werent installed where the lim meets the block?
Old Sep 9, 2008 | 07:26 PM
Rotary Specialists
Coolant leaks out, rapidly
Old Sep 9, 2008 | 08:26 PM
87 t-66's Avatar
not a drifter
been there, done that
Old Sep 10, 2008 | 05:18 PM
MDD0101's Avatar
slowmotion
turns out i did neglect to install those o-rings...just took everything off today and put them in, thank god it was mentioned
Old Sep 10, 2008 | 05:57 PM
ITSBOOST's Avatar
i can pee on you
thank god u were asking for any advises
Monsterbox
Sep 11, 2015 03:29 PM
windom
Sep 11, 2015 04:48 AM
