Old Dec 9, 2017 | 04:09 PM
  #6701
rwatson5651's Avatar
79 w 13B4port
excellent work. Can we see a rear view?
Old Dec 9, 2017 | 08:30 PM
  #6702
peejay's Avatar
Old [Sch|F]ool
My 84 is getting raunchy so i bought a new shell for its mechanicals.
Old Dec 11, 2017 | 02:27 PM
  #6703
lwrobins's Avatar
seattle seven
Blackout
I've been toying with this hood blackout idea...
Old Dec 18, 2017 | 12:42 AM
  #6704
7aull's Avatar
RX HVN
Clean look! not sure this would work as well on any other color?!
Stu Aull
80GS
AZ
Old Dec 18, 2017 | 01:59 PM
  #6705
DreamInRotary's Avatar
Always Wanting to Learn
KCREPU that is gorgeous! I'd like to do something similar for my center console, just not sure I have the patience to accomplish a job that well done. Will look amazing in the car to say the least!
Old Dec 18, 2017 | 10:34 PM
  #6706
KansasCityREPU's Avatar
Out In the Barn
Thx - I've since cut the lower holes for the gauges and need to give it a respray. I hate that Rust-Oleum paint and primer in one. It looks good but the can sprayer fails most of the time.
Old Dec 22, 2017 | 01:50 AM
  #6707
RXChevin's Avatar
Any intrest in a build write up
Hey all I can't thank some of you enough. The forum has been great and the build threads that everyone posts are an amazing help. Ive been using the writeup's from wangracing and Viking War Hammer and just wanted to see if there was any interest in me doing one as well.
Old Dec 22, 2017 | 01:54 AM
  #6708
7aull's Avatar
RX HVN
Safe to say most EVERYone enjoys a vicarious follow of a good project. Undercarriage clean up you have done is EPIC. Good luck.
Stu Aull
80GS
AZ
Old Dec 27, 2017 | 08:48 AM
  #6709
JSmall's Avatar
That underbody looks incredible
Old Dec 30, 2017 | 09:11 PM
  #6710
Richard Miller's Avatar
Damn, it did start!
any picture before you sprayed? what kind of rust issues if any did you have to contend with? What did you use for a coating? Also that is a great purple.
Old Jan 26, 2018 | 08:46 PM
  #6711
klptk's Avatar
I spent the last few days pulling my rear axles and got new bearings put on today. Years of curbing had the passenger side grinding but slipping off a rhino ramp really gave it the clunks.
Maybe a dumb question, but I read a post saying to put bearing grease on the axle seals for assembly. Will coating with a bit of diff oil work fine?
Old Jan 27, 2018 | 10:29 AM
  #6712
meifert's Avatar
Cracked a housing and rotor.
Old Feb 9, 2018 | 08:39 PM
  #6713
ricsrx's Avatar
Member of one
Old Feb 9, 2018 | 08:40 PM
  #6714
ricsrx's Avatar
Member of one
Old Feb 10, 2018 | 12:51 PM
  #6715
meifert's Avatar
Helped unoack the SR20DET for the swap. It came with quite a few extra oarts that will be sold to offemset the cost of everything involved. Also, stripped the Ford 7.5 down for the brackets to be welded on
Old Feb 20, 2018 | 09:02 PM
  #6716
peejay's Avatar
Old [Sch|F]ool
Old and busted vs. new hotness.
Old Feb 23, 2018 | 07:48 PM
  #6717
ricsrx's Avatar
Member of one
fuel access
Old Feb 27, 2018 | 05:40 PM
  #6718
peejay's Avatar
Old [Sch|F]ool
Old Feb 28, 2018 | 11:59 AM
  #6719
Jeff20B's Avatar
Lapping = Fapping
Think this one will be less breakable, peejay?
I see you have a dual bolt pattern on the flange; good thinking.
Old Feb 28, 2018 | 09:31 PM
  #6720
peejay's Avatar
Old [Sch|F]ool
It's a single bolt pattern. I had Da Boss chuck up the Ford flange and machine the inner OD a little larger to accept the Mazda spigot diameter. I gave him a Kia Sportage front driveshaft chunk for reference The Mazda bolt holes are merely drilled in where there wasn't a Ford pattern in the way.
Having major difficulties getting the Watts to work with it.
Old Mar 7, 2018 | 11:44 AM
  #6721
Freeskier7791's Avatar
Ric, your car looks pretty epic, what all are you doing with it?
Old Mar 7, 2018 | 12:04 PM
  #6722
DWNUNDR's Avatar
what seat mounts are these???
Old Mar 8, 2018 | 02:38 PM
  #6723
ricsrx's Avatar
Member of one
I am not sure...i have owned a few 7s in my life and always wanted to go crazy on one. I just want mostly to terrorize the neighborhood
Old Mar 11, 2018 | 06:30 PM
  #6724
DivinDriver's Avatar
1st-Class Engine Janitor
Passed smog... again )
Old Mar 15, 2018 | 01:17 PM
  #6725
Sounds fun!
