T72 dynochart - 9psi and 15psi
Old Oct 2, 2005 | 08:08 PM
onefastrx7's Avatar
I meant to post this dynochart for a while...
The car belongs to 1STGEN
1983 RX7 FB
13B- REW street ported
550cc/1600cc injectors
HKS cast manifold
T72 hyrbid turbo ( T66/T72 turbo)
Microtech LTX8
SLIPPING CLUTCH
Tuned by Alamo Autosports in Arlington, TX
Old Oct 2, 2005 | 08:16 PM
Directfreak's Avatar
I am a Jeeper Now.
Nice, Can you post a sheet with engine RPM as well? Pics of the car too?
I Love turbo 1st gens.
Old Oct 2, 2005 | 08:45 PM
onefastrx7's Avatar
Under rpm, you can see the clutch slip.
I can get some pictures next time the owner comes by.
He is getting a new clutch, so we will retune with the new clutch. He also has exhaust leaks, and we tuned for 10.8 afr, but it felt like 10.0.
So with the new exhaust gaskets, a bit less split, and a bit leaner afr, we are hoping for 470whp at 1bar boost
Old Oct 3, 2005 | 12:47 AM
BDC's Avatar
BDC
BDC Motorsports
Impressive. Keep up the good work!
B
Old Oct 3, 2005 | 01:42 AM
mwatson184's Avatar
holley guy
Explain what you mean by t66/t72, all of the t series turbos have the same selectin of turbines/housings/chra's. You choose the compressor side to go with them.
-Marques
Old Oct 3, 2005 | 05:21 AM
RETed's Avatar
Wow, how you got the 550 / 1600 combination to support that kinda power?
Stock FPR?
Are you running higher fuel rail pressures than stock?
-Ted
Old Oct 3, 2005 | 09:10 AM
onefastrx7's Avatar
Stock FPR?
-Ted
The car has an Aeromotive fpr and fuel pump.
550/1600c is ok, but I am pretty sure they are borderline.
Old Oct 3, 2005 | 09:11 AM
onefastrx7's Avatar
-Marques
All I know is that the turbo came off a truck, and the owner thought it is a T72. He just had it rebuild by Majestic, and they told him that it is not a T72, but some kinda hybrid with T66 parts etc.
Old Oct 3, 2005 | 09:16 AM
Whizbang's Avatar
Respecognize!
at is impressive for 9spi!!! damn you and your standalone!
Old Oct 3, 2005 | 09:19 AM
Whizbang's Avatar
Respecognize!
something i never really understood, why cant the stock turbo do that......
Old Oct 3, 2005 | 01:34 PM
mwatson184's Avatar
holley guy
Inneficient at high boost, can't flow enough air...Simple as that.
Old Oct 3, 2005 | 01:38 PM
Whizbang's Avatar
Respecognize!
ah. thats damn impressive still though. has to be some good tuning involved
Old Oct 3, 2005 | 06:45 PM
onefastrx7's Avatar
Actually the car is tuned really conservative. The owner does not want me to push it. I suggested a C16 map, but he refused. And he wants to run 15psi on pump gas not more
But believe me, the car is INSANELY FAST! I have tuned many high horsepower cars ( 800-1000HP), and this rx7 can really hang with some of them. I guess the weight of 2000lbs helps to run with a 800hp Supra ( 3600+lbs).
Old Oct 3, 2005 | 07:30 PM
darkphantom's Avatar
The king of the highway!
even though that turbo is mixed parts. I was going to get a T72 instead of a T78. if i knew now what i known then I would of gone with a T72.
BTW how much power you think that 550/1600CC's can hold cause i have close to the same setup?
Old Oct 3, 2005 | 08:37 PM
z-beater's Avatar
REW'd FB
wow, great numbers!
Old Oct 3, 2005 | 08:56 PM
fastrotaries's Avatar
W. TX chirpin Monkey
On what gas is this on? The weak 91 octane that's in the Metroplex?
Old Oct 4, 2005 | 12:37 AM
onefastrx7's Avatar
Right at 450-470whp
Old Oct 4, 2005 | 12:38 AM
onefastrx7's Avatar
93 octane
Old Oct 4, 2005 | 11:32 AM
FB II's Avatar
hell yes, turbo 1st gens unite!!! car pics if you can get them plz hhahaa
Shainiac
Jul 17, 2019 02:20 PM
Ian_D
Oct 14, 2015 12:31 PM
94RHDFD
20B Forum
Apr 8, 2002 04:57 PM
