street ported and.........
Old Apr 24, 2002 | 10:15 PM
violator's Avatar
just wondering if i need a fuel pump? i know the stock injectors are fine but do i need a new fuel pump?
if i do will the pettit unlimited control the fuel pump? i know it cant control aftermarket injectors.
Old Apr 24, 2002 | 11:01 PM
cash money's Avatar
Old School Member
it would help if we knew what mods you have
Old Apr 25, 2002 | 01:41 AM
jspecracer7's Avatar
1JZ powered
Re: street ported and.........
...that's a pretty general question. The ECU won't control the ECU except to turn it on(and that's what you want).
Old Apr 25, 2002 | 02:04 AM
0piston's Avatar
you are only going to need a fuel pump upgrade if you are going to run higher than stock fuel pressure to cover the additional boost, maybe through RRFPR or FPR.
Old Apr 25, 2002 | 02:27 AM
violator's Avatar
i have the following mods:
-blitz nurspec cb
-apexi fmic
-stock turbos
-hks mp/dp
-street port
just bought the car with the following mods and want to make it more reliable. i know i need a ast, new rad, ecu, and a boost controller.
Old Apr 25, 2002 | 03:22 AM
rynberg's Avatar
If you limit boost to 12 psi, you will not need a fuel pump or bigger injectors. Although at only about $250 and a half hour of time, installing the Nippon Denso pump is not bad insurance. If you run over 12 psi, you should really get larger secondary injectors and the fuel pump. Also, if you get the PowerFC, you won't need a boost controller.
Old Apr 25, 2002 | 10:26 AM
Nameless's Avatar
Wow with those mods I really suggest you get an ECU upgrade.
Old Apr 25, 2002 | 11:06 AM
violator's Avatar
my question now is if i get a fuel pump, get just like a pettit be good enough to control it? or do i need a power fc?
so ur saying that even with the street port i dont need a fuel pump unless i run over 12psi?
the stock turbos prob cant take much more then 12 psi hehe so im just gonna leave it at 12psi.
Old Apr 25, 2002 | 01:04 PM
rynberg's Avatar
The ecu does NOT control the fuel pump directly. You just install the Nippon Denso and go. Even with the stock ecu. I have heard that the big Bosch and Walbro can run a little rich at idle.
Actually, I forgot about the streetport. I would just get the fuel pump, they're not that expensive. Technically, you don't need a higher flowing pump unless you upgrade to larger secondaries.
Old Apr 25, 2002 | 01:30 PM
KZ1's Avatar
KZ1
fuel pump is a waste if only runnings 12 psi of boost. it is also useless unless, as previsouly stated, you bump fuel pressure or larger injectors.
Furthermore, I wouldn't do any of that without a stand alone. upgraded ECUs are way to expensive when the day is over.
Old Apr 25, 2002 | 02:24 PM
violator's Avatar
so whats the verdic? one says yes one says no. im guessing that u dont need it but as rynberg stated it wouldnt hurt i prob might as well get it.
but i should prob get a rad first because of the FMIC the stock rad will not get enough air flow right?
Old Apr 25, 2002 | 03:27 PM
KZ1's Avatar
KZ1
it can hurt your pocket book. technicaly, practically, fundamentally. anyway you want to say it, if you don't upgrade your fuell system you don;t need a fuel pump. it is even debateable when you upgrade to say 1200cc.. that is why a fuel pressure gauge is nice, you can see when you need a new one. no internet guesing with the gauge.
Old Apr 25, 2002 | 09:45 PM
violator's Avatar
kool thanks kz1. another question while im getting some important tips;
what efficienicy are the stock turbos/injectors running at
if i use 12psi??
Old Apr 25, 2002 | 10:30 PM
lane_change's Avatar
It has begun
Mine inj. duty cycle runs anywhere from 88-98% @ WOT. Mods below.
Old Apr 26, 2002 | 12:28 PM
KZ1's Avatar
KZ1
did you get your maps tuned at the same time, because adding a fuel pump will not reduce inj. duty. maybe you tried it on two differernt days with changign temperatures. The ecu will not know the fuel pressure, thus will not make inj. duty go up to compensate for falling pressure. Now, if you took fuel out, that is differnt story.
I added my denso pump and it did jack **** as suspected, it offered nice insurance when I upgraded to 1300cc injectors though.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Ian_D
Oct 14, 2015 12:31 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
