A-spec 500R
Old Feb 10, 2006 | 11:48 PM
Zero R's Avatar
Just in time to die
A-spec 500R
After thinking about it for awhile for numerous reasons (confusion being the main one) I have chosen to close out the old thread and start this fresh and new. So here is all the relavent information needed. Even if you read the old thread reread this as there have been changes made of significance.
It will be available in T4 only. Rear housing options are .82, 1.00, 1.06, 1.12 Divided. Our 500R will offer almost identical response to the 35R with a much more efficient top end. So if you were looking at a 40R this will offer roughly the same power, under most circumstances, with quicker response. If your looking for something that has more topend than a 35R but quicker response than the larger turbo's this will do it. It is more efficient across the board and especially at higher pressure ratios. Example 15lbs on a 35R 74% eff. 500R 77%.. @18lbs 35R 72% 500R 75%.. @20lbs 35R 67% 500R 75%.. @25lbs 35R is out of breath, 500R is 73%.. It will support up to 75lbs/min. at a pressure ratio of 2.75 I can even broaden this for you further if you opt for the anti surge compressor. The best part is you wont have to sacrifice response for this setup. It will be very similar to the standard 35R in response. I spent a while finding this combination and I think it will be the absolute best offering out there for those who want response and power.
Old Feb 10, 2006 | 11:53 PM
BoostedRex's Avatar
NorCal 7's Co-founder
Sean, when would the anti surge compressor housing become a necessary item?
Zach
Old Feb 10, 2006 | 11:59 PM
Zero R's Avatar
Just in time to die
It helps broaden the map as well as keep the compressor from surging not to mention you get the cooler sounding turbo.
Old Feb 11, 2006 | 12:04 AM
Zero R's Avatar
Just in time to die
We have hit 448whp&337rwt@1bar, a few days back and 503&386rwt@20lbs today. I will try and get the sheets up tomorrow
-S-
Old Feb 11, 2006 | 12:25 AM
SyderJL's Avatar
EMPEROR
Just out of curiousity what kind of numbers are you getting/expect to get on 92 octane? 1 bar or so?
Old Feb 11, 2006 | 12:41 AM
Poweraxel's Avatar
the anti surge compressor cover is ohhh sooo sweet!
Old Feb 11, 2006 | 12:46 AM
Rotortuner's Avatar
Undercover
Do a search. he just posted those numbers the other day, the car did 446-448 at the wheels with pump fuel and 14 psi.
CJG
Old Feb 11, 2006 | 06:18 AM
21K95RX7's Avatar
so this is the new name for the 35rs?
Old Feb 11, 2006 | 07:50 AM
21K95RX7's Avatar
It will be available in T4 only. Rear housing options are .82, 1.00, 1.06, 1.12 Divided. Our 500R will offer almost identical response to the 35R with a much more efficient top end. So if you were looking at a 40R this will offer roughly the same power with quicker response. If your looking for something that has more topend than a 35R but quicker response than the larger turbo's this will do it. It is more efficient across the board and especially at higher pressure ratios. Example 15lbs on a 35R 74% eff. 500R 77%.. @18lbs 35R 72% 500R 75%.. @20lbs 35R 67% 500R 75%.. @25lbs 35R is out of breath, 500R is 73%.. It will support up to 75lbs/min. at a pressure ratio of 2.75 I can even broaden this for you further if you opt for the anti surge compressor. The best part is you wont have to sacrifice response for this setup. It will be very similar to the standard 35R in response. I spent a while finding this combination and I think it will be the absolute best offering out there for those who want response and power.
also, what were his supporting mods to make that power? very interested in this turbo!
Old Feb 11, 2006 | 09:29 AM
-S-
Wow. Hm, so on 94 octane with water injection you can run 20 psi....you can get good spool/low end from 3500 rpms and great top end to 8000 rpms, with 500 wheel hp and almost 400 wheel torque? Intriguing.
Old Feb 11, 2006 | 09:35 AM
21K95RX7's Avatar
could be a dual threat turbo ie; road course, and drag?????
Old Feb 11, 2006 | 10:07 AM
Poweraxel's Avatar
yeah its a good all around turbo... you could probably run without WI if you back the timing off but its always a good safety measure.. this coming monday the 500rwhp/20psi run will be repeated to check for consistency and i think it will be videotaped. since the customers ecu has a 24 psi map sensor (microtech) it'll probably be ran up that high just to check what we could get out of it.
have a good one
Old Feb 11, 2006 | 10:17 AM
A-Spec Tuning's Avatar
Registered User
heres some videos guys at 1bar... these runs are from the next day to back up the dynos and check for repeatablity. We will eventually have more vids of other stuff and cars we have that we will be posting on our homepage www.a-spec.com
Efram Lopez
Click here to see Video
Old Feb 11, 2006 | 01:55 PM
Zero R's Avatar
Just in time to die
This is what I was shooting for, this would be great for the guy who loves the road coarse where a 7 should be, but wont have to give up turning up the boost and hitting the strip to feel good about himself there. The best part is still fantastic response. I will be offering other options to this setup as well soon that will improve upper end power more and still keep the response almost identical. I truly feel if you own a FD and want the best all around setup this will be it, hands down.
-S
Old Feb 11, 2006 | 02:16 PM
ronbros3's Avatar
with the choice of rear hsg. would not there be different response with each one. and what kind of money for a complete turbo. and you say divided only , would it work on an open cast manifold, HKS
Old Feb 11, 2006 | 02:43 PM
Zero R's Avatar
Just in time to die
Yes, different housing will offer different levels of response and power. Sacrificing one for the other. You can run divided turbine housings on undivided manifolds your best bet is not to knife edge it but to cut it back into a C-shape. This however will ruin the housing for putting on a full divided manifold later. At this time we are currently not offering just the turbo. It will come only as a complete package setup.
-S-
Old Feb 11, 2006 | 03:14 PM
21K95RX7's Avatar
-S
sweeeeet! thats what im looking for a 500hp road car.
Old Feb 11, 2006 | 03:31 PM
dubulup's Avatar
development
-S-
Is this the manifold? (Equal & optimum length exhaust runners; for thos that don't know)?
Congrats on these numbers!!! You are right this sounds like every FD's owners turbo...in a relatively small package!
Old Feb 12, 2006 | 12:39 AM
13bmaniac's Avatar
you should post pics of the entire turbo kit since in the web page you only have turbo kits installed that will be nice so we can see a good shot of the manifold and turbo.
thanks
Old Feb 12, 2006 | 09:15 AM
rx7tt95's Avatar
Photo Diety
What are we looking at price-wise for just the turbo? Kit? And what a/r would you recommend for street/500rwhp?
Old Feb 12, 2006 | 10:25 AM
dubulup's Avatar
development
^sorry bro...see my post above, COMPLETE package only.
I assume,
Manifold
WG
DP
Turbo
drain/feed lines
hardware
gaskets
Old Feb 12, 2006 | 04:25 PM
Zero R's Avatar
Just in time to die
Yes it is a complete package only. The turbo itself is not for sale, and dubulup that is the basic setup. I have a short runner manifold as well.
Old Feb 12, 2006 | 04:47 PM
Zero R's Avatar
Just in time to die
I do not like to give out numbers as I can never tell what "YOUR" car will do. I see cars on here with T78's making 37Xwhp I see them make 500+ it is all on you to get the power out of the car the kit only provides you a piece of the puzzle.
We did 448whp on one day at roughly a bar we backed it up the next day with a 439 run and a 446 run. Again boost was roughly at a bar. The day after that we did 503@20 lbs. We will keep tuning and tweaking and see where we end up.
-S-
Old Feb 12, 2006 | 09:52 PM
13bmaniac's Avatar
what is the price of the kit? and what is me most agressive package that you offer with this turbo?
Old Feb 13, 2006 | 12:04 PM
Zero R's Avatar
Just in time to die
Price for the kit is $3699, then there are options such as coating and anti-surge etc.
What do you mean by aggressive?
-S-
