I want to P-port. Any tips?
Old Jul 29, 2002 | 07:12 PM
KraftDinner's Avatar
I bought a worn out 13B housing off of ebay for a peripherial port experiment. $5.50 by the way
I basically know how to do it, but I was wondering if anyone knows of any step-by-step guides out there to doing it. Or just has some tips and advice for doing it.
Old Jul 29, 2002 | 10:22 PM
Greg's Avatar
how bad is the housing?
Old Jul 30, 2002 | 02:12 AM
Well I just won the auction, haven't gottten it yet, but here a picture of it.
Old Jul 30, 2002 | 08:53 AM
Directfreak's Avatar
I am a Jeeper Now.
JEEZ, that thing is toast.
Old Jul 30, 2002 | 10:27 AM
87GTR's Avatar
just like melba baby melba toast
Old Jul 30, 2002 | 10:44 AM
Greg's Avatar
LORD
Old Jul 30, 2002 | 06:10 PM
Perfect for what I want
Any tips on doing it?
Old Jul 31, 2002 | 06:25 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Yeah get one with the ability to hold some compression...
Old Jul 31, 2002 | 06:31 PM
peejay's Avatar
Old [Sch|F]ool
What for? It's a junk housing. It's just something to experiment with, so that way if/when you screw it up you won't have to worry about ruining a good part.
I've actually been doing the same thing, with the trashed rotor housing from the 12A. I have nothing to add in the way of assistance to this topic except that it's best if you start with a set of known values (intake opening and closing in degrees) and mark the housing off at the opening and closing points, so you get an idea as to where the new hole has to be.
I didn't do that. Fortunately I was close to where I eventually decided I wanted to be. And hey, it's a junk housing, so what.
Old Jul 31, 2002 | 07:21 PM
Greg's Avatar
i would say have a machine shop make the hole but its not worth it
Old Jul 31, 2002 | 10:27 PM
peejay's Avatar
Old [Sch|F]ool
I just realized... that's a pre-86 rotor housing (the water O-ring grooves are in the rotor housing, not the side housing like later engines) which means that it's rather different than the later model stuff.
Old Jul 31, 2002 | 10:51 PM
Rotortuner's Avatar
Undercover
Look at that housing a little closer, isn't that a diffuser in the exhaust port? Those never came in the 4 port 13b's, or at least none that i have seen, and also why would it change since its an older housing? should still be the same.
CJG
Old Aug 1, 2002 | 11:51 AM
peejay's Avatar
Old [Sch|F]ool
Very strange. AFAIK GSL-SE's (which also had water seals in the rotor housings) did not have diffusers either.
But that clearly is an '85-earlier rotor housing, and it clearly has a diffuser.
What the hell IS that thing???
edit: The only thing I can reckon is that that is in fact an '86-92 6-port housing and the "grooves" that we are seeing are just the telltale marks from where the O-rings used to seat.
Old Aug 1, 2002 | 01:00 PM
Rotortuner's Avatar
Undercover
Ya i aggree, thats what it has to be. Any ways what are you guys planning on using for your angle, location on the housing and how large OD and ID? Just curious to see what you guys are planning.
CJG
Jeff20B's Avatar
Lapping = Fapping
You are correct peejay. I recently got a bunch of junk housings to build a mockup 13B and experiment on. That housing is infact an '86-'92 6 port.
Old Aug 1, 2002 | 05:01 PM
swoop's Avatar
check out the Yaw Power site. Port timming basics.
http://personal.riverusers.com/~yawpower/dectech.html
Old Aug 1, 2002 | 05:05 PM
Yeah, i have that bookmarked! It's GREAT advice, very usefull though.
Old Aug 5, 2002 | 03:15 AM
JonesersRX7's Avatar
Kraft,
Any updates, Pics on how it went? Let us know man! Let's see the work.
-- Eric
Old Aug 5, 2002 | 01:04 PM
Rotortuner's Avatar
Undercover
Well i never heard a response to my questions that i posted up above. Whats the deals ? You guys do unerstand that those are what realy affect how it all works. Its ntot very challenging to actualy cut and sleeve the housings, the hard part are figuring out a good set of angles etc. that WORK.
CJG
93FD510
Oct 1, 2015 02:00 PM
Rotafuzz
Sep 30, 2015 09:55 AM
