gutting main cat what you think and other exhuast Q and A
Old Apr 13, 2002 | 02:04 PM
NashMan's Avatar
well i know in v based motor if you gut em you will gain alot of power but what about the rex
what whould the gain be and one other thing why do they use dual exhuast i still don't get it the only thing that come sot my mind is a way for back persure or style
Old Apr 13, 2002 | 04:02 PM
Aaron Cake's Avatar
Engine, Not Motor
Gutting the main cat will produce a 5HP gain (or thereabouts). Putting on a header and a cat-back will result in substantially more power.
The dual exhaust is used for style.
Old Apr 13, 2002 | 04:05 PM
blu_gxl's Avatar
ok well you don't want to gut the main cat at all if possible, especialy on the 86-88 cars that use back pressure from the main cat to open the 5th and 6th ports if you still want to gut it you will need to either go to rpm based 6 port opening or wire them open. wireing will be simpler but you will lose a good chunk of your low rpm torque, some people hate this some like it it's a matter of opinion. you can punch the pre cats for a simple gain, with minimal low end loss. the dual y setup was used for style imo. it's a good gain but would be better with a high flow aftermarket system.
james
ps next time please search i'm nice but others will not be as nice with this kind of noob question
Old Apr 13, 2002 | 04:06 PM
Aaron Cake's Avatar
Engine, Not Motor
If you have the stock cat-back, the 5th and 6th ports will still open.
Old Apr 13, 2002 | 04:07 PM
blu_gxl's Avatar
yes but not until higher rpms than normal right?
Old Apr 13, 2002 | 04:10 PM
Aaron Cake's Avatar
Engine, Not Motor
Nope. The stock mufflers are restrictive enough to easily create the 2PSI needed before 4000RPM.
Old Apr 13, 2002 | 04:16 PM
blu_gxl's Avatar
whoa!! well then i guess i was kinda wrong al though he doesn;t give any info on what set up he's running
james
Old Apr 13, 2002 | 05:38 PM
NashMan's Avatar
it all stock and sounds like kittel it not loud at all
and reson being i am kinda new at the rex i know v based off the top of my head but time to lern some thing els new
Old Apr 13, 2002 | 07:09 PM
Aaron Cake's Avatar
Engine, Not Motor
You should also head to the Canadian Forum and check out all the meets. You will probably find something local...Also, there is a BIG one coming up in Winnipeg in June. See link in my sig...
ls1swap
Jun 3, 2024 03:25 PM
Sethix
Nov 3, 2017 11:48 PM
Andrew7dg
Aug 6, 2017 01:41 PM
