Walbro 255l/h Filter
Old Feb 19, 2004 | 01:29 PM
jreynish's Avatar
New Project on the Way...
I have to clean out my gas tank, so I droped the gas tank and I had installed the walbro 255 L/h fuel pump prior, and Installed jus the little bag filter that came with it, now I am currious wich would be better the little bag or the stock box screen?
Old Feb 19, 2004 | 01:30 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
my parts car had a "bag/sock" type filter. But my TII and Sport have a box type filter. I think both are about the same.
Old Feb 19, 2004 | 01:43 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
I'd like to know which one filters better. I just used the small bag that came with my walbro, but the stock box filter has a much large surface area.
Old Feb 19, 2004 | 11:58 PM
jreynish's Avatar
this is what I am trying to figure out wich it better the box type of the stock or the bag type of the walbro
Old Feb 20, 2004 | 03:49 PM
jreynish's Avatar
bump^
Old Feb 24, 2004 | 02:39 AM
BUMP
Old Feb 24, 2004 | 03:26 AM
TonyTurboII's Avatar
Glock Lover
Im using the stock screen on my Walbro. I just didnt like the look of that little bag.
Old Feb 24, 2004 | 08:41 AM
jon88se's Avatar
Eat, sleep, work, mod.
aeromotive
Old Feb 24, 2004 | 11:07 AM
jreynish's Avatar
I finally got tired of waiting for a reply so I did a little research this mornign in the Lab after I finished my work.
I took 50ml of gasoline and a vacume flask and put each filter on the end of a tube I then inserted the filters each in different tryal with 10g of debris and mixted it, then started the vacume flask. did this twice once for each filter.
In the end the stock screen let way too much through for my liking,
the bag filter that comes with the walbro worked rather well only letting through the very fine stuff, not as much corse stuff as the box type screen that is stock.
Old Feb 24, 2004 | 02:13 PM
Thanks for stepping up and providing some good info.
Old May 30, 2004 | 01:36 AM
$150FC's Avatar
Currently Winning
Bump.
Where can you get the filter for the Walbro? Any auto parts store?
Old May 30, 2004 | 09:22 AM
Icemark's Avatar
probably the best bet would be to use the walbro sock inside the stock screen
Old May 30, 2004 | 10:39 AM
chris1234p's Avatar
Sorry to steal the post but I just installed my walboro yesterday and now my fuel gauge wont work. Im assuming it was that long rod with a wire wrapped around it that came unmounted or something when i put the assembly back in the tank. Anyone know exactly what to do to fix it?
Old May 30, 2004 | 03:49 PM
RETed's Avatar
Why don't you get a fuel pressure gauge and tell us?
-Ted
Old May 30, 2004 | 05:06 PM
jreynish's Avatar
Yes it would probably be best, but then you would have some modification, because I dont' think you can fit both filters on at the same time without modification. But that is most likely the best idea.
Old Jun 6, 2004 | 12:55 AM
$150FC's Avatar
Currently Winning
Nobody knows where to get a replacement filter?
Old Jun 6, 2004 | 01:00 AM
Net Seven's Avatar
Uhh just about any auto store you can ever think of...
Old Jun 6, 2004 | 01:23 AM
$150FC's Avatar
Currently Winning
and ask for what? a walbro 255 fuel filter? the stocker didn't look like it would attach to the walbro.
Old Jun 6, 2004 | 01:28 AM
version13's Avatar
Exhaust leak
Ditto, they perform the same and I thought the stock was cooler.
Old Jun 6, 2004 | 01:30 AM
$150FC's Avatar
Currently Winning
hm. ok. guess it can work.
</dumbass>
Old Jun 6, 2004 | 03:15 AM
jreynish's Avatar
How do you figure they perform the same did you not read the entire thread out of trials had the stock box screen type let more stuff through than the one that came with the walbro, these are real tests done in a Lab, not just a "guess". what do you base that assumption on?
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
tidanb0utch
11
Oct 7, 2015 07:36 AM
Captain Hook
Sep 22, 2015 01:12 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
