Power FC New version of PowerFC FAQ
Old Aug 30, 2006 | 05:08 PM
DaleClark's Avatar
RX-7 Bad Ass
Hey everyone -
I finally finished my long-awaited update of the PFC FAQ. This should answer 90% of the newbie questions about the PFC .
The installation section has been expanded, info on using it in an FC has been added, and tons more stuff I've forgotten I've put in there .
Here it is -
http://www.clubrx.org/media/pfc/PowerFC_FAQ.pdf
Please let me know if you have anything that should be changed, added, deleted, what have you.
Thanks,
Dale
Old Aug 30, 2006 | 09:24 PM
cewrx7r1's Avatar
Eye In The Sky
The way to get the AC ECU bypass to turn off the AC when on power, is to insert a Hobbs pressure switch into the AC control circuit. I have mine set at 4psi to turn the AC off.
Old Aug 30, 2006 | 10:15 PM
DaleClark's Avatar
RX-7 Bad Ass
Good point - I'll see if I can't add that in there. The AC discussion needs some more work.
BTW, what model car do you have - base, touring, R? Seems like there was some correlation between package and whether the AC would work. My '94 R2 has been working like a champ - all speeds, no problems, for at least 20,000 miles (with SERIOUS daily AC use ).
Dale
Old Aug 31, 2006 | 11:20 PM
cewrx7r1's Avatar
Eye In The Sky
Dale,
My FD was one of the most troublesome year/versions ever made: March 1992 R1.
Best bang for the buck was my 1967 Alfa Romeo GT1300JR, and my wife's
MX-3 GS with the V6 engine which we no longer own.
Chuck
Old Sep 3, 2006 | 02:36 PM
RE-Amemiya's Avatar
Not the company
Thanks for the info!
Old Sep 3, 2006 | 09:29 PM
grimple1's Avatar
Turd Ferguson
Thanks for the guide. It's good information and I had honestly not heard about the idle bleed screw adjustment during install. Probably saved me some labor time.
Old Sep 4, 2006 | 05:51 AM
paulr33's Avatar
Smile
hey,
you should check out
http://paulr33.skylinesaustralia.com/
-> Documents
-> Apexi PowerFC FAQ
almost the same thing
Old Sep 5, 2006 | 09:43 AM
DaleClark's Avatar
RX-7 Bad Ass
That's good stuff - I've never seen that before! I'll have to put a link to it in my FAQ, as that covers a lot of stuff for other cars besides the FD.
Thanks,
Dale
Old Sep 8, 2006 | 07:07 PM
Great writeup! Thanks DaleClark!
+1 vote for Sticky.
Old Sep 9, 2006 | 12:00 AM
scrubolio's Avatar
they don't understand
thanks for all your contributions dale! i read your faq and a lot of your posts before installing my PFC, you rock
Old Sep 9, 2006 | 02:15 PM
grimple1's Avatar
Turd Ferguson
Gonna put this in this thread for other PFC users.
Here's picture location of the idle bleed screw that is mentioned in the FAQ above.
Old Sep 10, 2006 | 09:46 AM
DaleClark's Avatar
RX-7 Bad Ass
I've been meaning to put that in the FAQ - I may just add your pic in .
Thanks,
Dale
Old Sep 10, 2006 | 06:07 PM
*RX007*'s Avatar
Yes it's twin turbo...
i was wondering if there is a way to reset a used PFC to the base map without a comander, since i just bought one w/o the comander thanx!
Old Sep 11, 2006 | 11:31 AM
DaleClark's Avatar
RX-7 Bad Ass
Nope, you need a commander. The PFC can't do squat without the commander or datalogit.
Read the FAQ - make sure you get the right commander for your PowerFC.
Dale
Old Sep 11, 2006 | 05:07 PM
*RX007*'s Avatar
well actualy i just ordered the datalogit, so will i be able get get the stock map with that then, until i get her tuned? thanx, the FAQ has some great info!!!
Old Sep 13, 2006 | 10:45 PM
JDawG707's Avatar
xx-Team-xx
preston...u can use my commander to reset it.......BUT DO MY TIAL LIGHTS plz
Old Sep 17, 2006 | 06:56 AM
KINETIK_FD3S's Avatar
almost done
scrubolio- thanks for all your contributions dale! i read your faq and a lot of your posts before installing my PFC, you rock
me too, thanks dale
Old Sep 29, 2006 | 11:10 AM
DaleClark's Avatar
RX-7 Bad Ass
Bump since no one will sticky the FAQ .
Dale
Old Sep 29, 2006 | 11:31 AM
coda23's Avatar
quiet excess...
Me three! thanks dale.
I read your FAQ and want to share some feedback about my experience... I was looking for a "selflearn" screen... or maybe a function to begin after I engaged the clutch... something to lmk that the unit was in fact "learning"... not seeing anything made me apprehensive.... maybe a blurb about the first run and what to expect after installation and the best course of action for newbies... get it tuned, run it as it is, get a B/C... whatever you think is best.
I just installed yesterday then switched back cause I dont wanna blow the thing up in my ignorance!
BTW whats a "bump?"
Old Sep 29, 2006 | 11:33 AM
coda23's Avatar
quiet excess...
Talking
BTW whats a "bump?"
<---- obviously a noob.
thanks.
Old Oct 6, 2006 | 06:01 AM
almost done
^bump^ for a sticky!
Old Oct 6, 2006 | 07:07 AM
SLOASFK's Avatar
Top's always down
Right now, I'm trying to find the perfect ECU for me and I've got a couple questions that I didn't see covered in the FAQ...
Is it true that the PFC is untunable above 8,000RPMs?
Is it true that the PFC has problems supplying feul above 15PSI?
Can a PFC support a 6 injector setup?
Old Oct 6, 2006 | 09:42 AM
dhcernese's Avatar
Dan Cernese
Is it true that the PFC has problems supplying fuel above 15PSI?
No, no, I don't know.
https://www.rx7club.com/power-fc-forum-47/power-fc-running-6-injectors-496165/
Old Oct 26, 2006 | 02:48 AM
*RX007*'s Avatar
better bump this before it gets lost...
Old Oct 26, 2006 | 03:08 AM
almost done
why don't the mods sticky this?
