83 stearing gearbox install
Old May 27, 2003 | 05:36 PM
Pittdp's Avatar
Whats the best way to install a new steering gearbox and colum in my 83 rx7? What do I need to do?
I just got the thing on ebay, very clean, 83k miles on it very little play. $35.00, + 10.00 to ship
Old May 27, 2003 | 05:39 PM
Pittdp's Avatar
Should I also take pics of the change out for other users info?
Old May 27, 2003 | 05:44 PM
Mr. ImportGuy's Avatar
Looking for Another RX7
It's very easy just get the car up in the air. Take off the steering wheel and the turn signal and wiper stuff. Then unbolt the box and it basicly come out. Give or take a few other little things but its very easy.
Old May 27, 2003 | 10:51 PM
Pittdp's Avatar
will the ac get in the way?
Old May 28, 2003 | 01:55 AM
Pittdp's Avatar
no one? I have everything unbolted except the sheld underneth and the steering arm is stuck to the tie rod cross member. I need a fork to get it loose. it looks realy tight with the AC.
Old May 28, 2003 | 05:04 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
good luck man, I changed/rebuilt mine when I had the motor out, I dont see it being easy with everything in the way. Id say the AC will have to come off, the battery and battery brack, the radiator and probally the condenser. Also dont forget the bolts that attach the steering column to the underdash. Once you get everything loose , you can slide the black column cover off the steering box, will slide out from inside the cabin. It will make it way easier to move to the left or the right. And I tell you it was a pain in the ***, I dont see it being very easy with the motor in
Old May 28, 2003 | 10:16 AM
Pittdp's Avatar
Dam, thats what I thought
Old May 28, 2003 | 10:34 AM
Metallic_rock's Avatar
Ride 'n Style
ok, you don't need to pull all of that stuff out. Get the car up in the air, pull off that shield underneath, and use a tie rod end press to get the joint off the pitman arm. After you have taken off your steering wheel, signal crap, and MAKE SURE YOU HAVE YOUR KEY ON (the key lock will prevent the shaft from sliding out if you don't have it on), you can un-bolt it and slide it down. It is tight, but you can do it without removing the A/C.
BTW, disconnect the battery before doing this!!!
Old May 28, 2003 | 06:18 PM
Pittdp's Avatar
It's done, I had to unbolt the ac though to do it.
The new one is much tighter
24seven_dada
20
Nov 10, 2018 12:03 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
Enzo1944
Sep 6, 2015 08:57 AM
