Post Pics of your FD Wheel Fitment!!
Old Oct 28, 2017 | 04:56 AM
  #2376
mr rxeven's Avatar
center lock wheels
center lock wheels
Old Oct 28, 2017 | 02:43 PM
  #2377
MILOS7's Avatar
Originally Posted by supraman
I think 19's work nicely!!
it looks very good! , what tires size are you running in the front and back ?
Old Nov 12, 2017 | 10:08 PM
  #2378
JP's 93 fd's Avatar
Originally Posted by 7_rocket
^^ Grand mighty's old rims? You need some camber for the rear, it's sticking out too much. Love the rims man. LOVE!
Yes they are! Hopefully getting an alignment soon.
Old Nov 12, 2017 | 11:16 PM
  #2379
cr-rex's Avatar
half ass 2 or whole ass 1
17x9+30
17x9.5+15
square 255/45
slight roll in the front and rear
17x9.5+15 255/40
17x10+20 275/40
feed front and rear fenders
Old Nov 13, 2017 | 04:41 PM
  #2380
speedjunkie's Avatar
Make an assessment...
Veteran: Air Force
Originally Posted by cr-rex
17x9.5+15 255/40
17x10+20 275/40
What wheels are these?
Old Nov 13, 2017 | 08:53 PM
  #2381
cr-rex's Avatar
Te37v
Old Dec 7, 2017 | 10:43 AM
  #2382
Javi.NES's Avatar
Need some input/help if you all have any
I have seen multiple setups on here and had some questions of my own. I am looking into the 2 following specs for a set of te37. Car will be on ohlins coils for reference. How big of a difference do the two have in making it work on a stock body FD?
18x10 +39
18x10.5 +15
I have seen a lot of input on the 18x10.5 +15 fit, but not more than a pull and roll. I also am not interested in doing much of a tire stretch.
Old Dec 7, 2017 | 10:54 AM
  #2383
amustafa32's Avatar
18x10 +39
18x10.5 +15
Is that your front and rear specs you want to run or are you trying to run a square set up?
I run 18x10.5 +22 with a 285/30/18 rear. I'm lowered on Teins with an aggressive roll and in the rear I'm still rubbing a little during hard cornering. Front's I have 18x9.5+22 no issues really
I think you would need roll/pull if you don't want a stretched w/ a +15 on 10.5 wide (depending on how low you go)... I could be wrong...
Old Dec 7, 2017 | 12:28 PM
  #2384
Javi.NES
18x10 +39
18x10.5 +15
I am going to assume you mean stock body FD but with rolled front and rear fenders and some camber.
By the sizes/offset listed it looks like you are considering a couple different styles of TE37 looking at what is currently available.
18x10 +39 is available in the "TE37SL Black EditionII"
18x10.5 +15 is available in the "TE37SL"
Though 18x10.5 +14 is available in the "TE37SL Black EditionII" which is pretty much the same for fitment.
The 18x10 +39 will fit a stock body FD with rolled front fenders, 2.5deg front negative camber and stock rear fenders with -1.3deg rear camber and a 265/35-18. Only issue I had with similar set-up is 265/35-18 is a bit too tall of a tire up front and will rub the plastic fender liners when turning. 255/35-18 would fix that issue.
On the 18x10.5 +15 a 215/40-18 would fit the same for the tire as the above and the wheel lip would stick out 30mm away from the body of the car.
Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
I would NOT do the 18x10.5 +15 with 215/40-18.
The 18x12 +26 "TE37SAGA" with a 255/35-18 fits only 8mm further out than that so could be done with a roll with some pull front and rear...
Not sure why you don't list the 18x10.5 +22 "TE37SL" or the 18x10.5 +21 "TE37SL Black EditionII"
Which would fit allow a 235/35-18 and the wheel lip would stick out 24mm from the 18x10 +39.
Even better would be the new "TE37SAGA" which is available in 18x10.5 +24 which would fit 245/35-18 and the wheel would stick out 21mm from the 18x10 +39.
Bonus, it has the aggressive Face 4 available.
http://www.willtheyfit.com/index.php?width=265&aspect=35&diameter=18&wheelwid th=10&offset=39&width2=245&aspect2=35&wheel_size=1 8&wheel_width=10-5&offset2=24
https://www.rayswheels.co.jp/product...wheel=TE37SAGA
Volk doesn't make a wide wheel (over 10" wide) with an offset that fits the stock body FD well, but they do make 18x11 +55 "TE37RT" for Porsche. With a 20mm 5x114.3 to 5x130 adapter spacer that makes it 18x11 +35 so you could fit 255/35-18 with the tire tucking the same as 18x10 +39 and the wheel sticking out just 17mm (so better fitment with the 18x11 than all the 18x10.5 offered).
I wish Rays Engineering would at least make the TE37 fitments they do for Porsche machined for 5x114.3mm bolt pattern...
Old Dec 7, 2017 | 08:13 PM
  #2385
Javi.NES's Avatar
This guy!
Yes, I was looking into several options. I was looking into doing a squared "mildly aggressive" setup.
The wheel setup I am looking at is the 18x10 +39 it is a te37 OG setup, not the SL. "Real" forging vs flow form forging. I understand there will be some mild fender work, rolling, and some camber which I am not opposed to. I am just not interested in doing the crazy stretch style. Id also like to add that I am not a fan of spacers either, but if theyre needed at a small degree then sure. I see you were running a 265/35 tire and stated the inner liner would rub, how bad? What tire were you running, and how low?
Old Dec 8, 2017 | 11:38 AM
  #2386
When I ran the 18x10.5 +38 with Federal 595-RS 265/35-18 the front tire rubbed lightly on the inside of the fender liner just below where you see the plastic in the engine bay when I turned the steering wheel because the tires were too tall. The tires would also rub the factory mud flap on the back of the fender arch slightly and much more than slightly as any debris would build up there between the fender sheet metal and the mud flap.
When I went to 18x11 +45 with the shorter 295/30-18 the rubbing went away.
Ride height
profile
When I switched to 18x11 +45 with 295s
Old Dec 8, 2017 | 01:51 PM
  #2387
Javi.NES's Avatar
Thats just crazy to think lol
So the thought process is to run a +22 in the rear and a +35 in the front, making a requirement of spacers. 5mm in the front and 17mm in the rear. This SHOULD make a 265/35 tire fit all around with minor work.
I believe "Farkel" was running this setup on set of Advan GT but with A048, making the thread width 10.3 and Diameter 25.2. I will be running a 265 with 9.4 thread width and 25.3 Diameter. Does this make sense to you Blue??
Edit: Just found the link to the advans.
https://www.rx7club.com/wheels-tires...comps-1106783/
Old Dec 9, 2017 | 12:37 AM
  #2388
No, a 1/2" stagger with the wrong offsets and spacers doesn't make sense to me but plenty of other people do it...
Old Dec 9, 2017 | 12:50 PM
  #2389
Javi.NES's Avatar
Fitment was more of the question.
I decided against the square setup. It just doesnt make sense for what I want, and I am not a big fan of running spacers and not even sure why I considered running that much to begin with. The searching continues.
Thanks for the help Blue!
Old Dec 11, 2017 | 11:39 PM
  #2390
DigitalRX7's Avatar
Tenured Member: 5 Years
Work VS-XX 18x9 +26 & 18x10 +20
Old Dec 19, 2017 | 11:13 AM
  #2391
w4kj4k's Avatar
Do you guys think 18x11.5 + 25 rubbing 265/35 will work in the rear with just a roll?
Old Dec 19, 2017 | 11:28 AM
  #2392
DigitalRX7's Avatar
I really doubt that will fit unless you run a crazy stretch. 265 with that wheel setup would poke a lot. I had a hard time fitting 18x10 +20 with a 255.
Old Dec 26, 2017 | 08:25 AM
  #2393
YoshiFD3S's Avatar
FD + 2JZGTE = WIN! **D
OEM pulled and rolled fenders.
Volk RE-30's....19x10 +25 and 19x11 +25......235/35 & 275/35 tires.
Old Dec 27, 2017 | 12:59 AM
  #2394
Veteran: Air Force
I'm gonna go with absolutely not. I have 18x11.5 +12 with 285/30 but I also have my fenders pulled about 2". MAYBE if you ran a retarded amount of stretch and negative camber, MAYBE. But it would be (and look) absolutely idiotic, along with not being functional in the least. Sorry man. lol
However, pull those fenders or get some over fenders and you'll be set.
Old Dec 27, 2017 | 10:23 AM
  #2395
w4kj4k's Avatar
Ah! It’s not loading on photobucket
Old Dec 27, 2017 | 10:25 AM
  #2396
w4kj4k's Avatar
Gotcha! Thank you for the reply!
Old Jan 1, 2018 | 11:35 PM
  #2397
mannykiller's Avatar
Garage Hero
18" Enkie GTC01RR
F: 9.5 et22
R: 10.5 et15
Old Jan 8, 2018 | 12:40 AM
  #2398
Jose A.'s Avatar
Rexxy
nice
Old Jan 28, 2018 | 11:36 AM
  #2399
LO7's Avatar
LO7
Old Mar 6, 2018 | 10:55 AM
  #2400
Javi.NES's Avatar
Went ahead and installed the Ohlins coilovers this past weekend as wheels are expected to arrive this week.
Waiting for everything to settle to make adjustments, getting fenders rolled tomorrow as my driver side fender has rubbed with current wheels as you can see.
First alignment prior to wheels will be done this Friday. Love how they ride compare to stock, a lot smoother than expected.
