flood!!
Old Mar 13, 2002 | 04:37 PM
MazdaRx7Power's Avatar
flood!!
since i've put the headers and straight pipe dam car keeps flooding. did every once in a while before. but now it turns on fine in the morning but when i go to work or drive somewhere and try to turn it on bam flooded. what do you guys suggest?
if i have to wire the fuel pump how do you?
Old Mar 13, 2002 | 05:07 PM
the o2 sensor isnt connected could that cause it to do it?
Old Mar 13, 2002 | 07:32 PM
come on i know everyone has had this problem before? search aint working right now so haahahah cant do that.
Old Mar 13, 2002 | 08:03 PM
QC Motorsports
don't
Just in case you do this...don't. DO NOT step on the accelorater before you start the car. You might know that all ready. You could also have a throttle positioning sensor malfunction. Its allways nice to have one of thoughs. That would be my best bet. Its what was wrong with mine.
hope you get it fixed.
Old Mar 13, 2002 | 08:15 PM
well before the headers the car would flood if i didnt tap the gas a little. so i stopped doing that when the header was on, and starts fine in the morning but whenever i go to lunch at work, it always floods. how do you wire the fuel pump? and is it safe to do?
Old Mar 13, 2002 | 08:16 PM
i'm tired of having someone have to come and help me by turning the key while i hold the gas hose. pulling the fuse never works either. is there a fuel pump fuse that can be pulled?
Old Mar 13, 2002 | 08:26 PM
QC Motorsports
sorry
sorry I can't help ya there. you might ask mazda.
wish I could help more. good luck
Old Mar 14, 2002 | 07:42 AM
Josepi's Avatar
Despise Enmity
Under the hood, by near the A/C+PS.
Alt, you could install a kill switch for the fuel pump.
Old Mar 14, 2002 | 08:24 AM
schexy1's Avatar
you have one o ftwo choices for a switch. You could wire a togle switch to turn the fuel pump on and off, or you could use a 5 prong relay with a momentary switch. Either one will work, but I don't know if this will damage the fuel pump. If you want a diagram send me an email at schexy1@hotmail.com.
tidanb0utch
11
Oct 7, 2015 07:36 AM
FbFuninthesun
Oct 6, 2015 08:03 AM
PinkRacer
43
Oct 1, 2015 09:13 AM
Monsterbox
Sep 11, 2015 03:29 PM
