the "500 ON PUMP-AI CLUB"
Old Feb 28, 2007 | 01:32 PM
Howard Coleman's Avatar
Racing Rotary Since 1983
2007 is going to be the year of the "500 ON PUMP-AI CLUB."
it is going to be really neat to see all the dyno sheets get posted in our DYNO SECTION w 5s being the front number... maybe some 6s too
howard coleman
Old Feb 28, 2007 | 02:34 PM
in order to be a member of the 500 on PUMP-AI CLUB...
you have to make 500 or more rwhp on pump and AI, duh. well i had to start somewhere.
you have to post in the DYNO SECTION of the AI forum
ideally you should post:
a dyno sheet
the brand/model of your AI system
jet size/s
injectant... water, alcohol, mix
tune details... timing, afr, egt, knock boost
turbo
so far we have 1.5 members.
XINX did 512 using a CM system w an M8 and M12 (1260 CC/MIN max)
PDViper77 did 501 ( yes i know you did 562 but that was on racegas which doesn't count). 1/2 bridge w a GT42R at 20 psi. PD hasn't yet posted in the dyno section but we will grant him provisional membership in hopes of seeing his info there. BTW, you don't have to post a dyno sheet, just some details would be appreciated.
i will make a prediction that there will be alot more members in the 500 Club by yearend 07.
since it is an exclusive club that will meet once a year in Yankee Stadium we need an emblem/decal/badge/sign. so someone w talent get busy and design/post your idea on this thread and then we all will figure it out and come up w a decal for our rolling stock.
of course there can be a 600 club too. if you do it you have to post.
howard coleman
Old Feb 28, 2007 | 02:45 PM
fastcarfreak's Avatar
3rd motors a charm I hope
your gonna make me blow my motor just so i can get into this club, arent you?
ugh.. oh well, here goes nothing.... i'll fill you guys in this summer
Old Feb 28, 2007 | 02:51 PM
iceman4357's Avatar
god damnit!!! im 10rwp off. Maybe i will go to a mustang dyno just to get a dyno chart over 500rwp I will get my new wastegate spring and lay over 500 on pump and alky damnit.
Old Feb 28, 2007 | 02:57 PM
zinx's Avatar
_________________________
zinx, not xinx
I'm sure there are a lot more out there that just either haven't dynoed or just don't post.
Old Feb 28, 2007 | 03:00 PM
we need a really cool decal....
Old Feb 28, 2007 | 04:41 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
I need to put my car back together, upgrade my t04s to something that breaths a little better above 20lbs, heckle you guys into what kit i should run and then get one of them cool decals..
Old Feb 28, 2007 | 08:09 PM
hondahater's Avatar
spending too much money..
I just need to get my half bridge irons back from being ported and get the thing put together and tuned and hopefully I'll beable to get a cool decal
Old Mar 1, 2007 | 01:24 AM
BNA_ELLIS's Avatar
a dyno sheet
jet size/s
turbo
so far we have 2.5 members.
Erdin did 549 rwhp using an SMC system running methanol at 20 psi w an R85.
howard coleman
Howard,
Erdin got 465 on a hub dyno approx 420 rwhp
Old Mar 1, 2007 | 01:34 AM
sdminus's Avatar
Cant be bothered anymore
Brian.. didnt you and re works and dragon etc make 500 hp a while ago with WI.
Scott
Old Mar 1, 2007 | 06:40 AM
blitzboy's Avatar
whooho lets do this Dyno Queens , I got to make up another 50 rwhp easy peasy now with my half Bridgeport.
Scott shall I contact Richard again and get the system, is the summer working well?
Old Mar 1, 2007 | 06:45 AM
brian,
thanks for the post. i re-looked at the 2 dyno sheets posted in the dyno section and the 2nd shows 549 flywheel hp unless i misread it. i didn't pick up the Flywheel part so if that sheet is correct Erdin should be credited w 85% of that or 466.
a good run but if i am correct not enough for a decal
howard
Old Apr 15, 2007 | 12:59 AM
RICE RACING's Avatar
Exclamation Hmmmmm H2o way to GO !!!
RICE RACING Water Injection System
Pump fuel 95 RON
16.7psi boost at peak rwhp
13B cosmo engine with secondary bridge port, owner built & ported
tune 10.10:1 AFR, no knock, water rate *enough* not tuned for dyno runing
dyno dynamics system (give lower figures than your types, you can add a minimum 25rwhp)
Old Apr 15, 2007 | 01:13 AM
Lightbulb Water Injected only!
howard coleman
I suggest you go start this 600 sticky
I will be posting in it shortly !
Old Apr 15, 2007 | 01:50 AM
Thumbs up pay up time :)
We shall post up a sheet with the cars typical performance very soon minus any messages on it
also some some video footage of what a complete animal such power makes a little RX2/capella
So who do we PM delivery address for the decal????
600 thread going yet? will someone beat us to it?
lol
Old Apr 17, 2007 | 03:46 AM
Talking
still no PM about the decal?
Am i the only legitimate member of this club???
To all the people who have PM'd me about WI I say thanks
I look forward to helping a whole heap of new users who's eyes have finally been opened to a proven technology, the best technology.
Old Apr 17, 2007 | 03:53 PM
sdminus's Avatar
Well done pete. You the man.....
This may be my last post. My fd should be going tomorrow
Scott
Old Apr 19, 2007 | 04:49 PM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
I will be in this club in about a month
Half Bridge with GT45
Old Apr 19, 2007 | 07:29 PM
we have to get going on a cool decal as lots of people are going to be in the most exclusive Club on the board.
hc
Old Apr 23, 2007 | 05:29 AM
Redynoed Rx2 tonight, did 578rwhp on pump and WI
stats 21psi mid range 18psi at peak power, still could not get boost controller to work right. hope to have new dyno sheet up in next few days.
Old Apr 24, 2007 | 07:30 AM
Old Apr 24, 2007 | 08:26 AM
you are on the decal list...
hc
Old Apr 30, 2007 | 05:59 AM
blitzboy's Avatar
Dynoed at just under 470 at the hubs (1.3BAR) on a Dyno pack with 375 lbs of torque at 6k on pump fuel !!! this Saturday just gone graph to follow, running 50:50 mix on the Aquamist HFS system. my last setup was 450 at the wheels on race fuel. So an improvement of 20 BHP and it also peaks earlier at 7k and holds till 8k at the same power level, torque improvement by a massive 50 lbs, so the combination of HB and WI on the same turbo and same boost pressure has improved performance massively over last year
Old Apr 30, 2007 | 06:32 AM
hondahater's Avatar
interesting. would love to see the dyno graph between both the street port and bridge port.
Old May 22, 2007 | 03:18 AM
Talking
How much did your drivability suffer and what is the idle speed now (lowest point). I am still debating wether or not to go through with this mod on my own engine before it goes back in the car
I know the power bridges make, but also have seen the power of street ports too so give us a detailed real world update mate
I'm 99.999% set on my street ported example so it better be a good review haha
