Haltech OMP Block Off Plate (FD)
Old Dec 1, 2006 | 08:19 AM
dubulup's Avatar
development
anyone have issues with front main bearing after tossing a BOP over the OMP?
I ended up tapping the oil feed (front iron) to the OMP and plugging it...overkill? I also removed the [omp] shaft during the build.
I'm thinking about dropping a reman in and I'm wondering if I leave the shaft in the front cover and just intall the BOP...if I'll be fine.
TIA
Old Dec 5, 2006 | 08:14 AM
dubulup's Avatar
development
no one has tossed an Oil Metering Pump Block Off Plate on an FD front cover (without further modification) without ill effects
Old Dec 5, 2006 | 03:02 PM
C. Ludwig's Avatar
www.lms-efi.com
Tap the front iron where the galley exits into the front cover. I tap them 10-24 and use a set screw with some red loctite to seal the hole. That way you don't have to worry about oil seeping out between the iron and front cover in that area.
Old Dec 6, 2006 | 04:31 PM
dubulup's Avatar
development
That's what I've done on my current engine. My question is...is this proceedure 100% necessary???
If I get a reman...do I need to pop the oil pan off, then remove the front cover and tap the iron?? I'd rather not do that with an engine that is together. I guess I have to make damn sure I get all the shavings.
Old Dec 6, 2006 | 06:11 PM
C. Ludwig's Avatar
www.lms-efi.com
No. Just leave the OMP driveshaft in the front cover and you'll be good. Plugging the passage only becomes neccesary when you remove that.
Old Dec 6, 2006 | 06:14 PM
slo's Avatar
slo
registered user
I just installed the OMP block off plate and I havn't noticed any seapage, or leaking.
I didn't realize it was recomended to plug the oil feed.
Old Dec 7, 2006 | 08:06 AM
dubulup's Avatar
development
^thanks, that was the info I was looking for.
Old Dec 7, 2006 | 03:01 PM
Gohan3rdrift's Avatar
Movie Star
+1
Old Dec 7, 2006 | 04:37 PM
dubulup's Avatar
development
Only recommended if you remove the entire system...shaft and all.
Old Jun 22, 2007 | 08:21 AM
dubulup's Avatar
development
opps
stickmantijuana
20B Forum
21
Mar 22, 2022 01:00 PM
Jeff20B
73
Sep 16, 2018 07:16 PM
BLK 93
11
Sep 9, 2015 10:56 AM
