going old skool got a repu:)
Old May 19, 2007 | 08:40 AM
blwfly's Avatar
kiwi from downunder..
got this off a buddy it run's its in pretty good condition couple dent few minor problems i have the headlights grill and lower valance
thought ild share my ride
is there many repu guys in this section
Attached Thumbnails going old skool got a repu:)-cimg0198.jpg   going old skool got a repu:)-img_0012.jpg   going old skool got a repu:)-img_0013.jpg   going old skool got a repu:)-img_0015.jpg   going old skool got a repu:)-img_0005.jpg
Old May 19, 2007 | 10:42 AM
BASTARD's Avatar
nice... looks like it's practically complete... can i have your center dash panel
Old May 19, 2007 | 11:43 AM
Jeff20B's Avatar
Lapping = Fapping
How is the steering?
Old May 19, 2007 | 12:16 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
noice
Old May 19, 2007 | 05:42 PM
trochoid's Avatar
Old Fart Young at Heart
Chris, I want those wheels. They are so close to what I have on the 2nd gen it's not even funny. Before you cut up the widebody you found, maybe you should see if someone will by it as a shell.
Old May 19, 2007 | 05:43 PM
blwfly's Avatar
few things need to be fixed like the headlight wireing
can i use a 1st gen speedo cable??
but scott i wont those flare's on my car !!!!!!
Old May 31, 2007 | 12:16 AM
blwfly's Avatar
fixed the headlights well kinda i now have indicators in the front and back but the side lights arnt going
i now have headlights but only highbeams need to read throught the fsm for this one
any one have ideas on the speedo cable?
Old May 31, 2007 | 12:23 AM
DriveFast7's Avatar
i bought a new speedo cable on ebay years ago. can't remember if it was for a b1600 or not. rx7........honestly never compared it. a good junkyard trip.
Old May 31, 2007 | 05:24 AM
trochoid's Avatar
Don't you have a 1st gen cable laying around, maybe from the parts lot with the last 7 you bought
Old Jun 4, 2007 | 10:18 PM
blwfly's Avatar
nah the cable was brittle and broken bit of a bummer
just waitin on the p.o to send me the socket for the lug nut then i can fix me breaks yay
Old Jun 4, 2007 | 10:26 PM
riceburner1r2001's Avatar
my boss has a blue 1. if i knew how to put the pics on here i could show ya
Old Jun 20, 2007 | 04:32 PM
Sobr609's Avatar
damn that repu is in very good over-all good condition..seems like everyone is finding repu's..good luck with the project!
Old Jun 20, 2007 | 10:26 PM
vancityR100's Avatar
speedo cable
there are new ones on ebay $20
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWD1V
Old Jun 26, 2007 | 09:24 PM
sirmikef9's Avatar
74 repu
wow kool...........i got a yellow one....
Old Jul 24, 2007 | 01:03 AM
blwfly's Avatar
help im trying to change my slaves on my drum brakes
which way am i supposed to turn the adjusters to losin the brakes i have turned them anti clockwise alot on both and the damn drum still wont come off... any pointers..
also on one i cant get a set screw out "can i just drill the screw out?? and not worry bout replacing it?
Old Jul 24, 2007 | 07:47 PM
Tom93R1's Avatar
gross polluter
the drums need to be pressed out with those screws, or if you can get a drum pulled from the local parts store it will have a slide hammer to get them off.
Old Jul 26, 2007 | 07:14 PM
Mazdaorbust's Avatar
Beach Bum
Repu
Congrats on your repu. I have a 75 repu which I am working on. It gets more looks than my brothers rx7. I think it great.
Old Jul 26, 2007 | 10:17 PM
blwfly's Avatar
this would explain why i cant knock the bastards off might have to take me truck to a mechanic for this one
Old Apr 9, 2009 | 10:59 PM
blwfly's Avatar
little update.
just purchaced this stuff from atkins.
Overhaul Kit, 87-88 13B T (B)
Overhaul Gasket Kit (8AF4-10-271)
Apex Seals and Springs
Corner Seals and Springs
Side Seals and Springs
Viton Oil O Rings (Inserts)
Oil O Rings (Metal)
Front and Rear Main Seals
Pilot Bearing and Seal
Thermal Pellet
Hylomar Sealant
Rotor Bearing For 69-92 Rotary Engines
3 Window Main Bearing for 74-92 RX7 All
Rear Rotor Housing 87-88 RX7 Turbo
Main Stationary Gear Bearing Tool to be used with a hydraulic press Rotor Bearing Tool. for use with Hydraulic Press
Clutch Kit- NEW - 87-88 13B Turbo Rx7
Contains: Clutch Disc, Pressure Plate, Throwout Bearing, Pilot Bearing & Seal
Oil Pump Chain for 86-95 All Rotary Engines
CoolantTester Atkins Rotary Designed Coolant Pressure Tester
Thermostat for 69-88 Rotary Engines
Thermostat Gasket
this stuff from japan2la on the froum
Front and middle sideplate
matched S4 TII rotors
Spacer between TB and UIM FREE
S5 Staygears front and rear (yes hardened)
S4 TII BPS sensor
been a longtime to get this far lol
also heres my thread on my wireing nightmare
https://www.rx7club.com/1st-generation-specific-1979-1985-18/s4-t2-wireing-project-830144/
cheers
kiwi
Old Apr 13, 2009 | 11:21 PM
blwfly's Avatar
atkins corner seals the indentation faces the iron.
new stuff
stock t2 clutch and pp
close up of one of the new housings
scored a shitload of tools for next to nothing all good brands snapon,mag etc
Attached Thumbnails going old skool got a repu:)-cimg1779.jpg   going old skool got a repu:)-cimg1773.jpg   going old skool got a repu:)-cimg1774.jpg   going old skool got a repu:)-cimg1775.jpg   going old skool got a repu:)-cimg1770.jpg
Old Apr 14, 2009 | 05:07 AM
MattG's Avatar
MattG FTW!!!!!
Nice score on the tools!!!
Old Apr 14, 2009 | 08:32 AM
Siraniko's Avatar
RX for fun
congrats!!!!!
Old Apr 14, 2009 | 10:13 AM
Matt22's Avatar
Fear The RE
Sweet another local guy with a REPU. I have thought about getting one for a while now.
I look forward to seeing it on the road.
Old Apr 14, 2009 | 07:28 PM
blwfly's Avatar
yeah i cant wait. slowly but surley i will get it running.
where in oregon are you?
thanks guys getting my parts tomorro from japan2la cant wait.
also i fould i have tiny tiny pitting in one area of the e-shaft.
has any one had there shaft polished at a machine shop.?i know pistons cranks are a lil different since the rods can be cut down.
but can i do this and stay within oil clearances?
Old Apr 19, 2009 | 12:14 AM
DBookatay's Avatar
Why? Why?? WHY???
I'D KILL TO HAVE THAT TRUCK!!!
I've been trying for over a year now to find one in even semi-decent condition here in the Northeast. Yours is espically clean.
Good find!
