blown engine/oil seal?
Old Apr 28, 2002 | 11:42 AM
88GTU's Avatar
Here's an interesting one for you all. We were out testing at Buttonwillow on Thursday and the car died coming out of a turn. Pretty much it refused to accelerate past 5,000 rpm. Two turns later it died completely and pulled off the track. At that point there was some oil in the exhaust that caught on fire. :-)
We removed the upper intake to find that one (and only one) of the intake runners is soaked with oil, the other 3 are clean. The leading spark plug on the front rotor is covered with oil as well as the hole itself. Any one ever blow an oil seal in this manner? Or does this indicate a different problem that we havn't considered?
The data logs indicate that temps were normal when this happened and that it didnt lean out.
-Matt
'87 TII
Old Apr 28, 2002 | 02:31 PM
Aaron Cake's Avatar
Engine, Not Motor
Tubular dowl leak?
Clean the engine with degreaser, then crank over and look for oil seepage...
Old Apr 28, 2002 | 04:42 PM
88GTU's Avatar
There's is no oil on the block just in the intake runner and the spark plug hole.
-Matt
Old Apr 28, 2002 | 07:58 PM
RETed's Avatar
Was the oil pressure okay?
What kinda mileage on the engine?
-Ted
Old Apr 28, 2002 | 08:35 PM
88GTU's Avatar
Oil pressure was consistant at 70 psi above 3000 rpm. Mileage on motor was approx. 150,000. (It was our mule) :-)
We we're not really expecting this motor to last but we do want to diagnose the problem to make sure it wasnt user error...
-Matt
Old Apr 28, 2002 | 11:56 PM
RETed's Avatar
With that high mileage, the oil control o-rings are close to failure.&nbsp Pounding a 150k mile engine is asking for trouble.
-Ted
Old Apr 29, 2002 | 12:13 AM
88GTU's Avatar
Yeah, but its a hell of alot of fun. I was just wondering if the symptoms of failure reflect an oil seal problem or do they indicate something else? (ie: Can an oil seal going prevent an engine running)
-Matt
Old Apr 29, 2002 | 01:30 AM
RETed's Avatar
If it blows enough oil coat the spark plugs, it will...
-Ted
Andrew7dg
Aug 6, 2017 01:41 PM
Snook
Oct 8, 2015 10:09 PM
BLK 93
Sep 28, 2015 01:45 PM
