Upgrading 100% 93 Stock FD. Suggestions...
Old Oct 6, 2017 | 09:39 PM
  #76
rowdog_14's Avatar
Originally Posted by Sgtblue
Agree, looks good. Not sure if it’s been mentioned previously but seeing these pictures made me think of one other reliability mod you might consider...stock dual oil coolers. Finding a good used set might take some time but a worthwhile mod imo.
oh yeah that was on my list. I actually had the Pettit racing set on my list but if I came across an R set I was going to jump on those.
Old Oct 8, 2017 | 08:24 PM
  #77
rowdog_14's Avatar
Bleeded the brakes today with new brake fluid. Man brakes feel so much better found a new leak on the side of the oil filter. Will check it out next weekend. Can not want for these dang gauges and down pipe.
Old Oct 11, 2017 | 12:38 PM
  #78
silverTRD's Avatar
Time or Money, Pick one
Originally Posted by arghx
For what it's worth, here's a graph of airflow into a medium sized V8 engine at WOT (naturally aspirated). It's a back to back run, with the second run having the main cats gutted.
There's a difference of about 3.5% airflow between the two runs near redline.
The difference in power would be larger with our cars being turbo, correct?
Old Oct 12, 2017 | 09:12 AM
  #79
rowdog_14's Avatar
So car started leaking oil about a week after I got it. Cleaned off the left side of the engine this morning and think I found out where it is coming from. Either the bottom of the oil filter, the connection the filter connects too(oil filter body two o-rings) or the oil pressure sensor. Man things are tight in this engine. I love working on my 04 RAM. Nothing but room
Old Oct 13, 2017 | 10:39 AM
  #80
arghx's Avatar
rotorhead
probably but it's going to depend on the details of what you're changing.
Old Oct 14, 2017 | 02:00 AM
  #81
rowdog_14's Avatar
Well drove the car 70 miles today 15-20 min in stand still traffic. Car did great, and I confirmed the oil leak is on the section that the oil filter spins on to. Also I smelled eggs today after the car sat and let it sit for about 3 hours. I started it up started driving out the parking lot. I was stuck on a hill so I was ideling it up and smelled the eggs after I was able to take off so probably will need a new cat , downpipe still on order and can not find a used RB dual tip for a good price so guess I will buy a new one.
Old Oct 15, 2017 | 01:24 PM
  #82
rowdog_14's Avatar
AST replaced with an OEM AST. Getting there, only a few more things to go and I will be happy. Ordered the oil filter stand o-rings that are leaking, noticed rx7 have a battery cover so will order that too. HSK downpipe should be shipped out in the next week or so.
Old Oct 15, 2017 | 06:31 PM
  #83
rowdog_14's Avatar
Just ordered the RB Dual Tip! Working from home all next week so hopefully it comes in along with the o-rings
Old Oct 17, 2017 | 07:38 AM
  #84
rowdog_14's Avatar
Oil stand O-rings out. Flat as a kitchen counter and slitghtly cracked . I have an o-ring set here but went ahead and just ordered some factory ones the other day. Should be here tomorrow hopefully
Old Oct 23, 2017 | 05:06 PM
  #85
rowdog_14's Avatar
Oh my this RacingBeat exhaust looks great!!!!! Love the clean welds and quality!!! Will try and install tonight!
Old Oct 23, 2017 | 05:47 PM
  #86
rowdog_14's Avatar
Man breaking these exhaust bolts are a bitc-!!! My truck was not this hard. Soaked these suckers over night and freshly sprayed them again. Might have to ride to my old job and put it up in the air to get better leverage and worst case impact gun!!!
Old Oct 23, 2017 | 05:54 PM
  #87
rowdog_14's Avatar
Got one!!! Dam- these sucker... now let's try the other . Dang exhaust would have been on by now started working on this thing around 6:30! Had to jack the car up about 6 more inches to put an extra wrench on the end for leverage.
Old Oct 23, 2017 | 07:34 PM
  #88
rowdog_14's Avatar
Done!!! I really like the exhaust! Did not think I would notice a difference in power but man it spools up a little quicker. I can only imagine adding the HKS downpipe now.
Old Oct 23, 2017 | 07:38 PM
  #89
rowdog_14's Avatar
Originally Posted by gmonsen
Yeah. Well, you made me go the other way. I took off the R1 and put on the base...
Ok, the base lip is actually not bad. If mine was not cracked in the middle with a big chunk out of it I probably would have stayed with it. I do like the R1 a little better. What made you but the base lip on?
Old Oct 24, 2017 | 05:58 AM
  #90
arghx's Avatar
rotorhead
If you don't have some kind of heat wrap or heat shield on the downpipe you will notice your floor boards heating up.
Old Oct 24, 2017 | 06:02 AM
  #91
Sgtblue's Avatar
Urban Combat Vet
^ Agreed...and good catch. Now would be the time for him to have it heat-coated.
Old Oct 24, 2017 | 06:58 AM
  #92
rowdog_14's Avatar
Yep 👍 already on my todo list. Not doing heat wrap on this. Really do not like that setup on stuff unless that is the only option. So sending out or might do local once I get the downpipe. Picking up my battery cover locally Saturday.
Old Oct 24, 2017 | 03:06 PM
  #93
I think the R1 lip and rear wing were simply added to distinguish the R1 package from the other versions and make a statement that this is the more sporting one. They were tacked onto the basic design and are not really an inherent part of it.
The R1 front lip and rear "floating spoiler" were developed in the wind tunnel and as you say definitely tacked on to the performance version of the FD after they found out how much front end lift the new body had at speed in the initial wind tunnel tests. Together they halve the front lift coefficient without affecting the rear- though they do increase coefficient of drag.
The R1 rear element was definitely styled to look like a wing, though it acts as a spoiler (hence Mazda's term "floating spoiler")- so I agree there is an element of style over pure function there.
So, I agree with them being tacked on to the beautiful FD body design and I agree with the rear wing being overly styled (could have been a simple duck bill spoiler or wicker); but they were put there for performance in the end.
Old Oct 24, 2017 | 05:35 PM
  #94
rowdog_14's Avatar
While the R1 spoiler pays "lip service" to getting a little more air in the oil cooler ducts, I decided the overall shape of the R1 spoiler didn't relate well to the lines of the grille or entire front end. And, the R1 lip on my car takes the eye away from the aluminum grille I had made. The base spoiler lip simply follows the lines of the grille and ducts and so it emphasizes those lines. I think the R1 lip and rear wing were simply added to distinguish the R1 package from the other versions and make a statement that this is the more sporting one. They were tacked onto the basic design and are not really an inherent part of it.
cool
Old Oct 25, 2017 | 10:41 AM
  #95
https://www.rx7club.com/3rd-gen-gene...t-lip-1116170/
Old Oct 25, 2017 | 04:06 PM
  #96
rowdog_14's Avatar
So gauges should be shipping out in the next day or two. I have a triple dash pod but like the din pod too.
Negative/Positive with the dash speaker pod is I loose the clean dash factory look, but I am able to keep my eyes at least somewhat on the road if I need to check the gauge.
Negative/Positive with the Din, I am able to keep the clean dash look, but I have to completely take my eyes off the road.
Gives me something more to think about. I have read other post about the same and need to make a decision for myself
Old Oct 25, 2017 | 05:39 PM
  #97
eslai's Avatar
You are absolutely correct. The non-R1 car with no wing shows purity of form. I think the R1 bits look tacky. Nice job, can't wait to see the car at SevenStock!
Old Oct 25, 2017 | 06:00 PM
  #98
rowdog_14's Avatar
Just drove around and not liking the location of where the DIN mount would be. I put in the 3 gauge pod and functionally works better. Guess I just will have to live with the unclean dash look
Old Oct 25, 2017 | 06:04 PM
  #99
Sgtblue's Avatar
Urban Combat Vet
Why are you set on all these gauges when you're trying so hard to keep a clean factory look?
Again, IMO the only gauges you really need on a stock car with a stock ECU are boost and temp, either oil or coolant. Having both is redundant. Coolant is typically easiest to install and if installed using the TB coolant line, easily reversible. And I don't see the need for fuel pressure. You can't adjust it anyway.
Old Oct 25, 2017 | 06:27 PM
  #100
adam c's Avatar
Cheap Bastard
Why are you set on all these gauges when you're trying so hard to keep a clean factory look?.
Dash pod completely ruins the "stock look". Looking down at gauges for a moment is no different than looking at your stereo. Din is the way to go!!
Attached Thumbnails Upgrading 100% 93 Stock FD. Suggestions...-gauge-pic.bmp
