Power FC Forum Apex Power FC Support and Questions.
Power FC Datalogit FC-Edit Software
Old Dec 6, 2007 | 10:06 PM
MIKE2's Avatar
quiet a few revisions have been out since .118
FC-Edit Universal
v2.124
- Hopefully reduce number of INR errors
- Add DebugLog.txt for further improving INR errors
- Reset Com port settings when com port is changed
- Fix error in frmMain_load on first time run
- Added SR202PRO v3.122 support
- Changed Setting6 (AT) label to "TPS vs ATF line pressure"
v2.123
- Added COM auto detect function
- Hopefully reduced dropouts while logging and updating simultaneously.
- Fixed FileOpen when txt file has LF instead of CR+LF
- Added SR20DE1 v4.12 support
v2.122
- Added 1JZ-GTE3 v3.20A support
- Added RB25DET v4.33A support
- Add 13B-REW v4.11 support
- Fix log open giving 'File Open Error' when log contains no advanced data
v2.121
- Added compare feature
- Restore the monitor window open/closed on startup
- Added Interpolate feature to map (right click)
- Fixed bug when pasting into IGT map when display = split
v2.120
- Fix run-time error when minimising 3d graph
- Fix EditCurve buttons for all Power-FC versions
- Make column widths in AF table not adjustable
- Fix AF table (and tracer) for 4G63, row 1 is 'KPM frq' not 'Voltage'
- Fix SetupAux form when displaying polynomials.
- Add SR20DET4 v3.12A support
- Add SR20DET4 v3.01A support
- Add SR20DET5 v1.33 support
v2.119
- Add Show All option to Setup ComPort menu
- Fix bug, WriteAll sometimes performing scan when version doesn't match.
- Fixs bugs in setup Aux 5-8
- Add RB25DET v2.33 support
- Add 3S-GE v3.80a support
- Add 2JZ-GTE1 v4.10B support
- Add 4AGE1PRO v1.142 support
Old Feb 14, 2008 | 12:09 AM
P@shencia's Avatar
v2.125
- Fix bug causing rare 'skewed' log file.
- Added 1JZ-GTE v1.91A support
- Added 3S-GE v4.10A support
- Added EJ207 v6.30b support
- Found first read with USB/serial via USB hub was failing.
>> Fixed with reset Com port (close&open) on any retry - or INR error.
- Added more debugging for INR errors.
Old Feb 14, 2008 | 09:52 AM
arghx's Avatar
rotorhead
somebody post this latest version. I don't have access to the yahoo group or whatever.
Old Feb 14, 2008 | 12:08 PM
P@shencia's Avatar
FC-Edit v.2.125 - click for download
Old Mar 6, 2008 | 09:57 PM
silverflash2's Avatar
Is the v2.125 for the beige box also ? What is the newest version for it if not?
Old Mar 9, 2008 | 09:14 PM
VegasFD's Avatar
Wishin I Still Had The FD
To my knowledge, Datalogit stopped creating updates for the beige box. Version 1.120 is the latest. They focused their efforts on the universal software.
The download link is at the beginning of this thread.
-Scott
Old Mar 12, 2008 | 10:28 PM
katit's Avatar
I have beige box and just realized that I use 2.121
Is there any no-no for using universal software with beige boxes?
Old Mar 23, 2008 | 04:54 AM
docmar's Avatar
Thanks so very much for the latest version
Old Mar 25, 2008 | 01:45 PM
topaz's Avatar
Greek Geek
Anyone nows more about this?
Old Mar 25, 2008 | 01:57 PM
arghx's Avatar
rotorhead
the universal software can be configured for the black or beige box. It's under setup --> FC-box
Old Jun 15, 2008 | 07:05 AM
yannis-supras's Avatar
Lag Hater
Thanks very much for the links!!!
Old Jun 18, 2008 | 02:03 PM
Wompa164's Avatar
I'm getting system file dependency errors.
I corrected everything and now I'm getting "Failed to load uctAirFlowGrid from. Your version may be outdated."
Help! I really need to get this Datalogit going. I'm using the 2.125 FC-Edit executable that was posted above.
Old Jun 26, 2008 | 12:31 PM
Godzira's Avatar
yeah, updates appreciated. I am waiting for group invite as well and need to get some fixes installed.
Old Jun 28, 2008 | 06:24 PM
mlmayer's Avatar
Thx
Thanks for posting the update information.
Old Jul 15, 2008 | 04:49 PM
rotory4life's Avatar
links dont work
Old Jul 21, 2008 | 12:55 AM
VegasFD's Avatar
Hey guys,
I just checked this thread for the first time in months. I will check with Admin here and update the links. I can upload the files to my own server and make them readily available to everyone. Sorry for the inconvenience.
-Scott
Old Jul 26, 2008 | 12:04 PM
Veger's Avatar
Originally Posted by Veger
You will find the full version plus all the extra files hereon my site, this is the Full CD version, totaly complete including all the little files if you have never had it installed before.
http://www.mx5info.com/html/FC-Edit/RX7-FD3S%20v1.120/
This like should still be ok
But be sure to then update with VegasFD's links
Old Aug 8, 2008 | 01:23 PM
dradon03's Avatar
Derwin
I have the black box, sent an email to Datalogit and they didn't reply. I tried the links here and I can't download what I need.
Essentially my FC-Edit won't even open right now like it is @ the most basic level. I need to make it into the FD specific maps.
Old Sep 1, 2008 | 02:33 PM
Perry9394's Avatar
can someone please post some sample maps for FD3S???
Old Sep 1, 2008 | 06:33 PM
  #45
dradon03's Avatar
Derwin
If you bought a Datalogit within it it has a sample of the map. Go open in FC Edit and then in samples there is one for 13b-rew.
Old Sep 2, 2008 | 12:35 PM
  #46
Perry9394's Avatar
yup, i have that sample 13B-NEW map but i just dunno any details about it, so i didn't try. i know there are 2 versions of maps that come stock with the apexi PFC, i am looking for the new version, wonder if anyone has it here, and also if anyone have a tuned map for twins and dont mind sharing it, that would be a great helf for references, thz.
Old Sep 2, 2008 | 01:08 PM
  #47
dradon03's Avatar
Derwin
That one is the most recent version. 5.08
Old Sep 9, 2008 | 09:39 PM
  #48
Archangels's Avatar
- Make Haste -
hey guys, i have an S5 Turbo with a PFC and cant find a link to download the software....
all i recall is that it is a specific power FC for the S5 model, and that the casing (ECU) itself is silver....
also, what type of cord will i need to connect it to the PFC itself....
thanx in advance guys!...
Old Sep 9, 2008 | 10:15 PM
  #49
dradon03's Avatar
Derwin
Your not really making sense right now. Do you have an AP Engineering Power FC, a Power FC for FD3S? There is no uploadable software to the Power FC.
Old Sep 10, 2008 | 10:51 PM
  #50
Archangels's Avatar
- Make Haste -
i have an Apexi power FC for the S5 FC....
it is NOT for an FD....
