The FD Restoration - $$$$ Damnit
Old Sep 22, 2006 | 12:32 PM
  #176
KeloidJonesJr.'s Avatar
strictly business
Looks like coming along good.
Old Sep 23, 2006 | 10:01 PM
  #177
Alright got the Trailing arm bushing pressed in, but still trying to decide on which set to use. I also got some new goodies from Adrenaline Racing http://www.adrenalineracing.com/, Tein EDFC version 2.0 and Tein hood dampeners.
While getting the underbody cleanup I noticed that the drive side sway bar mount had a few cracks, unfortunately it can be fixed with a weld and grind. This was caused by the stock sway bar mount being hit by a large roll a long time ago...man that was a long time ago...anyways I have an upgraded mount that tied into the engine cradle with a cross bar so this crack although not ideal isn't a show stopper.
The more you look a car the more you find wrong with it.
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc01376.jpg   The FD Restoration - $$$$ Damnit-dsc01381.jpg   The FD Restoration - $$$$ Damnit-dsc01377.jpg   The FD Restoration - $$$$ Damnit-dsc01382.jpg   The FD Restoration - $$$$ Damnit-dsc01399.jpg
Old Sep 23, 2006 | 10:35 PM
  #178
Not roll, rock damnit! I need to slow down.
Old Sep 24, 2006 | 12:51 PM
  #179
TireSmokin7's Avatar
Registered RX7 Abuser
I love all the good pics of your build up... Looks GREAT!
Old Sep 24, 2006 | 10:49 PM
  #180
Thanks Smokin, I'm really interested in the difference in handling with your delrin kit.
Log 123459ABCDZ
Finished sealing and painting the underbody, Capt. Bobbo spent most of the weekend trying to make my old intercooler look'n pretty for the new image conscious owner whoever they are.
Cleaned up the suspension frames and installed the front engine cradle in order to attach all frontend plastics to finish the body work, looking good. I also repaired a broken driver side arm rest tray for 29K FD Vincent "Lucky SOB" Huynh.
Need...fresh air.....been....inhaling too much....paint fumes!!?!
Moto out........sheeshk
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc01403.jpg   The FD Restoration - $$$$ Damnit-dsc01407.jpg   The FD Restoration - $$$$ Damnit-dsc01408.jpg   The FD Restoration - $$$$ Damnit-dsc01420.jpg   The FD Restoration - $$$$ Damnit-dsc01419.jpg
Old Sep 24, 2006 | 10:53 PM
  #181
Energize.....Bong bong bong
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc01414.jpg   The FD Restoration - $$$$ Damnit-dsc01415.jpg   The FD Restoration - $$$$ Damnit-dsc01410.jpg   The FD Restoration - $$$$ Damnit-dsc01412.jpg   The FD Restoration - $$$$ Damnit-dsc01413.jpg
Old Sep 27, 2006 | 12:10 PM
  #182
SPACE WRANGLER's Avatar
**** been gone for 4 days and whoo look at you
Old Sep 28, 2006 | 12:18 PM
  #183
Here's some pics of me at the track last year. Giving myself a motivation booster. Enjoy
Notice how ruff the paint is and the fender damage...I didn't do that by the way.
Attached Thumbnails The FD Restoration - $$$$ Damnit-lmb_0713-1.jpg   The FD Restoration - $$$$ Damnit-lmb_0775-1.jpg   The FD Restoration - $$$$ Damnit-lmb_0864-1.jpg   The FD Restoration - $$$$ Damnit-lmb_0924-1.jpg   The FD Restoration - $$$$ Damnit-mks_6166-1.jpg
Old Sep 28, 2006 | 12:33 PM
  #184
Rxmfn7's Avatar
Do a barrel roll!
May I ask what you are considering not using the RE trailing arms? I have these along with RE toe links not yet installed, and am planning on doing the derlin bushings such as you, but wondering why there is a consideration of using the stock trailing arm?
Old Sep 29, 2006 | 01:43 AM
  #185
Well here's where I'm at with that. Both are good and doing the intented job, it just comes down to preference.
1. Both essentially do the same thing; limit the amount of flex at the pivot points, eliminating changes in toe, camber and the byproduct wheel hop under launch. I plan on driving and dragging this car with both installed to see if they're is any noticable difference. I will let you know the results when I do.
2. The delrin should last longer (unproven), compared to the metal to metal surface rod-ends. Both are potentially vunerable to debris getting in the bearing surface and accelerating wear, however the delrin should be less sensitive to that.
3. Maintance is about the same as far as checking for wear and play. Replaciing rod ends is easier to do than having new bushings machined. Will have to wait and see if that's even an issue unfortunately.
4. Since the delrin kit uses the stock trailing links there are no issues of getting them adjusted to the right length. Mess up the adjustment of the RE's and your going to potentially get weird handling characterisitcs. However, if your smart and have time you might find that you can create certain handling characteristic that could be beneficial in a drag situation. Very doubtful, but you never know.
Old Sep 29, 2006 | 01:56 AM
  #186
Well ****, I took the stubborn half shaft to work and put in under the press and couldn’t get it to budge at 25tons, didn't want to go further due to potentially damaging the upright. May need to find myself an upright and half shaft assembly...that sucks.
Old Sep 29, 2006 | 08:36 AM
  #187
Het Moto - just a FYI Eddie has his aligment rack now ........
Old Sep 29, 2006 | 10:42 AM
  #188
Ya, I talked to him last week about it when I was picking up my Tein parts. It will be really nice having a place so close to home where I can adjust corner weights and suspension setup.
Old Sep 30, 2006 | 03:17 AM
  #189
MWMburton's Avatar
ur car is hawt! as far as the gt wing goes, i say . . . i dunno. lol. if ur all about the go then go big, if u wanna keep it looking really nice then go 99 spec. im not sure how the big will look but im sure it'll be fine as long as its not a foot n a half above the roof.
Old Oct 2, 2006 | 12:28 PM
  #190
No wing for this car, not a race car, and the 99 spec is really just an attachment with marginal benefits in my point of view (just like the STI and EVO wings). If it was an R1 and I was making it into a straight up race then ya, I'd wing it and put ground effects on too.
Went to HIN and see my dad this weekend. Man, HIN was a waste of 30 bucks. Some cool cars, hoe lotta strippers strut'n their stuff, but too damn dark so see really anything in detail. But I had a kick *** ride along 101 coming back. Hit 183mph in a couple spots and in one section I never went under 100mph for about 78 miles. Rode for 8 hours straight, man I'm sore. My Valentine One Radar Detector saved my *** more than once on this trip
PS: I had to inhance all the HIN pics just be able to see the cars.
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc01451-1.jpg   The FD Restoration - $$$$ Damnit-dsc01452-1.jpg   The FD Restoration - $$$$ Damnit-dsc01473-1.jpg   The FD Restoration - $$$$ Damnit-dsc01498-1.jpg   The FD Restoration - $$$$ Damnit-dsc01514-1.jpg
Old Oct 2, 2006 | 12:31 PM
  #191
Mo Pics
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc01523-1.jpg   The FD Restoration - $$$$ Damnit-dsc01537-1.jpg   The FD Restoration - $$$$ Damnit-dsc01538-1.jpg   The FD Restoration - $$$$ Damnit-dsc01551-1.jpg   The FD Restoration - $$$$ Damnit-dsc01571-1.jpg
Old Oct 2, 2006 | 12:38 PM
  #192
Yet Mo
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc01577-1.jpg   The FD Restoration - $$$$ Damnit-dsc01578-1.jpg   The FD Restoration - $$$$ Damnit-dsc01581-1.jpg   The FD Restoration - $$$$ Damnit-dsc01579.jpg
Old Oct 5, 2006 | 01:40 AM
  #193
MWMburton's Avatar
u were on ur bike when u hit 183 right. if so i do belive u when u say 'i have a screw loose'. lol. well hold on a minute now i dont know much about the fd's n what not but what is the big deal about the R1's? n what the difference to ur car?
Old Oct 5, 2006 | 10:04 AM
  #194
lol, I said I had a few screws loose not just one. There's a difference, some of them cancel each other out, that's why I seem normal to other people.
Hard top version, it could be a base model I don't care, just a hard top. You loose chassis rigidity with the sunroof and it's a total bitch to blow out the braze and put on a hard top and have it true when your done.
Nah, when I'm done with this car I will be looking for a roller eventually and make it into a straight up race car with either a 13G or LS7, but that's a few years down the road.
edit: Then again I might just design and build my own DSR race car, it would cost me about the same amount of money, 20 million dollars. Anybody know of a hot sugar momma that likes car guys?
Old Oct 5, 2006 | 11:13 AM
  #195
Okay, Started stripping and cleaning the brakes. Will have them painted by Friday hopefully.
Raced in the heavy weight Indoor Kart racing leagues at Sykart Tuesday. Finished second after starting from 6th. The track config didn't really lend itself to passing all that well. Apex showed up and won, circumstances out of my control prevented me from giving him a run for his money. Still in the lead for points right now: http://sykartracing.com/standings.aspx
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc01584.jpg   The FD Restoration - $$$$ Damnit-dsc01591.jpg   The FD Restoration - $$$$ Damnit-dsc01594.jpg   The FD Restoration - $$$$ Damnit-dsc01596.jpg
Old Oct 6, 2006 | 09:53 AM
  #196
Finished stripping Brake caliper and applied the first coat of paint. Also got my Tein Flex's back from being rebuilt and all put back together. Mockup time this weekend.
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc01602.jpg   The FD Restoration - $$$$ Damnit-dsc01604.jpg   The FD Restoration - $$$$ Damnit-dsc01601.jpg   The FD Restoration - $$$$ Damnit-dsc01615.jpg   The FD Restoration - $$$$ Damnit-dsc01617.jpg
Old Oct 8, 2006 | 11:45 AM
  #197
Went to Street Warriorz show at PIR last night, tech was closed when I got there so I couldn't drag the bike a few times. But some cool cars where there, this was a better show than HIN! Except not as many booty shaking girls at this one.
500hp at the wheels all blackout Scooby was badass. Whoever did it knew what they were doing, super clean.
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc01628.jpg   The FD Restoration - $$$$ Damnit-dsc01629.jpg   The FD Restoration - $$$$ Damnit-dsc01630.jpg   The FD Restoration - $$$$ Damnit-dsc01627.jpg   The FD Restoration - $$$$ Damnit-dsc01626.jpg
Old Oct 8, 2006 | 04:33 PM
  #198
MWMburton's Avatar
i was there last nite, it was pretty bad. so now im really glad i didnt go to hin but it was cool for a lil while but didnt catch my intrest enough. the jet car was pretty badass! thing was loud as hell! they did have some cool are there though but theyre just wasnt enough action.
Old Oct 9, 2006 | 03:10 PM
  #199
Well this months going to be a waste on working on the car. Shows, trackdays, rebuilding the motor on my truck next week and fixing my friends cars.
Anyways, started the process of putting the motor and tranny together for mockup time. The way things are turning out I going to do mockup before any paint gets layed on the body.
Anybody want to help me, so I can actually get the car done before the end of the year? Quit laughing, I'm being serious....really.
Attached Thumbnails The FD Restoration - $$$$ Damnit-dsc01632.jpg   The FD Restoration - $$$$ Damnit-dsc01633.jpg
Old Oct 9, 2006 | 04:00 PM
  #200
MWMburton's Avatar
call me if u need the help but im not sure how much it will be. im outta a job so i got the days to myself.
