Not boosting correctly?? Help please!!
Old Dec 26, 2002 | 08:56 PM
insomniac's Avatar
Unhappy Not boosting correctly?? Help please!!
quick insight, I have the XS T04E and all the mods for single turbo and only had it for 6 months, it was only boosting at 6-7 psi, which I thought it was boosting off the wg spring which was just fine. Just have to wait for a BC. Added a profec B. And still boosting not over 7 psi
So thought it was the wg. Had that checked out and it's working. Had my intake system pressurized to make sure of no leaks anywhere. Found a leak here and there and it's fixed. But still not boosting pass 7psi.
Even had the wg manually bolted closed with a longer bolt. Mechanic told me that, this will at least boost it to a point where my motor will blow. But no luck. Still not boosting.
is this a sign of a bad turbo? any help out there from you single turbo guru, will be highly appreciated
Old Dec 26, 2002 | 10:12 PM
Remove the filter and watch the turbo at idle. Its should spin freely. Also, are you sure you have no boost leaks? With the wastegate closed the turbo should spin vrery fast.
Old Dec 27, 2002 | 04:27 AM
1FooknTiteFD's Avatar
Ghost Ride the Whip
check to make sure all the gaskets are tight and in correctly. Afterwards, check to see if all the intercooler hoses are connected and that there are no vacuum leaks either.
Old Dec 27, 2002 | 12:38 PM
insomniac's Avatar
All has been checked, Ivan has my car and still can't figure it out.
Old Dec 27, 2002 | 02:24 PM
Ghost Ride the Whip
Insomniac, do you have the silver car with the small PFS SMIC??? I think I saw your car at the Auto palace the other day
Old Dec 27, 2002 | 02:48 PM
insomniac's Avatar
yeah that's mine, I think it's the PFS smic that might be clogged.
Old Dec 27, 2002 | 02:56 PM
insomniac's Avatar
POS car is stressing me out, I just hope it's not the turbo. If it's the IC then this is a good excuse to get a new FMIC. I'll keep my fingers cross!!!
Old Dec 27, 2002 | 03:49 PM
Ghost Ride the Whip
did you buy the turbo kit brand new? If so, then that turbo shouldn't wear out so quickly. They usually last quite long
Old Dec 27, 2002 | 03:58 PM
insomniac's Avatar
yeah got it brand new, so I'm hoping it's just something else. Something else that's not to costly.
Old Dec 27, 2002 | 06:17 PM
nyt's Avatar
nyt
check the settings on the back of the profec
there are 2 settings, one for internal wg's and one for external.. i dont know what difference it would make but
should have up down up down
or the reverse order
play around.
also
make sure you have a boost source going to the side of the wastegate. this will open the wastegate when the boost pressure equals the spring pressure. pressurize that a little and make sure there are no leaks. under the right amount of pressure the wastegate should open.
your boost controller solenoid should be going to the top of the wastegate, this will keep the wastegate shut.
make sure that it doesnt leak and that you can pressurize it up to at least like 30psi
if this is all setup correctly, you may have a defective solenoid or your boost controller isnt hooked up properly
hope this helps
p.s. i run xs to4s with the hks racing wastegate and a profec-b =]
Old Dec 30, 2002 | 09:33 PM
insomniac's Avatar
Ok, Ivan found out what was the cause of my strange boost problem. It was the sorry *** american made resonated midpipe I had install from the nearest muffler shop, that was willing to take off my cat and make me a mp while I wait.
Somehow from all the heat of the rotory engine, the internal of the pos mp has melted and collapse together, restricting exhaust flow. Which was preventing my turbo to spool up all the way.
Just by looking underneath the car, no one could of ever thought that the mp was clogged.
I give props to Ivan, who took most of the time out of his vacation, to work on my car.
Old Dec 31, 2002 | 03:08 AM
Ghost Ride the Whip
he told me that he put a bolt through the midpipe and that it didn't even come out the other end...
Old Dec 31, 2002 | 06:00 PM
insomniac's Avatar
OMG...just picked up my car from Ivan, can't believe the power on it. Big difference like night and day.
24seven_dada
20
Nov 10, 2018 12:03 PM
ZacMan
Sep 19, 2015 09:20 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
rotor_veux
Sep 3, 2015 07:10 PM
