Oil / water lines. Where do they go?
Old Mar 24, 2005 | 08:09 PM
Bodyshop's Avatar
Hey guys.
Sorry for such a dumb question but...
I have a 93 FD and I just got my GT 35R kit from RX7 store and was wondering which ports on the turbo were for oil and which were for water and which were inlet and which were outlet. Then. Where do those lines connect to the block?
I have done quite a bit of searching and have come accross quite a bit of discussion on restricting the oil inlet. I think I have decided to leave it unrestricted as the GT35R has a built in restictor and to go with the biggest oil return that I can. I just need to know where to hook up the lines.
Any pics would be great.
Thanks so much guys.
Old Mar 24, 2005 | 08:27 PM
unvmyrx7's Avatar
the coolant lines comes out from the water pump housing, it doesn't matter how you hook them up to the chra. when you install the turbo, position the chra with the oil return on the bottom, its the largest hole . the coolant fitting will be on the right and left. use silicone hoses for the coolant lines. here is a pic of the oil inlet hose
Old Mar 24, 2005 | 09:07 PM
Bodyshop's Avatar
Where does the oil feed come from and then where does it return to?
After the water comes out of the water pump housing, it goes into the turbo, and then where does it go?
Thanks again.
Old Mar 24, 2005 | 10:06 PM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
Yes...I know things are dirty...
The 90 deg bend is the oil feed...
The return is the front return port that the primary twin used. It's the line that's just above the steering rack in the pic.
The water return line is the upper hose in this pic.
This is the supply...
Old Mar 25, 2005 | 08:16 AM
Bodyshop's Avatar
WOW. Fantastic. Thank you very much. That's a huge help.
I take it the water feed is the stainless one with the red A/N fitting on it in the last pic.
I know there is also a place on the passenger's side fire wall side of the block right behind the rear rotar. There's a hole with a short stud above and below it. Is this a return for the rear turbo on a stock twins setup?
Old Mar 25, 2005 | 08:20 AM
AntiVenom7's Avatar
Wouldn't Go If U Paid Me
I used the nipple that used to go to the TB for the AWS and the return port that was used for the same. of course this only works if you are getting rid of the AWS.
Old Mar 25, 2005 | 10:03 AM
2a+RoN's Avatar
it is not the ss one, that looks like fuel. The water is that 90 degree coming out of the water pump housing with the rubber line on it.
Old Mar 25, 2005 | 02:28 PM
Railgun's Avatar
I won't let go
What he said.
Old Mar 26, 2005 | 09:32 AM
Bodyshop's Avatar
I was looking at the car this morning and I can't seem to find where you guys are getting the oil feed. Do you have to remove your power steering and such?
Old Mar 26, 2005 | 09:52 AM
2a+RoN's Avatar
if you leave that stock hard line you can take the oil feed from there and you should be able to get to it with ease, otherwise you can take out the hard line and run at the corner of the front plate which prolly would require removing some accessories...
Old Mar 28, 2005 | 04:32 PM
Bodyshop's Avatar
Thank you everyone for all of your help. You have been fantastic. Right now I have only one more question and that is: What is the hole on the firewall side of the block, behind and below the exhaust ports. Is this an oil feed/return location? I have the oil and water lines hooked up as described in this thread. Do I have to block this with a plate or anything? I'll take some pics tonight and get them sent up.
Thanks again.
Old Mar 28, 2005 | 04:49 PM
Railgun's Avatar
I won't let go
Block it off. It's the oil return port for the secondary turbo.
Old Mar 28, 2005 | 06:41 PM
Zero R's Avatar
Just in time to die
Didn't your kit come with blockoff plates and instructions???
Old Mar 29, 2005 | 08:49 AM
ghostrx7's Avatar
Hmm mine didnt, btw sean, I sent you a pm....about the manifold etc.
Old Mar 29, 2005 | 12:11 PM
Bodyshop's Avatar
Ya, my kit didn't come with block off plates or intructions. I did buy a seperate blockoff plate kit from RX7store. I used them all and do not have one left over for that one. I guess I'll just make one.
Thanks again everyone.
Old Mar 29, 2005 | 01:38 PM
Zero R's Avatar
Just in time to die
I haven't been receiving all my PMs it seems. Your the second person now to tell me they sent one and I haven't seen it. I thought yours(blockoff plates)were sent if you still need a set let me know it is owed to you. Shoot me a email instead of PM's I'll get back to it today.
Old Mar 29, 2005 | 06:49 PM
ghostrx7's Avatar
What is your email addy it seems you have disabled it through here...
Old Apr 2, 2005 | 03:21 PM
books's Avatar
I tend to agree with this. Has anyone verified this?
I do not have a lot of room to attach the top hose (from water pump housing) to the driver's side of the turbo. It is close to the compressor housing and LIM. I would like to run it over the top of the turbo to the other side and attach it to the passenger's side 90 degree fitting. I would run the driver's side line down (90 degree fittimg pointing down) to the lower housing nipple.
I would appreciate A-Spec's comments on this.
thanks
Old Apr 2, 2005 | 04:11 PM
Zero R's Avatar
Just in time to die
thanks
Email was sent.
Sean@a-spectuning.com
Old Apr 2, 2005 | 06:40 PM
books's Avatar
thanks for the speedy reponse
Old Apr 2, 2005 | 09:40 PM
1sicsol's Avatar
Good thread for install n00bs.
Old Apr 2, 2005 | 10:33 PM
Jason's Avatar
The one
The kit should have the oil return block plate with it. If you are missing one let me know and I will send you one. I also have instructions if you need them.
Jason
Old Apr 3, 2005 | 06:05 PM
1sicsol's Avatar
What happens if you use the oil return on the left
side of the motor?
Old Apr 3, 2005 | 08:50 PM
Railgun's Avatar
I won't let go
then you have to block off the front one.
FD7KiD
15
Feb 26, 2021 10:12 PM
Snoopy FD
Dec 8, 2015 01:45 PM
rotor_veux
Aug 31, 2015 07:49 PM
FD7KiD
Aug 17, 2015 11:50 PM
